Question about Speed Queen Dryers
Speed queen wiring new motor 91593 harness color code matchs except a orange wire that comes off from the white wire do I splice it to another wire?
Speed queen AG5419 dryer replacing motor with 915p3 motor wire harness color codes yel,brn,dbl. orange, white,prob white has a ornge wire split off from it ,am I to splice it in somewhere?
  • 77 Answers
SOURCE: conveyor dryer wiring
Newer electrical codes call for a 4 wire receptacle. never splice appliance cords, it isn't woth the safety issue and they are not very expensive. you need to access the terminal block, which is where the cord goes into the dryer. the cord you use (3 or 4 wire) will depend on what is on your wall. if you wall has a 3 wire plug then you will need to connect the green wire from the center terminal to the frame of the dryer. there is probably a hole and screw next to terminal block. that is where the green wire goes on a 3 wire hook-up. if you have a 4 wire receptacle then the green wire should be hooked to center terminal (white). you will have to obtain the proper cord (pigtail) from a parts supplier.
J
Posted on Jun 10, 2008
mikedurland
  • 481 Answers
SOURCE: I have to change the
  • green = ground (attach directly to the case, should be a green painted screw near the opening
  • red = hot 110v connect to the red on the dryer
  • black = hot 110v connect to the black on the dryer
  • white = neutral connects to the blue (only if the blue is in the middle)
  • neutral is always in the middle with a hot wire on either side of it.
  • also make sure all the connections are tight
let me know if you need more help Mike
Posted on Jul 02, 2008
Benimur
  • 6966 Answers
SOURCE: splicing the wiring from a kenwood excelon kdc-x589 unit to a jeep harness
For the Kenwood KDC-X589:
yellow - always on B+12 such as battery + terminal
red - switched B+12 such as ACC of IGN switch
black - body/chassis ground (- battery)
orange/white - dimmer control wire (car light control switch)
gold - to my knowldege no gold
brown - mute control from mobile phone
pink/blk - external amplifier control/trigger wire
blue/white - power control wire similar in function as the orange/white
blue/blk - to my knowldege no blue/blk
blue - motorized/power antenna
For the vehicle, pls postback info on year and make/model.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 13, 2008
ginko
  • 19396 Answers
SOURCE: no sound.
The first thing you need to do is doublechecking all the new wirings, it sounds like a contact.
Posted on Oct 24, 2008
SOURCE: changing heater element in kenmore dryer (110.60702990)
the orange wire is for the timer if you do not connect it then the cycles wont work.the timed cycle will but not the other cycles.
Posted on Nov 13, 2008
No sound.
Oct 24, 2008 | Kenwood KDC-MP338 Car CD Player
Bosch 02 sensor downstream on a 1996 Jeep grand cherokee 4.0 motor. I have no wire harness to match the colors to. bosch has two white, one grey and one black. Jeep has orange/green,black/brown,black/blue...
The two white are the heater
The black the ground
The gray the O2 Sensor output,
you back probe to check Voltage
& Switching Times
The vehicle wiring harness does not have to match
the sensor, BUT -- you need to have the same
connector on the sensor
If you have a universal cut & splice, you have junk,
and we given the wrong part
Get a Bosch or NGK, OEM sensor & just
plug it in
Jun 23, 2011 | Jeep Grand Cherokee Cars & Trucks
Had to re-wire the tail lights after a small fire which fried the rear wires. Cut out all the melted wiring in the harness and re-spliced the wires. tail lights work, turn signals , but the brake lights do...
See your GM dealer they will print out a wiring diagram for you, Look at the brake switch under the dash, I,m pretty sure they have a couple of white wires and an orange. The wire harness runs along the roof on the L/F side, What we use to do is run temp wires to test and varify everything and then do it perminantly. Good luck Kirk fc6fc
Apr 03, 2011 | 2001 Chevrolet Astro
How do i connect a kenwood krc 394 radio cassette,+ve battery, eth, and speaker connections.
Head unit color code:
12V-Yellow
12V switched-Red
Ground-Black
Illumination or Dimmer-Orange/Orange w/white stripe
Blue-Power Antenna
Blue wwhite stripe-Amp turn on
Whites-FL speaker
Greys-FR speaker
Greens-RL speaker
Purples-RR speaker
(Black stripes negative)
If you have a female harness to connect to the veicle side you will pretty much color match. The only exception is that you may only have an amp turn on wire but only a power antenna on the vehicle. In this case you would connect blue w/white stripe wire from radio harness to the blue antenna wire on the vehicle side.
