Question about AEG Lavamat 74640 Front Load Washer
AEG 76639 E20 error - AEG Lavamat 74640 Front Load Washer
SOURCE: AEG 72640 update
e20 means cant drain i usually found itsufficient to clean filter and restart but this time i blew down waste pipe /drain,cancelled program and reset
Posted on Feb 10, 2009
  • 44 Answers
SOURCE: AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Posted on Mar 21, 2009
SOURCE: AEG 74800
We had something like this a whlie back - I'm pretty sure it indicated a water supply problem (we had low water pressure)
Posted on Jun 01, 2009
  • 457 Answers
SOURCE: AEG oko Diplomat E Update
Error code E20 indicates that water cannot be pumped out of the machine. Possible causes:
  1. Sieve filter is blocked. Open the sieve lid, (lower right of machine) and clean.
  2. Drain tube bent or blocked. Check for bends and straighten the tube, open hose band clips and check inside for objects or dirt.
  3. Some small object (coin, children's toy, ...) blocks the drain pump. Pump needs to be dismantled and cleaned.
#1 and #2 you should be able to do yourself. With a little aptitude for repairs, you can do the fix #3 yourself, too. If you don't trust yourself to get all parts back together, let a service technician do the repair for you.
Posted on Dec 23, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: AEG OKO LAVAMAT DIPLOMAT E UPDATE, FRONT LOADER.
Sorry to read about your problem, I hope this helps you out.
Your E20 code
This particular code is used when the machine detects a pump problem or water draining problem (failure to properly pump all the water off in the designated time). In this case, the fault would occur
just before attempting to spin.
Check your filter which is accessible from the bottom of the machine.
Sometimes intermittent FALSE errors like this can come up if there are high resistance (oxidised) contacts between the ribbon cable that goes from the POWER CARD to the facia panel electronics. To fix that sort of problem, remove any retaining clips from the end that plugs into the facia panel, remove and replug the cable end a few times. This gives the contacts a "wipe-clean" action and can remove the oxide. Obviously if the cable or contacts are badly corroded or burnt, then replace it.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Remove housing
How to replace a washing machine door seal on an AEG ...
? 5:38
https://www.youtube.com/watch?v=KlAXmnKJQ9k
Aug 17, 2009 - Uploaded by eSpares
This video will show you how to remove and replace the door seal. ... Do you have video repair instructions for AEG washing machine OkO ...
AEG removing drum Washing Machines Questions ... - Fixya
www.fixya.com/tags/removing_drum/washing_machines/aeg
AEG washing machines removing drum related questions and answers. ... into thehousing and get the object out. well as we say in my town you got a "toston" .
Aeg/electrolux lavamat 76810 waschmaschine E20 - YouTube? 0:28https://www.youtube.com/watch?v=1WX5rKxFrXsMay 3, 2015 - Uploaded by jusuf jerkovicAeg/electrolux lavamat 76810 waschmaschine E20 ... front load washer from not draining -- washing machine error code e20 - Duration: 2:52.washing machine error code e20 - YouTube? 2:52https://www.youtube.com/watch?v=2B7FxovrxKoOct 25, 2014 - Uploaded by teppichkopfSave some money and fix it yourself. Totally bizarre how stuff gets stuck in the drain!
Dec 21, 2015 | AEG Washing Machines
How can I correct error code 25 on an AEG OK-LAVAMAT 74640 update washing machine mean?
Family error code "E20" means difficulties in draining, but I never heard for error code E25 on this model. Could be : E21, E23 and E24 error code.
Dado
Aug 24, 2014 | AEG Washing Machines
Aeg tumble dryer e20 error code won't start
E20 is a master code for two sub-codes E21 and E22, both of which need taking a look at the electronic board. Best to call the service engineer.
Jun 28, 2014 | Washing Machines
Washing cycle does not complete and I get error E20 with beeps
The E20 error means that the thermistor resistance has drifted or the temperature scanning sequence is incorrect. The ambient temperature could be below freezing.
Check the thermistor and associated wiiring for correct resistance and operation and replace if required.
Dec 28, 2009 | AEG Lavamat 72640 Front Load Washer
Hi
regards
Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG 74800
Dec 21, 2008 | AEG L74800 Front Load Washer
AEG 72640 update
Jan 13, 2008 | AEG Lavamat 72640 Front Load Washer
Error 20 AEG washer dryer
On 40c wash hit E20 error so moved programme onto long spin and all ok!
Jan 09, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat 74640 Front Load Washer Logo
47 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
