Question about Sport & Outdoor - Others
Need new poles for a greatland columbia three room tent model no. 15710
Need new poles
2 Suggested Answers
SOURCE: I have a greatland tent item #15710. This is a two
I am looking for a manual for Greatland Outdoors 2 room tent with screen porch item #15710, however, I guessed how the poles go together. I set up the tent by myself, but I recommend 2 people or more, especially if it is windy.
Start by stretching out the bottom of the tent into a square, and stake all of the perimeter tentloops to the ground, starting with the corners, with the stakes directed at a 30 to 45 degree angle under the tent, so the tent cannot easily pull them back out. Leave the yellow cords attached to the tentloops loose, so you can use the cords to help pull up the stakes when you take down the tent.
Now assemble the poles going through the loops across the front of the screen porch. Insert one end of a pole #1 into a pole #2 and thread them through the loops over the entrance to the screen porch. Put the long end of a curved pole #3 through the loops starting from one side, and attach to either side of the 1/#2 you made. Put the long end of another #3 through the loops starting from the other side and attach to the loose end of the #1/#2. You should tie the loose green cords on each corner of the sceen porch to the silver metal rings at the curved end of each #3.
Later, you will do the exact same assembly with a #3 on each side of a #1/#2 for the poles going across the back of the tent and the poles going through the pocket across the middle/top of the tent.
Now insert the small end of pole #4 into the curved end of a #3, then insert the small end of a #5 into the open end of the #4. There should be a rubber foot on the bottom of the #5 pole. Do the same thing for the other side of the porch. With help, you should be able to prop up the front of the sceen porch, pulling aganst the stakes holding the rear floor of the tent, and place the rubber feet of the #5 poles close to the center loops of the floor on each side.
Now prepare the #1/#2 poles for the rear, and attach a #3 to each side and tie the loose green cords to the silver rings on the short ends of the #3s. Prepare a #4/#5 pole the same as the front, and prop up the back of the tent, putting the feet near the side loops of the floor which are about 1/3 from the rear of the tent.
Make another #1/#2/#3, and push it through the pocket across the middle of the tent, and connect the last #3 from the other side. The side supports for the middle are pole #8 with the white clamp on the bottom, and pole #7 slid into pole #8 (The #7 was scraped off both of mine). Leave the #7 mostly inserted into the #8 until after the center is lifted up. The #6 goes on top of #7, and insert the #6 into the curved end of the #3 poles which are already in the center pocket, and tie the loose green cords to the silver rings at the short end on each of the #3s. Now lift up the center with someone helping on the other side, and put the feet of the #8 into or near the yellow loops at the center of each side. Loosen the white clamps and extend the #7 poles until the peak of the tent is at proper height.
Move the feet of the #5 poles closer to the tent, until all is tight, and you should be done!
Posted on Sep 20, 2009
I need to buy replacement polls for 2 room dome tent with screen porch
try manufacturer for part replacement or thier customer service for assistance in part replacement
Jul 23, 2017 | Sport & Outdoor - Others
Got one pole that the hook on the bottom of the tent won't stick inside the bottom of the pole
Hmmm.. Another photo would've helped. In my experience, though, it has one of three solutions.
  1. There is something (dirt, mud, clay, trash, gum) stuck inside the pole that is preventing the metal hook from going into the bottom of the pole. Try taking a ground stake of a smaller diameter and bottoming it out inside the pole. This will often dislodge FOD.
  2. There's a rubber cap or similar on the end of the pole, or the pole is backwards in the tent. Some of the shock-corded fiberglass poles are not intended to be reversible, and may not have an opening on the problem end. This does not apply to most dome tents, where 2-3 poles in circular arches can be switched, though.
  3. If you simply can't get the hook into place so that the pole can reach it, try to redistribute the tent over that pole. Push more of the end that is the problem through the sleeves on the top of the tent. It'll make the tent look taller, and may seem like it's stretching the tent. What that does is give the pole more wiggle room - on that style pole, sometimes fabric will get hung up on the metal connection sections, preventing an even spread.
