My konica 2223 copy lamp is dim resulting to paper jams and blank copies, im just repalce my Power supply board
Im just replaced my Power supply board and P51 error was corrected
    Problem Solver:
  • 14 Answers
Check your newly installed power supply board input rating if the same with the old one if yes P51 error common for front door open and can be cleared by closing the front door. Door lock actually connect to the interlock switch at the back beside power supply unit sometimes we just clean connectors if not replace power supply. Now if the light scan with very low intensity the result would be darker and probably will cause you paper jam at the fusing/heater unit but, if blank copies the light intensity is to high. you may adjust or correct it by CVR adjustment/Light intensity adjustment " go to 36 mode off machine hold 3 and 6 while power on release 3&6 after display reads CC, enter address 9-0, start, p- select (0/30 darker 35/55 normal- 60/90 lighter) this adjustment may vary depending on drum coating and optical adjustment/cleaning. I suggest clean first all mirrors before you do it.Hope this may help you sold the problem.
Posted on Feb 20, 2012
4 Suggested Answers
jqsababa967
  • 145 Answers
SOURCE: Konica 2223 J72 alarm
ST216, J72.
Solution:
PROBABLE CAUSES:
1. Paper is caught on the flapper assembly (p/n 12TK-4510). The indexer is not adjusted high enough to have the flapper correctly positioned. This symptom usually occurs after the last copy enters the top bin. To properly adjust the indexer position, perform the following:
a. Power copier OFF.
b. Remove the front and rear covers.
c. On the sorter CB, set dipswitches SW1-1, SW1-2 and SW1-3 to the ON position.
d. Ensure both sorter interlocks are closed (PS208 and MS201).
e. On the sorter CB, press and hold PSW1 while powering ON the main body (code 70-00 will occur; this is normal).
f. Release PSW1, then press and release it one time. The indexer will lower to the adjustment position (approximately at the 4th bin).
g. Open the conveyance section.
h. Insert the indexer positioning shaft adjustment tool (p/n 7050K0020) into the access hole on the rear side frame of the sorter. The hole is located to the right of the conveyance door interlock switch (MS201). The shaft should be positioned under the indexer and into another hole in the front side frame.
Note: The indexer positioning tool is the same tool used for optics alignment on the 7050.
i. Rotate the indexer motor encoder plate to lower the indexer until it contacts the adjustment shaft.
j. Loosen the fixed screw located on the front side of the indexer.
k. Slide the front of the indexer up or down until it is positioned parallel with the adjustment shaft. Retighten the indexer fixing screw.
l. Loosen the screw that secures the PS203 4-slot encoder plate and adjust the 4-slot encoder plate until LED 1 is lit. Retighten the encoder plate.
Note: Either or both interlock sensor/switch (PS208/MS201) must be opened during this adjustment.
m. Remove the indexer positioning shaft and reset all 3 SW1 switches to the OFF position.
n. Power copier OFF/ON to return to the normal mode.
2. The sorter top front frame is slightly bent and not parallel with the rear top frame. This, in turn, allows the top cover to be out of position and bind the flapper gate (p/n 12TK-4510). This gate should normally open when the indexer lowers to bin 2, allowing the paper to enter the bins.
Reform the sorter top frame so the top cover, when mounted, does not bind the movement of the flapper gate.
3. Mylar guides are installed on the exit unit of the main body.
Remove the mylar exit guides when a sorter is installed. The guides help eliminate static when paper exits into the catch tray. When a sorter is installed, the guides can cause exit misfeeding.
4. The flag for the sorter entrance sensor (PS201) is stuck on the guide plate below the sensor. This happens when the top of the sorter is lifted as it is moved away from the copier.
Lift the top of the sorter and place the flag back into its proper position. Instruct the operators not to lift the top of the sorter when it is moved.
HOPE THAT HELP
THIS IS ONLY FOR ST216 MODEL SORTER
Posted on Oct 17, 2008
  • 51 Answers
SOURCE: f35 error code
Warm-up was not completed
within a specified period from
the start of warm-up.
• The low fixing temperature
fault detection software is
activated.
