Question about Panasonic Televison & Video
My Panasonic is blinking 12 times n it doesn't
  • Panasonic Master
  • 8,617 Answers
I can assist with that issue But I will need the model number of the set which is located on the rear cover.
Posted on Feb 19, 2012
4 Suggested Answers
  • 63 Answers
SOURCE: Panasonic Plasma TH-42PX60U - power light blinks 12 times
Bad capacitors...! Remove rear panel cover from tv. Most require a star screwdriver. Look for bulging caps in power supply board. (3300uf 10v ) caps need to be replaced with 3300uf 16v. Identify the bad caps.... Caps are bad when they are bulged/bulged and raised. A good Cap is flat X top not raised or buldged. I have pics of what bad caps look like on these boards. Email me if you would like to to see them. Caps cost abywhere from 1-2 dollars or you can buy them in lots of 10 or 12 on ebay for around 8 bucks. Caps need to be soldered on. Do it yourself (if confortable) or take it to a tech/pc repair shop in your local area. Do do that unplug all the wire harness from the board and unscrew the boarda nd take to your teck to solder on the new caps.
You can fix this for about 20 bucks if you have someone else solder or 40 cents if you buy the caps on ebay and replace the 2 bad ones yourself. If one is bad and the other is not replace them both.
The caps go bad because they need to be a higher voltage. 10 insn't enough..... 16 is plenty and don't go any higher than that.
Good Luck
Gunny
Posted on Feb 07, 2009
diodeic
  • 1622 Answers
SOURCE: My 50" panasonic only blinks 10 times but
The main cause of this power up problem are bad capacitors on your power if the capacitor is bad. See more bad capacitor image
Now, if your LCD set is still under warranty I would suggest to use it and let the professionals handle the problem for you. But for the rest of the Samsung LCD TV owners that their warranty had expired and want to save some money, this would be the best route. Mind me, when I fixed my power supply I didn't have any previous experience on desoldering and soldering capacitors on a power supply board. It was a good experience after all is said and done.
Now lets talk about the specs, capacitors hold 3 important value:
1. The capacitance measured in uF(micro farads) (ex. 2200uF), 2. Voltage (ex. 10v), 3. Temperature (ex. 105°C)
I hope that this will help to solve the problem and do take care because it contains high voltages...
Posted on Aug 08, 2011
  • 107 Answers
SOURCE: tv turns itself off and
It is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on.
All these can be checked on the power supply board.
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes).
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.......
Thanks for using fixya
Caseytech
Posted on Sep 21, 2011
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
What is causing the Panasonic Viera C22 series TV to power down and blink 12 times?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience. Do a search by type in the brand name of the device to the search box.
Jun 17, 2014 | Panasonic Viera C22 Series TC-L32C22 32"...
Panasonic viera blinks 12 times and won't turn on
12 blinks Sound SOS H Board has the fault. Replace it. For more details, visit this site named "Electro-help'. Check this link, and select the site named above. It has details about this fault.
Aug 02, 2012 | Panasonic Televison & Video
I have a 2008 46 inch Panasonic Plasma. Whenever I try to turn on the tv within an hour of turning it off, the tv doesn't turn back on and the power light blinks. To get the tv to turn on I h
I will be the barer of bad news. your Panel is failing. Plasma TVs are only made to last 5-7 years. 10-12 is more realistic from what I have seen. The TH46pz85u is a great model of TV but when that starts happening it means the panel is beginning to fail. Replacing the panel is cost prohibitive and they don't even make them anymore.
You will be wise to spend your money on a new TV. newer TV's are much more power efficient as well. your 46" TV draws a lot of electricity. Your TV draws almost 650Watts of power. A comparably sized TV today(55" or larger) Draws around 200 watts. Significantly less.
Jan 10, 2018 | Panasonic Viera TH-46PZ85U Plasma TV
My co-worker's voicemail doesn't pick-up until it rings 12 times. how do we change it?
From his phone, on the intercom, dial *71324 You'll hear a tone and that makes his phone ring 4 times (24 seconds) and forward.
Carl
Aug 24, 2011 | Panasonic KXDT343 Phone
TCP50G25 it blinks for a count of 4, then nothing for a count of 2 then blinks for a count of 4 times again. but the screen doesn't turn on.
I've had the same problem. It seems like your power supply is shot. You can look it up by googling "blinking red light error code panasonic".
Jul 16, 2011 | Panasonic TCP50G25 50 in. TV
EVERY TIME I POWER UP ITS SAYING F61
The below doesn't work with all Panasonic equipment but if this fails then the only fix is a replacement Laser which isn't cost effective.
U61 Fault
Corrupted or Faulty DVD in Machine.
  1. Put Machine into Standby
  2. If won't go into Standby hold 'Power' for 5-10 seconds
  3. In Standby hold 'Stop' & 'CH UP' together for 5-10 seconds until tray opens
If this fails then re-initialise the Machine as follows
  1. Put Machine into Standby as above
  2. In Standby hold 'Stop', 'CH UP' & 'Open/Close' together for 5-10 seconds.
  3. Hello displayed followed by TM AV1
  4. Put Machine into Standby
  5. 11-11 then 12-12 and finally 22-22 displayed
Switch Machine on and Retune
Apr 23, 2011 | Panasonic Audio Players & Recorders
Televison & Video Logo
67 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