Jun 08, 2016 | Sport & Outdoor - Others
I need instructions for 89034 17x15 moab
Instructions
  1. Select a flat camping area and clean the area of sticks and rocks. Remove the tent from the bag and spread out the tent body with the floor on the ground. Assemble the tent poles by connecting the attached sections at the ferrules. Set the poles on the ground and separate by size.
  2. Locate the three long sleeves on the tent body. One sleeve is horizontal over the screen room and the other two cross the main tent body to create an "X". Locate the three long poles and slide one through each sleeve. Place the corresponding pins in the end of the poles. The poles will flex and erect the tent body. This step is best attempted with two or more people.
  3. Attach the clips to the exposed sections of the tent poles. The clips are attached to the ten fabric and will add rigidity to the tent. Locate the next largest pole and insert it through the sleeve on the screen house. Locate the metal grommets where the screen room meets the main tent and place each end of the pole in a grommet.
  4. Locate the two smallest poles. These are for the side rooms. Insert one pole through each of the side room sleeves. Attach the ferrule of one steel pole to each end of the side room pole. Insert the corresponding pins in the end of the upright poles to support the side rooms.
  5. Pull on each end of the tent to ensure the floor is tight. Use a rock to pound stakes through the ground loops on the tent. Place the floor mat in front of the screen room door and use stakes to secure the mat to the ground.
  6. Place the fly on the tent and make adjustments until the shape of the fly matches the tent. The fly will only cover the top of the screen room and the entire body of the main tent. Locate the D-rings on the base of the tent and attach the fly hooks to the closest rings. This will tighten the fly to the tent body.
  7. Locate the guy ropes on the fly. Pull the ropes to the ground at an angle and pound stakes through the loops to anchor the tent to the ground.
Read more : http://www.ehow.com/how_8092535_directions-ridgeway-tent-kelty.html
Jul 23, 2015 | Baby Gear
Replacement Pole for Coleman Oasis Cabin Tent model 2000000583
Coleman may be contacted toll-free at 1-800-835-3278. Replacement parts are available from them.
Apr 01, 2014 | Coleman Outdoor Products Coleman Oasis 16...
Bought a tent with no poles no instructions have a model number
CONTACT MANUFACTURER FOR REPLACEMENT POLES ..OR # AND LENGTHS/DIAMETER OF POLES AND FABRICATE YOUR OWN...PERHAPS EVEN WITH SCHEDULE 40 OR BETTER PVC
Jul 30, 2012 | Wenzel Swiss Gear Grand Lodge Cabin Dome...
I have a Ryan's Room tent, and some of the plastic pieces that make the frame of the camping-style tent broke. How can I get a replacement part?
We had the same issue. Here's my solution.
Each tent pole is composed of 49.5 inches of half inch pvc pipe cut into three 16.5 inch pieces. This can be purchased at any hardware store. You can cut it into three pieces like the original and string an elastic line through it or just keep a piece of 49.5 inch pipe in storage to use when needed.
G Barth -- gb4cities@comcast.net
Mar 16, 2010 | Small World Home Sweet Home By Ryan's Room
I have a great land tent and we went camping this past weekend and got soaked is their any garentee on the product or replacement. The front sheild canopy pole also snapped in half very unsatisfied and...
did you set tent up at home once and soak ot down with water and let it completely dry before using it?
I have several greatland tents and never have trouble
When it is raining the most important thing to do is to make SURE that nothing is touching the tent material on the inside as to that is what causes water to start to leak thru .Just like a wick. Once the tent gets wet the fibers swell and seal the material stoping the water from coming thru and this getting wet is actually the only waterproofing needed . Taking a tent down wet or damp defeats this and must be setup again and soaked and allowed to dry all over again.As for warranty you have to check the owners manual, The pole having snapped sounds like its possible it was put in place in the wrong spot
Oct 19, 2009 | MSR Family Tents
I have a greatland tent item #15710. This is a two room tent (not dome) with a screened porch. The poles have numbers and some numbers are blue and some red. I cannot identify whether the numbers go in...
Jul 21, 2009 | Sport & Outdoor - Others
Sport & Outdoor - Others Logo
214 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