If you are doing a hardwire (factory plug has been cut off) you can obtain a wiring code for your vehicle at www.the12volt.com for most vehicles.
Jun 06, 2010 | Kenwood KRC-394 Cassette Player
Suburu radio wire harness. trying to match up with a new soni deck
Hello uze7, Here is the wiring match up for a 2009 Subaru Forester using the Metra 70-7552 wiring harness: NOTE: The actual harness will be listed as a Nissan harness, but has been used by Subaru since 2007. Also, I'm assuming that your Sony deck uses the standard color code. If not, you should have a manual that lists the function along with the colors. Match the wiring by function, not by color (although the colors may be the same). 2009 Subaru Forester Radio Wiring Color Code: Battery BLUE/RED (+) RADIO HARNESS Accessory YELLOW/RED (+) RADIO HARNESS Ground BLACK (-) RADIO HARNESS Illumination VIOLET (+) RADIO HARNESS Dimmer BLACK/WHITE (-) RADIO HARNESS Power Antenna YELLOW/BLACK (+) RADIO HARNESS LF Speaker (+) BROWN LF Speaker (-) BROWN/WHITE RF Speaker (+) BLUE/WHITE RF Speaker (-) BLUE/YELLOW LR Speaker (+) WHITE/BLACK LR Speaker (-) RED/YELLOW RR Speaker (+) GRAY RR Speaker (-) GRAY/RED Metra Harness: Yellow ? 12V Constant Red ? 12V Accessory Black - Ground Orange ? Dash Light Dimmer/Illumination Green ? Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) White ? Left Front Speaker (+) White/Black ? Left Front Speaker (-) Purple ? Right Rear Speaker (+) Purple/Black - Right Rear Speaker (-) Gray ? Right Front Speaker (+) Gray/Black - Right Front Speaker (-) Standard CEA Color Code: Blue - Power Antenna Blue/White - Remote Turn-on Pink/Black - Audio Interrupt In (Phone) Orange - Illumination Red - Ignition (Switched 12V) Yellow - Battery (Constant 12V) Black - Ground Gray - Right Front Speaker (+) Gray/Black - Right Front Speaker (-) White - Left Front Speaker (+) White/Black -Left Front Speaker (-) Violet - Right Rear Speaker (+) Violet/Black - Right Rear Speaker (-) Green - Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) Hope this helps.
Aug 13, 2009 | Car Audio & Video
After I pulled the old CD player out of my car the wires end plug dosnt match up to my new Pioneer DEH-11E. Is there a way to make it work or should I take it back.
Hello al_will00,
The color coding of the wires from aftermarket equipment will not match up with vehicle color codes. The new player will work OK when you have matched up the wiring by function. There's 2 ways to do it: 1) Find the color coding of your vehicle wiring and splice/tap into the existing harness; 2) Purchase an aftermarket wiring harness that plug in directly.
The 2nd option is best. It allows you to make all of the connections (usually color for color) sitting at a table or workbench insted of from behind the poorly lighted dash. It also allow you to reinstall the OEM radio if you ever decide to do so. Splicing or tapping will make it more difficult.
I'd visit one of the online retailer like www.crutchfield.com or www.sonicelectronix.com to purchase a wiring harness. You can determine the correct model number from various sources, including the manufacturer, such as Metra here. Just enter your vehicle make, model and year information to see a list that the vehicle.
Hope this helps.
Aug 10, 2009 | Pioneer DEH-1100 CD Player
Splicing the wiring from a kenwood excelon kdc-x589 unit to a jeep harness
Jul 13, 2008 | Kenwood Excelon DDX-7015 Car DVD Player
Installing washing machine motor P/N 35-5022, need wiring schematic to hook up to machine internals
The black or brown connection block on the motor should be color coded to match the harness. If not you will need to remove the control panel and find the service guide sheet. This will give you the wiring diagram for the whole machine.
Jan 10, 2008 | Maytag Performa PAV2200
Dryers Logo
42 people viewed this question
Top Speed Queen Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Kristy Heard Duke
Kristy Heard Duke
Level 1 Expert
Are you a Speed Queen Dryer Expert? Answer questions, earn points and help others
