Question about Gear Head WC1300BLK Webcam
I went from being able to use my webcam to it not being recognized/powered up by my computer. from one day to the next. Bought it in December, have used it half a doz. times.
Yes, I guess. It says F/#2.0 f.4.8 mm cc on the face of the circle. It has nightvision.
Asus monitor not working
If the monitor is still under warranty return it asp, any tampering will result in voiding the warranty. The problem is in the power supply usually one or more capacitors will open, if you are lucky it will bulge at the top leaking.
May 06, 2012 | ASUS VH242H : VH242H 23.6 inch WideScreen...
How to fix problem wont let me go into the control panel
If the control panel can not be opened, most likely corrupt the operating system.
Solution
Press START - All Programs - Accessories - System Tools - System Restore - Restore my computer to an Earlier time - Next - example; on December 1st computer in normal conditions. December 2nd control panel can not be opened. So, you go back to December 1st. Click December 1st - Next - Next. Wait process is complete - Restart.
Note
If December 1st control panel in the error condition, you're back in November (see picture)
I hope useful.
Restore points November 2011
Dec 02, 2011 | Toshiba Computers & Internet
Bought a JCAM800 and after installing the software mi PC doesn't recognize the webcam but it does recognizes the microphone... I'm on Win XP and have all the technical requirements needed...
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Apr 15, 2011 | Jwin JCAM800 Webcam
MY COMPUTER IS NOT RECOGNIZING MY WEBCAB ANYMORE. I CANT FIND THE START UP DISC EITHER.
check the cables and make sure they are all still plugged in.. Especially power to the webcam. Next unplug the usb connector and reboot the machine. then plug the webcam back into the computer. If that doesnt work then try the webcam on another computer. It could have died permanently.
Mar 09, 2010 | Micro Innovations IC465C Webcam
What is the problem with my webcam? i can not use it
Check in device manager that your cam is recognized & has no question or exclamation marks next to it.
Start- right click on my computer- Properties- Hardware - Device Manager.. look in here or your webcam, clicking on the + sign next to items expands that item so you can view. You can also uninstall your cam from device manager, unplug your cam, restart computer then plug cam back in & allow computer to re-install it.
Hope this helps.
Have a nice day.
Oct 02, 2009 | A4tech PK-635 Webcam
WEB CAM NOT RECOGNICED
Step 1: The "Tools" menu of Windows Live Messenger
1. Recover Windows Live Messenger in our software if you do not have it yet.
2. Start the installation of the software.
3. Once this is done, go to the Tools menu software.
In this menu, two links are important in order to properly configure your camera:"Setting audio and video" and "Parameters of the webcam."This is the first that we will discuss first and foremost, the second used primarily to adjust the parameters of the image in the secondary stage but we are dealing with. Launch therefore setup wizard and click on "Next".
Step 2: The setting of loudspeakers
1. Select your hardware in the menu.
2. Check the box if you use a helmet.
3. Test finally your sound output in order to adjust the volume.
It is possible that you find in the menu several choices. That means you have several elements in your computer capable of transmitting sound, a dedicated card and your motherboard, for example. In this case, make sure to select well the correct input, what you quickly verify the test by loudspeakers.
Step 3: At the turn of the microphone
1. Select your sound source.
2. Start talking to your microphone.
3. Observe the cursor, if it moves, your microphone is working.
Two remarks on the stage configuration. On the one hand, if your camera has no microphone, you must go through a device that you must annex plug into the pink on your sound card. On the other hand, if your mouse does not work, you may have selected the wrong input device sound. Take particular care in this setting and not leave this page only when the cursor s'agitera,
indicating that your voice is recognized by the software.
Step 4: Turning finally to the image
1. Specify this time the source of the video.
2. Observe the window of return: if your setup is satisfactory, your image should appear.
3. Adjust the frame rendering through the "Option" button.
Aug 03, 2009 | Microsoft LifeCam VX-3000 Web Camera
My webcam is not recognized by my computer
when I have had this happen I unplug camera reboot wait until everything is loaded replug camera in camera is found.
If this does not work delete all camera drivers by
Start/control panel/system/device manager/right click camera properties delete driver reboot do this with camera disconnected
on reboot install drivers ensure they are installed properly system/device manager no yellow mark on it. reboot when system up and running plug camera in this should work
Jul 27, 2008 | Creative Labs Live! Cam Voice Webcam
When I plug in the webcam, it says USB DEVICE NOT RECOGNIZED
These camera seem to be delicate. Call Microsoft support number that is on the documentation and they will send you another one. I did this and the replacement VX-3000 works perfectly.
Jun 24, 2008 | Microsoft LifeCam VX-3000 Web Camera
No power
Do what I am going to do. Take it back. Mine is only a day old.
Jul 31, 2007 | iLO V27DMBX Television
Gear Head WC1300BLK Webcam Logo
130 people viewed this question
Top Gear Head Computers & Internet Experts
micky dee
Are you a Gear Head Computer and Internet Expert? Answer questions, earn points and help others
