I have the kenmore heavey Duty 70 series 92273100 Model 110 that we just moved. Was working fine before. Now it won't stop filling, overflows, and doesn't go into wash cycle. It will only s
Heavy duty 70 series model 110 92273100
    President:
  • 2,468 Answers
Either the pressure switch is bad or the pressure switch hose from the wash tub to the pressure switch is kinked or plugged so air pressure cant reach switch and operate switch,remove hose at tub and blow into it and see if machine now operates,if not the switch is bad
Posted on Feb 19, 2012
Lumpy816
  • 246 Answers
SOURCE: kenmore heavy duty 70 series extra capacity
This could be from a few things. First test. Turn on the washer to fill it up about 3/4 the way. Now turn it back off. Does the water stop? No? You probably have a bad water valve. Replace it. Yes? Listen for the sounds of running water or look for water on the floor. Do you see/ hear this? Yes? Your pressure hose has probably come off, reattach it. If it does turn off and there is not further sounds or leaking water, you probably need to replace your pressure switch.
Posted on Jun 17, 2008
  • 17 Answers
SOURCE: Model 110 top loading washer will not spin
check belt
Posted on Apr 10, 2009
  • 1937 Answers
SOURCE: I have a kenmore Heavy Duty 70 series. drains, but won't spinn?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
If everything else works OK, and the timer moves, the problem could be in the transmission / gearcase.
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode. Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
This is the Whirlpool PDF on installation and maintenance of direct drive washers. See the section on the transmission.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt. You don't have to remove the drum.
You can also see this site for removing the transmission.
http://www.fixya.com/support/r699497-replacing_gearcase
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
With ours, all told, it cost less than $30 (including new 80-90 weight gear oil) vs. about $170 for a new transmission.
The job is a bit complicated and messy but not too difficult.
Posted on Sep 29, 2009
woodchuck789
  • 4070 Answers
SOURCE: i have an old Kenmore Heavy Duty 70 series washer.
Did you clean the mesh screen filter in the end of the hose where it connects to the valve. It can stop up with sediment.
Posted on Nov 05, 2009
  • 714 Answers
SOURCE: kenmore heavy duty 70 series model 110-8237012
probably your drain pump leaking it has a seal right where it attaches to motor,,,,mine is leaking there but haven't replaced it yet! lol
Posted on Feb 28, 2010
Kenmore series 80 model 110 wont stop filling!
There is a clear plastic hose that runs from the load selection switch to the side of the washer drum. This hose connects the fill sensor to the load switch. without it being in good condition and connected properly the washer won,t get a signal that it's full.
May 09, 2013 | Kenmore Washing Machines
I have a kenmore 70 series heavy duty 110 96573230. It doesn't heat up. Can't find where the thermal fuse. Where is it located? Do I need to unscrew the back?
Yes, you need to take it all apart. ( Including the back.)
All of the things that can cause your problem are in the back and the bottom of your machine.
There are actually about 3 to 7 things that can cause "no heat".
Not only the "thermal fuse", but also the heating element, and any of the "overheat thermostat switches" can have failed, beside the possibility there is a wire has burned in two.
You will need a testing instrument like a multi-meter or a volt-ohm meter to check all these out.
Be blessed.
Mar 22, 2013 | Dryers
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
My washer overflows. it wont stop putting water
Enter your model number (110.########) and you'll see a list of major sub-components with diagrams and parts.
(The 110 means that it was manufactured by Whirlpool, you also need to enter the 8 digit model number)
Also see the Whirlpool / Kenmore Service Manual for these washers.
It has testing procedures as well as a good description of how the washer works.
It sounds like a defective water level switch or water inlet valve.
See the following for how to release the console and cabinet on these machines in order to get to the switch for testing.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
Basically, what happens is:
When the washer is turned on, the water inlet switch is closed allowing water to flow thru the inlet valve. When it senses that the machine is to the level selected by the water level dial, the switch opens shutting the inlet valves.
If the switch or valve is defective, water will continue to enter the machine.
The Whirlpool Service Manual has testing procedures (basis continuity tests with a multimeter) for both the switch and valve.
May 10, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore heavy duty 70 series model 110-8237012
Feb 27, 2010 | Kenmore Washing Machines
Series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Jun 16, 2009 | Kenmore Washing Machines
Help with Kenmore washer 70 Series
I called a repair man. The machine, it turns out is gear driven, and all the gears were shot.
May 27, 2009 | Kenmore Washing Machines
Kenmore Washing Machine 70 series
You most likely have a broken coupler between the motor and gearcase.
You can buy the part for about $10 or have someone come out and replace it for about $150-200.
If you will post the complete model number from the the washer so I can see which style cabinet you have, I will try to walk you through the repair. It isn't very complicated if you are handy with home repairs.
With the age of the machine it probably just needs a coupler, but it could also have a problem in the transmission or basket drive that has caused the failure.
Nov 13, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
624 people viewed this question
Top Washing Machines Experts
