Question about Audiovox BA200 Car Subwoofer
Lose wire with 6Wires connector... need diagrams of pin out
Hi ! i lose wire with 6wires connector. I try to find diagrams of pin out, but impossible, if someone of you can tell me wich wire is connected where in the connector of the Sub amp. Thanks a lot !
  • iqshop Jan 18, 2008
    hello all , i have the same problem with this subwoofer but i cant imagine the pin scheme with this discription
    ( look for enclosure , the up side down etc )
    my friend inferno77
    can you post a scheme the way we must look the 6 pin plz ?
  • 6 Answers
(There are different versions of the ba-200, so I'm assuming they al use the same wiring/pinout...) if you look at the amp on the enclosure(right-side up... so the writin goes left->right): The top left pin is #1, beside it is #2, then #3. The bottom left pin is #4, beside it is #5, then #6. #1 Right speaker positive input #2 Empty #3 12 Volt Constant Power #4 Left speaker positive input #5 Remote turn on / Acc power input #6 Ground Now there's supposed to be a 15-amp fuse on pin #3 (12v constan power).
Posted on Jul 27, 2007
Instrument cluster is not working properly
Check for lose terminal pins at the instrument cluster connector . sounds like lose connection or lose ground wire !
Jun 18, 2015 | Cars & Trucks
Looking all over the internet,why cant i get the diagram for the wires? (telling what each wire goes to)
It's the plug connector pins that you use not the colours to tell you what pin does what and connect them to the corresponding wire in your vehicle
Mar 08, 2015 | Kenwood Kdc-mp745u
How do I remove alarm brain box from wiring on a
"I bypassed the immobilizer circuit only on my alarm module (which is really tedious). Bypassing the whole
module is possible (and little easier), but you will lose the use of the remotes and the ability to arm the alarm.
The alarm module in my '97 900 SETC is located under the carpet, below the driver's power seat switches (a
pain to get at).
If you want to bypass the module completely:
1. Disconnect the battery (make sure you know the radio code-if needed)
2. Unplug the connector from alarm module and remove module from car
3. Install a wire jumper between pin 8 and pin 20 in the connector
4. Install a wire jumper between pin 9 and pin 21 in the connector
5. Install a wire jumper between pin 10 and pin 22 in the connector
6. Wrap securely with electrical tape
If you want to bypass the immobilizer circuit only:
2. Unplug the connector from the alarm module
3. Cut the following wires from the back of the connector and splice together as follows (Don't cut the wires too
close to the connector, because someday down the road you may want install a new module, so you'll have to
reverse this process):
4. Cut the wires to pin 8 and pin 20 and splice together w/ wire nut
5. Cut the wires to pin 9 and pin 21 and splice together w/ wire nut
6. Cut the wires to pin 10 and pin 22 and splice together w/ wire nut
7. Secure all with electrical tape
8. Reconnect the connector to the module
Not knowing the details of your problem, please be aware that this may, or may not, solve it. Good luck and let
me know how you make out."
Oct 02, 2014 | 1997 Saab 900
Brought LED back light the wires black,red,yellow, the old back light on my bike as two bulbs with six wires 2 x red 2 x blue 2 x black n yellow.three too each bulb when i connect my new light too bike...
Hi, firstly dont think for a miniute that the black wire on your new light is the earth, using the battery as a power source put one of the wires to earth and the other to live, as the led light will only work if the power is conected to the rite pole it is important to establish wich of the new wires is earth, you may have to swap them around to get the correct order, and then conect each of the other wires to the batt poss to check the lite works,when you are happy you have the correct order you can fit it to the bike, on the kawasaki blk and yellow is earth , although you have 6wires they are only 3wires in the loom wich double up to 6 for the 2 bulbs in the lite unit, you can leave 1 of eah colour disconected,
Mar 12, 2011 | kawasaki VN 750 Vulcan Motorcycles
1999 chevy silverado windshield wipers were working intermittently and now won't work at all. I metered the connector with it unplugged from the wiper motor and I had a change of state with all positions...
https://s1.postimg.org/482qy9l14v/wiper.jpg
Click on the link. I always check voltage and ground, w/o ground also, it won't work. The top wires in diagram are voltage depending on what your trying to do? The black wire is ground. You can check ground by also using a test light. One end of test light touches battery voltage, the other end touches black wire terminal. If the lite comes on, the ground is good enough to work the test lite.
Oct 05, 2017 | 1999 Chevrolet Silverado 1500
I am trying to find the wiring diagram for my 2002 FXD. I am installing a trunk and need to know the light wiring diagram in order to hook up the tail and turn lights on the trunk.
Connector 7 is under the seat. It is the main harness to tail lite connector. The wires from main connector are:
2002 All DOM and INT Including FXDWG
Connector 7 pin 1 goes to tail lite 94 connector pin 2 = BW
pin 2 goes to 94 pin 1 = O/W
pin 3 goes to 94 pin 5 = V
pin 4 goes nowhere = empty
pin 5 goes to 94 pin 6 = BK
pin 6 goes to 94 pin 4 = R/Y
pin 7 goes to 94 pin 3 = BE
pin 8 goes nowhere = empty
Connectors 93, 94, 18, 19 are all in the tail lite assembly.
19 = Rt Turn pin 1 = V/BN pin 2 = BK
18 = Lt Turn pin 1 = V/BN pin 2 = BK
93 = Brake and running lites pin 1 = BE = Dom running pin 2 = O/W = HDI running pin 3 = R/Y = Brake pin 4 = BK = ground
Jul 25, 2010 | Harley Davidson FXD Dyna Super Glide...
The brake light on the dash wont go off brakes are good rotors are good not the emergency brake. i have a 98 durango
check the brake fluid level and check the park brake switch it may be stuck on or out of adjustment
Apr 16, 2010 | 1998 Dodge Durango
Hi there, i have a samsung t190 and it keeps twitching!
Try to check connectors including ribbon wire and try to trace some possible lose connection especially for with add on ckt. Try also to re-solder pins on hot area.
Mar 21, 2010 | Samsung T190 19" Widescreen LCD Monitor
I have lost the Red hue in my screen. Any help?
Check the video cable connectors and sockets on your PC and monitor for bent or broken pins. If the cable suffered mechanical stress, a wire inside may got broken or pried lose from the connector internally.
Change the cable for a different one. Connect the Monitor to a different PC or try a different Monitor on your PC to home in on the cause.
If the problem persists and is attributed to the monitor, a fan of the monitor connector soldered to the internal PCB may be lose or broken. This sometimes happens if the connector was pushed in using excess force before.
While a repair shop can fix this easily, I recommend not to try the repair yourself.
Feb 04, 2010 | Princeton Digital VL1918 Monitor
I have a carrier AC model#50ee036330, the fan motor went out it was an emerson2 speed with 3wires.IMtrying to replace it with a GEMOTOR no.3586 with6 wires at 1 side and 4 on the other.6wires arered black...
jenny,White and black is high speed,wire nut the yellow and blue by themselves(2) brown wires cap.yellow brown together and orange and purple together they should be direction wires.If the fan runs backwards change them
Aug 14, 2008 | Carrier Heating & Cooling
Audiovox BA200 Car Subwoofer Logo
1,412 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Marvin
Marvin
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
