Question about Baby Gear
Urban Escape 3 Wheel stroller and Capsule - Baby Gear
  • 20 Answers
SOURCE: problem with front wheel of jane 3-wheeler stroller
The front wheel swivel has become a problem with some strollers that are a little longer than the standard three wheel stroller. This has been happening with the new Phil & Ted's Vibe as well.
This can be approached in a few different ways. The easiest is to take the wheel off completely and properly lube the connection pieces. You can use a standard axle grease, or WD40 if you have some in your home. When the tire is properly lubed, re-attach it. This should take care of the problem.
If that does not work, the wheel's inner tube might be/have been over-inflated. When this occurrs, a part of the tube bubbles and causes the wheel to wobble while being pushed. Deflate the tire slightly and see if this helps. If the tube has been over-inflated for some time, it may be necessairy to completely replace the tube - you can do this at most bike shops that sell replacement tubes.
If this does not stop the tire from wobbling, please feel free to contact us anytime.
strollerinfo@gmail.com
StrollerInfo
www.StrollerInfo.com
Posted on Oct 02, 2008
  • 37 Answers
SOURCE: new wheel in instep duo stroller needed (BACK WHEEL)
I should go to he Pram Shop where you bought it from, if it has closed down go to a Mothercare Shop or similar Pram Shop. They will be able to get you the information you need.
Posted on Apr 08, 2009
  • 12 Answers
SOURCE: Jeep 3-Wheel Stroller Liberty
email them. they should send one for free
Posted on Jul 13, 2009
  • 419 Answers
SOURCE: urban mountain buggy double stroller
THe Mountain Buggy is very simple to fold. Level with the footrest, there is a black plastic button (either side), these simply push toward the back of the pram and hey presto! The pram will collapse. To make this as small as possible, keep the front two heels on swivel so that they tuck neatly underneath and the handle bar adjusted to the lowest position.
See this link to help a little more.
http://www.mountainbuggy.com/customer-support/how-to-use/
I hope this helps.
Posted on Sep 14, 2009
SOURCE: need parent's tray for a 2003 Jeep Liberty Urban Terrain Stroller
need shade cover for front seat on tandem stroller ! also tray for back seat !
Posted on Aug 24, 2010
Where can I get replacement rear wheels for Mountain Buggy Urban pram?
check out
http://www.pushchairs.co.uk/acatalog/miscellaneous_spares.html
Dec 08, 2011 | Mountain Buggy Urban Single Stroller
FLAT WASHER THAT GOES ON THE END OF THE FRONT OF THE STROLLER WHEEL, THAT HOLDS THE WHEEL ON SO YOU CAN PUT A BOLT ON.
Washer has a tag to help lock the wheel on,macnutz_15.jpgThese people can help http://www.kolcraft.com/customer-service/contact-kolcraft/
Nov 16, 2010 | Kolcraft Jeep Liberty Limited Urban...
Cant get wheel on - Mountain Buggy Urban Elite
I believe this company http://www.outnabout.co.uk/ might be able to help, they sell parts to Mountain Buggy's and other strollers.
Apr 05, 2010 | Mountain Buggy Urban Single Stroller
Need parent's tray for a 2003 Jeep Liberty Urban Terrain Stroller
Apr 08, 2009 | Kolcraft Jeep Liberty Limited Urban...
Urban Jungle: push very heavy, squeaks
Alex,
You may try removing the wheels, cleaning all dirt and debris from the axel and the wheel, coating both the axel and inside of the wheel with silicone spray. If the axel is badly pitted from the dirt rubbing against it, you can use some emery cloth to smooth it back out before putting the wheel back on.
Mar 27, 2009 | Mountain Buggy Urban Single Stroller
Jeep stroller wheels
yes u cxan order a new one go to any stroller shop or outlet they have them there or can help you
Sep 03, 2008 | Jeep Liberty Limited XT Urban Earth Jogger
Broken wheel axle
go to kolcraft.com and pick the contact us link and that will give you a number they are real good with parts.
Aug 19, 2008 | Jeep Liberty Limited XT Urban Earth Jogger
How to take off a tire on a Jeep Liberty Ubran Terrain Stroller
If you have the model with the inflatable bike tire as a wheel, then there should be a metal locking pin wrapped around the plastic top of the wheel, you should be able to see the end of the pin sticking out (about a half inch to an inch) right below the plastic part that is at the end of the wheel. Use a pair of needle nose pliers and pull that metal pin strait off, it is held on with a pinch grip, so you don't need to twist (that could bend your pin). After the metal pin comes off, you can just take the wheel off. Then to put it back on just place the wheel back on the metal wheel bar and replace the locking pin by just pushing it on, no pliers needed for this part.
Apr 29, 2008 | Kolcraft Jeep Liberty Limited Urban...
Baby Gear Logo
125 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
