Question about Nintendo Wii Console
How do i fix Wii error code 50299 - Nintendo Wii Console
2 Suggested Answers
  • 26 Answers
SOURCE: I'm trying to connect my
    Connecting directly to a modem:
  1. Power off the Wii. Connect the official Nintendo Wii LAN adapter to the Wii, and insert a working ethernet cable into the official Nintendo Wii LAN Adapter.
  2. Unplug all devices from your modem. Most modems are unable to support more than one device at a time.
  3. Power cycle your modem. To do this, unplug the power from your modem and let it rest for 20 seconds. Plug the power back in. Connect the Ethernet cable from your Wii console to the Ethernet port on your modem.
  4. If the connection test fails, try a "Manual Setup" with the Wii console (how to), using your network's IP address, Default Gateway, Subnet Mask, and DNS information. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input these exactly as they're listed into the "Manual Setup" of the Wii console's internet connection.
  5. If you are still unable to connect and you are using broadband Internet, then your ISP likely uses PPPoE to establish a connection to their network. The Wii is not compatible with PPPoE. Contact your ISP for more assistance
Posted on Sep 14, 2010
Error code 50299 what do i do about that? trying to watch my netflix
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=50299&system=Wii&locale=en_US
Mar 06, 2015 | Nintendo Wii Console
Unable to connect to the Internet Confirm the Internet settings of the wii console. Error code 50299.
Go to internet options on your Wii settings, select internet, and then connection settings. Once that is done you will be able to see the wifi connection. Click the wifi connection and delete it. Try to reconnect the Wii to your wifi router and you should have success connecting to the internet. If it doesn't connect repeat the steps listed above.
Dec 31, 2014 | Nintendo Wii Console
Tried to set netflix on my wii and an error code came up 50299
Hey, here are your options:
  • Power cycle your home network and perform a connection test on the Wii.
    If your Wii was previously connected online, and no changes have been made to your home network, perform the following steps (if you have not previously connected your system online, skip to the next bullet point):
    1. Remove the power from your wireless modem and router. Plug the power back into both devices, starting with the modem.
    2. From the Wii Menu, select "Wii" in the lower-left corner, and then select "Wii Settings." Use the arrow on the right to move to the second page, then select "Internet," followed by "Connection Settings." Last, select your connection file, and the select "Connection test."
  • Create a new connection file.
  • Set up a new connection file making sure the Wii is attempting to connect to the appropriate wireless network and is receiving a strong wireless signal. How to Wirelessly Connect the Wii to the Internet Nintendo Support
    - Matt
Jan 20, 2014 | Nintendo Wii Console
Error 50299
Error Code: 52099It appears that your Wii console is unable to obtain an IP address from your wireless network. Our experience has shown that this error message is solved by performing a manual setup on the Wii. Please follow these steps:
The first thing you'll need to do is find out what IP address range you should be using. To do this:
  1. Click the "Start" button in the lower left-hand corner of your computer.
  2. Next, you will need to access the command prompt. To do this:
    • Windows XP users click "Run."
    • Windows Vista and Windows 7 users click inside the search bar.
  3. Type "cmd" into the box and press Enter.
  4. Type "IPCONFIG/ALL" and press Enter. The IP address, Subnet Mask, Default Gateway, and DNS servers of the PC will be displayed.
The IP address you are going to assign to the Wii must be 10 digits higher than the PC's. (e.g., 192.168.1.100 becomes 192.168.1.110). The Wii and PC must have different IP addresses.
Enter in the exact same values for your Subnet Mask, Default Gateway, Primary DNS and Secondary DNS. They must be the same for your Wii and for your PC.
  1. Click here to go to our Wireless Router Configuration page.
  2. Use the drop-down box on the left to select, if available, your router manufacturer.
  3. Click on your router's model number, if available.
  4. Read any "special notes" at the top of the router's page. Many issues can be solved by changing the settings found in the Special Notes. Follow the instructions and test the connection.
You will now need to manually assign this new IP address to your Wii. For step-by-step instructions on how to do this on your Wii, pleaseclick here.
Check Nintendo's router info for special notes, if available, for your router.
If you try these steps and you get a different Error Code, please review the values that you entered carefully, since an incorrect manual setup will cause another Error Code to appear. If the 52000 Error Code persists, than the problem may be caused by a basic setting in your router such as transmission rate. Please carefully read the instructions below:
If you are still unable to connect, please call 1-800-255-3700 in the USA or Canada for more information.
Aug 14, 2012 | Nintendo Wii Console
Recieved error code 50299 when accessing Netflix
The Wii wants to do a system update, but isn't letting you connect because your Wii is not updated. Catch 22.... Anyway, go to the connection settings it prompts you to, choose your connection one, save, then test. Should work now, and will prompt you to do a system update.
Mar 04, 2012 | Nintendo Wii Console
I'm trying to connect my Wii to the internet with the "Nintendo Lan Adaptor". I plug the ethernet cable at the back of my cable modem (motorola SB5100). I get errors 51420, 52020 and 50299 Help...
Sep 13, 2010 | Nintendo Wii Console
The microphone is not working. an error 50299 appears. Please help.
This error is caused by not configuring the internet connection settings of the Wii console.
To solve thie error: Complete the setup process to connect your Wii to your home network.
Dec 28, 2009 | Nintendo Activision Guitar Hero World Tour...
I cant connect my wii to my wi-fi
are you trying to play via wireless internet? if so you might not be getting a strong signal. if possible buy a ethernet to usb adabter for the wii. you can get them at bestbuy or anyother major electronic store. but you usually cant find them at walmart. this will guarantee a strong internet conection
Jul 31, 2009 | Nintendo Activision Guitar Hero World Tour...
Wii won't connect to Internet. Error code is 051330
When you are not able to connect with Internet from Your Wii, means there is something wrong with the settings. You may go to Wii Fix Guide and check out the guide available there, This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge.
Dec 25, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
3,955 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
