Unbalanced 2008 top loader fisher and paykel washing machine
We have a fisher and paykel aquasmart washing machine 2008. The problem is that it keeps stopping and beeping as an indication that it is off balance. I redistribute the clothes and it is fine to continue the cycle for 5 minutes or so and then stops and starts beeping again. I am wondering if it has knocked itself off balance because it did have an unbalanced load yesterday and was knocking loudly. Can I rebalance it myself ? Details Adding details will get you a faster solution from experts
SOURCE: On our Fisher and Paykel, the spin cycle does not
what modle do you have how old is it does it power down and turn off or does it stop and start beeping at you have you tried it with no clothes in it and if so does it do it then , these machines are very simple as they have vert few machancal parts post a phone number and i will call you
Posted on Feb 28, 2009
SOURCE: fisher@paykel aquasmart WL80T65CW1 fault code245
hi my fisher & paykel aquasmart has a message saying fault 49 what does this mean?
Posted on Nov 18, 2009
  • 447 Answers
SOURCE: Water leaks from my Aquasmart 8 kg washing
On most units, the water pump was a "weep" hole on it which tells you pump needs to be changed soon. It tells you the internal seals are starting to fail.
Posted on Dec 28, 2009
  • 1557 Answers
SOURCE: My Model GW712 won't spin or drain Top loader
hi there the first thing ill tell you is that the washer needs to drain water before it can spin there are only a few factors that prohibit this operation a faulty lid switch secound a blown or blocked water pump being a fisher paykel they are famous for jammed water pumps as they decided when they built the sysyem to turn the water pump upside down this causes a lot of stress on the water pump see if you can lay the hose on the ground and get all the water out i belive the machine will then start to spin dry. in this case it is the water pump and have it replaced its a simple operation if you can order the part fromf/p you simply turn the washer on its side depress the white latch next to the pump turn the pump clockwise till ity release from machine disconnect power supply plug and fit new unit as per reverse
best of luck
sonic boom electronics australia
Posted on Nov 06, 2010
  • 4 Answers
SOURCE: Whats a code 43 on
That's an 'out of balance' switch problem. Typically caused by a crook microswitch that lives under the main processor housing. Can replace with a generic switch from Jaycar or similar if needed.
Posted on Feb 26, 2011
Out of balance message being received constantly even after redistributing the load - knocking
Your AquaSmart machine requires 4 new suspension damper rods & 4 top bands, these are a common problem for AquaSmart machines.
Dec 14, 2014 | Fisher and Paykel Aquasmart wl80t65c
Fisher & Paykel Aquasmart washing machine makes loud banging noise then stops during rinse/spin cycles
Your Aquasmart machine requires 4 new suspension damper rods & 4 top bands, these are a common problem for AquaSmart machines.
Feb 02, 2013 | Fisher and Paykel Washing Machines
Fisher & Paykel Washing Machine WL80T65CW1 Aquasmart - Machine keeps saying it is unbalanced.
this model is prone for the suspension rods to weaken and cause fault,fit new set of suspension rods
Nov 10, 2017 | Washing Machines
Fisher & Paykel WL80T65CW1 - Washing machine keeps saying unbalanced.
Yes the shop you bought it from. At only 12 months old the warranty should still apply.
Nov 03, 2017 | Fisher and Paykel Aquasmart wl80t65c
Fisher paykel aquasmart top loader washing machine continuously comes up with fault 247 when trying to spin. Appears to be a balance problem as rearranging clothes and a restart allows it to...
Hi - you have possibly some restrictions in/around your smart pump unit, inside is a flapper valve suppose to control flow in both directions, often this gets the rough treatments.
Be careful if you wish to have a nosy its located beneath the smart agitator.
Jun 18, 2011 | Fisher and Paykel Washing Machines
My Fisher & Paykel AquaSmart 7kg top loader shows Error Code 245
Error 245: SmartPump Stall
Pump Impeller is jammed cannot turn.
May 24, 2017 | Fisher Washing Machines
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
