Question about GE (PSS26MSRSS) Side by Side Refrigerator
Electrical smell Water started shooting from the door dispenser on it's own while we were gone and flooded the floor, so we turned the water off to the fridge and cleaned up the mess, then about 3:30 in the morning with the water supply still off the ice dispenser decided to make a mess also, and shot ice cubes out in the floor before we could wake up to unplug the stupid thing, when plugged back up we now have an electrical smell, my wife thinks that it is possessed.
Water wont shut off whirlpool ghw9100lw2 left door open between loads and water ran flooding floor. Came from inside washer and out open door?
This is almost certainly the inlet valve gone bad not shutting off the water, just unplug appliance to confirm if water is still coming in if so just replace the valve
TK
Jan 30, 2017 | Whirlpool Washing Machines
My whirlpool fridge water dispenser won't dispense water but it shoots out a burst of water each time the door is opened even though I have the dispenser in the lock position.
I'd look for a pinched water tube where it enters the freezer door at the hinge. This would happen when you called for water, but got none because the tubing was pinched. Then, when you open the door and the tube flexes the pressure would be relieved and water would shower out of the dispenser (or on the floor if the tube was damaged.)
Oct 27, 2016 | Whirlpool Refrigerators
The little door that opens to let water into machine(front loader) does not open. Why?
Links to sears parts direct. First link is to download manual, see page 11 Clean dispenser.
NFW7200TW10 AMANA RESIDENTIAL WASHER Manual
Second link is to parts diagram. images can be changed in size.
Second image from left is the dispenser.
AMANA Residential Washer Parts Model NFW7200TW10
Sears offers trouble shooting help also look for trouble shooting in user manual.
Sep 21, 2014 | Amana Front Load Washing Machine Washer...
Refrigerator control panel failure, causing dispenser to run for hours, filling refrigerator with burned plastic smell
I have a artic and it has a motherboard in it. This is the most common problem.They are easy to replace and you can get one on the internet pretty cheap.First look at the mobo for any burnt spots on it. If so then get the # off the board and search for it.
Mar 16, 2014 | GE Refrigerators
My whirlpool suddenly stopped dispensing water.
most fridges stop dispensing water when you open the door. Find the door switch and make sure fridge interior light goes on/off when you manually press door switch. This would show you that the door switch was faulty.
If the water connection to the appliance is one of those watts flood-safe water lines, it may have stuck shut. I've seen this happen when the house water pressure is too high.
Does it still make ice?
If so, then the water connection is good, and either the switch in the water dispenser has failed or the water shutoff valve for the water dispenser has gone bad.
Some models have a problem with the water line getting frozen, such that simply leaving the light on in the water dispenser compartment overnight and/or manually defrosting the unit can get it working again.
Nov 02, 2009 | Refrigerators
Ice-maker problem
if the water runs constantly when you turn the water on its your valve but if it does it periodacally it probably your icemaker
Apr 29, 2009 | Maytag MSD2756G Side by Side Refrigerator
Smelly water dispensed from ge profile refrigerator
flush the water tank put a glass press for water and keep flushing on till smell gone
Mar 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice and Water not dispensing. Light button not working
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Apr 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Dec 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
32 people viewed this question
Top Refrigerators Experts
KJ4QOB
Jim Akins
rodney bartholomew
Level 1 Expert
