Question about Electrical Supplies
Instruction Manual for Infomon Inverter Generator
2 Kva infomon Inverter GEnerator Pure Sine Wave
5 Suggested Answers
  • 461 Answers
SOURCE: Monitor 2400 heater will shut down when I run My generator
A UPS unit might work. Electronics need steady clean power.
Posted on Dec 19, 2008
harlan301
  • 205 Answers
SOURCE: I'm looking for an operation manual for a
you can check the uk there a link there. also check your capacitor
Posted on Oct 13, 2009
nitrospawn
  • 290 Answers
SOURCE: I would like to run my Canon i550 printer with a
pure sine wave will be the best option ,but note it is not very possible to get a pure sine wave type
Posted on Feb 25, 2010
  • 342 Answers
SOURCE: have rassembled a late 90's model 3.5 kva yamaha
try putting a full load on it
Posted on Apr 04, 2010
Generator burning my electronics up
take you generator in and have the output tested for correct voltage and sine wave configuration
electronics rely on a perfect sine wave ac current as a manufactured sine wave affects electronic components such as capacitors, transistors and diodes
generator sets that run an alternator ( not an inverter ) have a pure sine wave and have less affect on electronics.
go google and type in search headings like ---sine wave, inverter sine wave, sine wave affects on electronics, alternator operation and inverter operations and then you may get a pointer as to why your inverter gen set is affecting your electronics
Jul 23, 2016 | Honda EU3000iS Inverter Generator
Generator runs,no power at breakers or output plug,has been started and shutdown under load. 5.7 volts on wires coming from stator. All three wires.this is on a motor home.
have the unit checked by an authorized generator repair shop
if it was operating when shore power came back on there is every possibility that the generator or inverter has been damaged from the lack of synchronization of the sine wave
Oct 07, 2015 | Generac 5975 GP5500 GP Series 5500 Watt...
Powerhorse 4000 generator only has 110v output
to get that voltage , it would have to be revving very high
volts on a gen set are set by engine rpms
start it again ad keep manual control of the governor lever and adjust the speed screw ( controls the spring tension to the gov lever) to the 240 v output
a straight ac gen set is a pure sine wave --it is the inverter sets that have a squared of sine wave
Apr 09, 2017 | Powerhorse Portable Generator - 4000 Surge...
Need owners manual
Without knowing make or model other than 600 Watts and pure sine output:
http://www.donrowe.com/user_guides/samlex/ssw_series.pdf
is for a series of pure sine inverters, yours should be similar enough to the 600 Watt version to be of practical use.
Jan 14, 2012 | Inverter 600 Watt Pure Sine Wave
I have a 700 watt power inverter. what appliances can be used for that amount of watts.
Please understand that an inverter should only be used for temporary use, not like a generator. 700 watts is about the upper limit that most cars or light truck alternators can take.
Before adding loads to the inverter, check the wattage rating of each device you plan to connect. You should not exceed 80% of the inverter's capacity, or 560 watts continuously (.8 x 700).
Some inverters output a pure sine wave, meaning they are suitable for things like computers or other more sensitive electronics. If the inverter outputs a square wave, you should be careful not to connect devices that could be harmed.
If you look on the inverter, there should be a model number and make. It's best to refer to the owner's manual before you use the inverter. If you don't have a book, you should be able to find one on-line if you search by make and model. There may also be a phone number you can call for technical support or to obtain a manual.
Aug 27, 2011 | Vector 800 Watt Digital Power Inverter
Im a installer of kitchen and bedroom cabinets some one at work said about a inverter instead of a generator for i havent got enough space in the van for a generator and i go onto sites without power ive...
I and welcome to FixYa. I am Kelly. If you have a single load at 1430 watts and possibly some other item using power figure your max working load at 2000W. I would recommend a 3000W inverter.
The problem your going to have with an inveter that size is a single battery is probably going to die an early death trying to keep up with it. Your prbably going to need to parallel a 2nd battery into your work vehicle.
This inverter is what I would recommend so that no matter what you did to it (6000W burst load) you are not getting it fixed or replacing it.
http://www.invertersrus.com/vec051d.html
At $329.00 it isn't cheap but you spend the money ONCE vs repeatedly.
Kelly
Apr 23, 2010 | Inverter Pure Sine Wave 1500w Inverter
Run a CPAP on a power inverter
I would not do this, you really need a pure sine wave inverter to guarantee the safety of your CPAP machine. At the price they are selling this device it could not be pure sine wave. 150W pure sine wave would be $70-$100.
Mar 05, 2009 | Thermal Engineering Corporation I-Tec 150...
Dec 18, 2008 | Intel CASE 350W PWRS ALLIED W/ 24PIN +...
Electrical Supplies Logo
588 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