The fixing temperature at the
end of warm-up is less than the
specified temperature.
activated.
The fixing lamp does not turn
OFF within the specified period.
SOLUTION
Rewrite the data at
address “P47” in the
25 mode to “0”.
(1) Turn the main switch OFF.
(2) While pressing the numerical keys 2 and 5 of the copy
quantity setting button, turn the main switch ON. This
will enable the 25 Mode. The 25 Mode is used exclusively
to rewrite in memory and, therefore, does not
support normal copy operations.
Posted on Aug 31, 2009
  • 3 Answers
SOURCE: frequent paper jams with my Konica 2223 photocopier
I believe u have cleaned all the optics right? if yes then,check if ur dev. is over toned run a few copies with flat top cover open
if not then change the dev and see if it works
Posted on Nov 07, 2009
I have an HP 4345 MFP that's printing nothing but blank pages when copying, sending a print job to the printer. Im not even able to print the config page. All comes out blank. Does anyone have any idea...
if you are tec guy?
do half test page test find any image created on catridge drum, if no image found then
Check laser scanner assembly shutter fully operating or not while catride access unit closed, if unable to check, remove the shutter from laser scanner assm
Increase toner density
set factory settings,
If image on drum no print on paper, check transfer roller, contacts, if dirty replace T.roller, no result replace Power supply board..
Sep 09, 2011 | HP LaserJet 4345mfp Printer
I have an old Konica Minolta bizhub 180 and am trying to make a copy on an 18x11 inch piece of paper with no success. Can anyone help me out?
The maximum paper size for the Bizhub 180 was 11"X17". Using a larger paper size will result in either incomplete copy or a paper jam every time.
Good Luck and Thank You for using Fixya.
Oct 14, 2010 | Konica Minolta bizhub 180 All-In-One...
I Have konica 7130 i can t Made L detection The
Code 0006 TCSB (toner control sensor board) output signal D/A conversion error To Clear SW2 (sub power switch) OFF/ON Problem Solutions, Replace 2? PRDB (printer drive board) 1? TCSB (toner control sensor board)
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aug 04, 2009 | Konica Minolta Di1610 Copier
F35 error code
activated.
activated.
SOLUTION
Rewrite the data at
25 mode to “0”.
Apr 21, 2009 | Konica Minolta Office Equipment & Supplies
Yellow doesn't print
Try this 1.Try placing sheet of paper on copy board, and run many copies . I ran 25x12 times - still blanks coming out. Run head clean after about each 50 sheets. Persevere
Mar 28, 2009 | HP Photosmart D7260 Printer
Frequent paper jams with my Konica 2223 photocopier
I wish I could help you, You need to call for service for your copier. An authorized dealer or Konica minolta branch service in your area. You might need a fuser unit that the upper separating claws disloge or broken, exit paper detect actuator is broken or disloged, or you need a new developer.
Feb 05, 2009 | Konica Minolta DiALTA Di200 Copier
On the konica 2223 when printing it leaves a dark thick line down the center of the paper.
Konica 2223 copiers are analog meaning the image that comes out on copies is a direct reflection off of the copy. Dirty mirrors in the optic section can cause a dark band, but it is more of a shading effect. Drum assembly's can be removed.The image drum has a cleaning section that uses a urethane blade to clean excess toner off of the drum after the copy passes through.It is simply called a "Cleaning Blade" these blades can be ordered through most online copier part stores. Last but not least is the "Upper Fuser Roller". this is the hot roller the paper passes through to "set" the toner to the paper. These are coated with teflon to prevent toner from sticking to them. They have "seperator claws" that keep the paper from adhereing to the roller, and they sometimes gouge the teflon. this exposes bare metal, and the toner can come off of the copies and stick to the roller.
Jan 16, 2009 | Office Equipment & Supplies
I have a Konica 2223 copier - wont print on edges
check all edge settings .f28 is code for charger corona just clean corona assembly with cerosene oil and change corona wire with new one.
Dec 16, 2008 | Office Equipment & Supplies
44 people viewed this question
k24674
jasbo
jasbo
