Question about Goodman GMS90703BXA Heater
GMP150-5 The heater will not go on the fuse on the board keeps popping
    Problem Solver:
  • 22 Answers
You have a low voltage issue, check for any bare wires at stat or unit, have you done any home repairs " such as hang pictures and so on" sometimes homeowners nick the 24v lines which can cause that porblem.
Posted on Oct 28, 2008
No heat
could be a few different things,bad heater,popped thermal fuse or the high limit on the heater box,if the dryer hasn't been taken apart and cleaned out in a long time and it should be done once a year if gas and 18 months if electric,clean out the cabinet where the motor is,clean out the duct that the lint filter slides into and blow out the vent line,if the air isn't moving and it's been taking longer to dry your clothes most likely you popped the thermal fuse,you have to clean it out or the fuse will keep popping and it's a none resetting fuse or the high limit thermostat popped on the heater box,both are from the dryer running to hot and either the thermal fuse or the high limit will pop as a safety.you'll need to unplug the dryer and get in there with a meter to see what part is bad,remove the bottom panel,pull out the lint filter and then remove the metal duct that the filter slides into and you can read out the parts,you have to remove at least one of the wires on the part you check,on top of the blower wheel housing you'll see a white piece with two wires going to it,pull off one wire and check it with your meter,if that's good go to the right and check the heater and the t-stat in the back on the heater box,hope this helps
Feb 09, 2014 | Whirlpool Dryers
The fuse keeps blowing inside the edenpure heater
Generally speaking, fuses blow when too much current passes through them. Typically this happens when there is a short circuit some place. a connector or bare spot in a wire touching ground, a bad component on a circuit board, a bit of conductive debris on a circuit board all can cause shorts. If the fuse blows, it's doing its job to protect you from a problem you have yet to find.
Dec 01, 2013 | EDENPURE USA1000 Infrared Heater
No power at control board
Check the fuse on the circuit board its just like a car fuse. If this is popped you have a short in you low voltage usually at the contactor coil in side the outdoor unit. It could also be a tripped breaker check that also. If this helps please rate me and do a testimonial.
Jun 03, 2011 | Goodman GMS90703BXA Heater
The fuse on my circuit board keeps blowing after a thunder storm. Need to replace the entire circuit board for my RS8 system. Any sugestions on where I can purchase just the circuit board? Mike
unplug all the aux plugs but mark them replace fuse turn on if it still blows need a new board if not plug in auxs 1 at a time till it pops then check out that aux for shorts sometimes the relays short out
Mar 17, 2011 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
The fridge is blowing the 12 volt fuse as soon as I power up the motor home, The fridge is turned off and it still blows the fuse, I tried to undo the 2 wires that go to the 12 volt block on the fridge and...
Unplug the wire located at terminal J4 (12v positive) on the control board, and see if you are still popping fuses. If so, then the fault lies between the wire you just removed and the fuse that keeps blowing.
If the fuse holds, and blows when you plug the wire back onto J4 terminal, then unplug the wire(s) at J2. These go to your door heater (used in humid conditions to remove condensation), as well as the interior light. The switch for the door heater is located on front panel, or is at the top edge of the freezer compartment with door open. It is not unusual for this switch to have issues since it gets chilled and moisture condenses on it. If unplugging the wires at J2 allows the fuse to hold, you probably got a shorted heater or bad heater switch. But, pull the lens off the interior light, and check the contacts there as well.
If the fuse still blows with J2 removed, then unplug the connector in the top left corner of the control board. This goes to the control panel on the inside of the fridge. If the fuse blows, replace the control board. If the fuse holds, the replace the control panel.
Jul 13, 2010 | Dometic RM2652 Refrigerator
Circuit board fuse keeps poping
Traced wires and found the wires to the humidifer were the cuprits. I beleive the solenoid may be no good. After disconnecting the wires to the humidifier, A/C and Heat are working fine now .
May 28, 2009 | Goodman GMS807034ANA Heater
Thermal fuse keeps blowing
Mr. Larry (guru?)
The thermal fuse is just that It doesn't protect the circuit from over current although it certainly can open in that case. It is there to protect the board from overheating , thus the term thermal. The dishwasher could be allowing the water to heat too hot or the water heater in the home is turned up too much. The heater could also be shorted to case thus allowing it to be on even though the control is not calling for it especially if the polarity is incorrect to the dishwasher or the relay on the board could be welded closed so that the heater can't turn off even though the thermostat is satisfied. The best thing is to get a person who can check these things. You don't necessarily need to change the board with a fuse. I have changed many fuses with no other problems and verified that the machine was still working years later. sometimes the fuse just blows!
Dec 02, 2008 | Dishwashers
Goodman Gmp150-5
sorry if you disconnect all the low volt wires from the board and it still blows fuses, th board is gone.
Oct 31, 2008 | Goodman GMS90703BXA Heater
Goodman GMS90703BXA Heater Logo
63 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
