Question about Whirlpool 24 in. ADP5962 Free-standing Dishwasher
Flashing green light and then move to END cycle
The machine flashes the green light on the button when pressed on a program, and then after a few seconds moves to the END cycle and sits there for a while before stopping. I suspect the machine may not be filling with water but I'm not sure. I'm competent enough with a screwdriver and I've got a degree in computing/electronics so I can probably tackle anything not too specialist in nature. (1 question before tackling anything involving a stripdown I always like to ask is) What is the best way to get access to the part in question if it transpires that I need to do so. You guys can save me time and energy stripping the thing down by giving a pointer to the most efficient access :-) For example the water inlet is tight to access through the snap-off cover plate so do I remove the back plate in total and if so what is the quickest way Thanks in anticipation Best wishes Chris
    Problem Solver:
  • 14 Answers
Hiya.sounds like the base of your is full of water due to a leak..disconnect from the electrical supply.and lay the machine on its back.you will probably get a wet floor at this point.that proves the base is full of water.ther are two t25 torx screws onthe front of the base plate.remove these an slide the base forward off of the two plastic clips.look for water lines leading into the base.repair the leak and replace the parts.alternatively,if the light flashes four times,a part called an ntc has failed.this is the part that detects the water temp..when 1st switched on,the appliance runs a diagnostic check.it may detect this is faulty.
Posted on Dec 29, 2007
    Problem Solver:
  • 17 Answers
The Dishwasher you are asking about is from and produced for Europe the only info I have is about US Models Sorry
Posted on Dec 03, 2007
SOURCE:
The green start light is flashing and won't start again when pressed.
Cycle thru the wash settings. Do all the lights work for the different settings?
Nov 25, 2012 | Washing Machines
My epson tx700 printer dispaly ink pad at end of life and printer not start
A fix from a forum:
Procedure 1 We found this procedure to work for the Stylus Photo 1270 type printer, and understand that it also works for the 870 range and even earlier models like the Stylus Color 740. The error is indicated on these printers by all four lights on the printer flashing. Even if you press the power switch on the printer, the lights continue to flash, and the printer does not turn off!
  1. Turn off your printer, ensuring that the print head is at it's home location and locked in place as normal;
  2. Power off the printer at the wall or by removing the power cable, for at least 20 seconds;
  3. When you restore power to the printer at the wall socket or by reinserting the cable, if the lights come back on straight away, the printer's power switch was 'on' - switch it off and return to step 1;
  4. Hold down the paper-feed button and the button with the ink-drops next to it, and then turn on the printer, still holding the buttons down;
  5. When the paper-out LED flashes, release the buttons;
  6. Press and hold the Cleaning button, until several lights flash - this will take a few seconds (i.e. then release the button);
  7. The printer will now attempt to reset, including resetting the EEPROM memory and running a short (about 10 seconds) cleaning cycle.
Procedure 2
  2. Hold down the paper feed button only;
  3. Turn on the printer;
  4. As the paper feed light starts flashing, release the button;
  5. Immediately hold down the ink-drops button for some 10-20 seconds or until the printer springs into life;
  6. Allow printer to complete it's processing, then turn off for a few seconds, and back on again for a newly working printer!
Procedure 3 - for 1290 and possibly 890 printers 1290 printer with green (power / data) and red (ink / paper feed) lights flashing alternately:
  1. Switch off printer with panel switch;
  2. Switch off printer at mains switch - leave off for 20+ seconds;
  3. Hold down roll feed and sheet feed buttons;
  4. Switch on at mains;
  5. Switch on at printer panel;
  6. Continue to hold down roll and sheet feed buttons until both green and red lights flash together in synchronisation, not alternately;
  7. Switch printer off and then, after a few seconds, on again at mains switch;
  8. When red and green lights are both flashing in synchronisation, release the roll and sheet feed buttons;
  9. Press and hold down the ROLL FEED button (the one at the extreme left) and keep it down until the machine finishes whirring, cleaning etc and the green light comes on steady;
  10. Release the roll feed button and all should be well.
Apr 25, 2011 | Epson Printer
I have an Electrolux EWD1477. I have been away for four months and I'm having problems with it. I set to do the quickwash30 program and press start, you hear the clicks, it might put some water in then...
My EWD1477 was doing this a year ago and I fixed it. Then it started doing it again a month ago and I seem to have cleared it again.
Firstly, remove the drain hose from where it is inserted into a laundry sink hole to make sure it is not blocked or sealed in with sludge.
Secondly, make sure the machine is empty of water and clothes and then turn the machine to off with the Program Selector Dial. Then turn off the power at the socket and remove the power plug and leave for five minutes.
Step 1: put the plug back in and turn the power back on.
Step 2: turn the selector switch to the right (Whites/Intensive). The green light of the Start/Pause button should be flashing and the green lights on for Prewash/wash, Rinses and Spinning. Don't press any other buttons or change any other settings.
Step 3: press the Start/Pause button and wait for the machine to empty any excess water. Press it again immediately after you hear water flowing into the machine OR two audible clicks. The machine is now in pause mode with the green light of the Start/Pause button flashing. Only the green light on the Prewash/Wash button should be on. Leave it in pause mode for 30 minutes and then press the Start/Pause button to recommence the cycle.
Step 4: If the Start/Pause button begins flashing, water stops flowing into the machine and the three green lights mentioned above are back on, turn the Program Selector Dial back to off, wait 10 seconds, and repeat the process above.
Step 5: If when you then turn the Program Selector Dial to Whites/Intensive and hear the two audible clicks, immediately press the Start/Pause button to set the machine in pause mode. Wait 30 minutes. Then press the Start/Pause button to recommence the cycle.
Hopefully the cycle will run without a problem.
Mar 26, 2011 | Electrolux Washing Machines
The ink pads are at the end if their service life.
Depending on what type of printer you have:
Procedure 2
Mar 13, 2011 | Epson Office Equipment & Supplies
It's STUCK
Hi
The light is flashing due to the door lock error. The door lock is activated as the machine experienced an error or was stopped in middle of a cycle. Or the door was being pulled while the machine was running a cycle. Try unplugging your washer and restart the washer to check if you are still getting the same blinking light. If error is still not resolved then start the rinse/spin cycle & stop the cycle, now press and hold the cancel button for 5-10 seconds. However, if you are still not able to get the door open then you'll need to open the door manually by disassembling the washer. Please post back for any further assistance.
Daniel
Jul 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Flashing green ''clean'' light and will not start a wash cycle.
the computer senced that the heater did not work last cycle. Push your sani clean, energy saver button s back and fourth a few times. It will run a self diag cycle. let it run for a few min. If it happens again your heater may have burned out.
Nov 11, 2009 | Kenmore Elite 45986 Front Load Washer
Dishwasher (Whirlpool ADP 952) not working
I have a whirlpool ADP 952 and the start button is flashing and it won't work
May 25, 2009 | Dishwashers
Washing machine door locked indesit WD12X
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Apr 01, 2009 | Washing Machines
Not washing
helen going by what you are saying i would say its the program cycle switch needs replacing,adrian
Jan 13, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Program light and 12:00 are flashing, no buttons work
Press program set once, then switch to clock mode to set time.
Sep 27, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Whirlpool 24 in. ADP5962 Free-standing Dishwasher Logo
187 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
