Question about Toshiba 42H83 42" Rear Projection HDTV-Ready Television
Dark line across the top of 56HM66
I have a dark shadow across the top of my Toshiba 56HM66 television, it started with a narrow band and continued until it is know the top 7-8 inches of my screen that is darkened. Any suggestion would be appreciated.
  • rtruett1 Jan 31, 2009
    Thanks JB you are a godsend your suggestion fixed my problem. I have researched the internet and there are several people changing out the light engine or light tunnel and are spending money on something they probably don't need. THANKS AGAIN!!!!!!!!!!!!!!
    Problem Solver:
I had the same problem on my tv found a simple solution its been a week and no problems so far.pull out light engine you will find round piece of tape pull it of there will be a #2 phillips screw in about 3 inches turn it clockwise and watch it vanish.i turned mine a little further to assure it would be gone.only took a couple of minutes to do dont know how long it will last though good luck
TelecomTech
jb
Posted on Nov 23, 2008
Vizio VW46L10 TV has a 6 inch dark band across the top of the picture.
Change input device to some other like a DVD player.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry. If problem persists, call in a qualified service technician.
Aug 02, 2012 | Televison & Video
Toshiba 56hm66 dark screen
I seem to remember this issue in their sets, might want to spend some time with the model number and search "problems" as I have seen this in one of these before---several thousand sets ago.
Apr 08, 2012 | Toshiba 56HM66 56" Projection HDTV
My zenith lcd tv has horizontal black lines whih form a band about 3 inches wide across the screen, sometimes the band looks more like a dark shadow than lines other times the right side of the screen...
This is either 1 of 2 things, first it could be faulty panel tabs , in this case, there is nothing you can do and is unrepairable....2) you could take the back off the tv and you will see 2 ribbons going from your t-con board to the panel tabs (top center of tv) remove them carefully and reseat them. This is a common problem. Tv repair tech 15 years! Best of luck.
Dec 05, 2017 | Zenith Televison & Video
A dark shadow is diagonal across the top of the screen. Can it be fixed?
hi,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The most common problem for this complaint is contaminated coolant for the picture tubes. If you look directly into the three picture tubes you will probably see a haze in the blue one. This is fairly common but requires a knowledgeable service man to take care of.
May 25, 2010 | Toshiba 50HM66 52" Television
Dark horizontal band at top of Sony KDF - 46E 2000 TV
rca ps2720lv blue is very dim any suggestions
Nov 14, 2009 | Sony Televison & Video
I have a 46 Toshiba DLP television
Hi,it does sound like it could be that mirror since thats what direct the light of the lamp.You will need to replace the light tunnel.
Oct 05, 2009 | Toshiba Televison & Video
I'm getting a rainbow tint on the upper 1/5th of
usually when the lamp is going out the picture gets dark if you are getting a rainbow tint most likely the light engine is going bad.
Aug 17, 2009 | Toshiba 56HM66 56" Projection HDTV
Toshiba 52WM48 - Dark line across top of screen about 4 inches
replace the vertical ic, LA 7833 and four capacitors near it, i encountered this last two days.change the parts and it ok now.
cost of this parts is about $20.00
Jan 22, 2009 | Toshiba 42H83 42" Rear Projection...
Left side of television just started having a shadowing problem?
I have the same problem and was told by a technician that I need to replace the light engine. Probably around $ 700.00.
Oct 15, 2007 | Samsung HL-R6167W 61" HDTV
Toshiba 42H83 42" Rear Projection HDTV-Ready Television Logo
268 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
