Question about Element Electronics GC823 MP3 Player
My mp3 player is saying starting but its just stuck there
I put a new battery in and it is still frosen on the starting screen
My sandisk mp3 is frosen on the meau and wont trun
1. Push the "Power" switch downward into the "Hold" position.
2. Press and hold the "Menu" and "Record" buttons at the same time until the device resets.
3. Push the "Power" switch upward all the way to turn it back on.
OR
1. Grab a steady hold around the device.
2. Push the "Power" upward and hold it there until it powers off.
3. Power the device back on by releasing the power switch and then pushing it upward again.
OR
1. Unscrew the screws on the back of the device (or simply push the lid off if it is a model without screws.)
2. Take out the batteries from the slot and wait until the screen goes black.
3. Insert the batteries the same way they were mounted and attached the lid again.
4. Push the power switch upward to turn on the device.
Oct 01, 2009 | SanDisk Sansa e250 MP3 Player
MP3 player stuck at welcome screen
One time I replaced my battery and my unit would not go any further than the Pearl logo. So, I downloaded the firmware upgrade from http://voxrightnow.custhelp.com/app/answers/detail/a_id/2243/related/1, and followed all the troubleshooting instructions that popup when you start the program:
start the program,
remove the battery,
hold the play button while plugging into usb,
release the play button the the term "initalizing" replaces "searching",
check the box that says "format data" (you can try it first without this checked, it may work and will save your music),
click the start button to replace the firmware.
After I did this, my pearl started normally, and my computer recognized it again. It also fixed my aac-error problem.
Jun 29, 2009 | RCA TH1602 MP3 Player
My e280 is frosen on Refresh Database. What do I
Mine did that, and I had to reformat. I believe this is how I did it (note, mine is not a Rhapsody type, that one is different in many respects):http://www.sansacommunity.com/forum/thread/11221/How-to-format-an-e200/
Jun 08, 2009 | SanDisk Sansa E280 MP3 Player
My RCA TH1161-A mp3 player wont work at all
Ensure the key lock is not activated by sliding
"Power on/off ( )/Hold" towards the center
position. If your player isn’t already on, turn it on by
sliding "Power on/off ( )/Hold" to the left
and holding until the player turns on.
-Tha Mp3 Doctor
Jan 06, 2009 | RCA TH1101 MP3 Player
My mp3 player wont come on
did you try holding the button? thats how mine works
Nov 30, 2008 | Coby MPC-848 MP3 Player
Sansa MP3 player has frozen screen
With the Sandisk you can just open up the battery compartment and pop the battery out for a second, then if you put it back in and turn the mp3 player on, it should work just fine. This is easier to do with the older ones that take AAA's, but unfortunately with the e250 you need a little screwdriver to remove the battery. (But the other day I used the flat part of a piece of jewelry; you can use whatever you have :D )
Sep 27, 2008 | SanDisk Sansa e250 MP3 Player
Stuck on loading screen
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Jul 31, 2008 | iLO (2 GB) MP3 Player
My delstar mp3 player model DS3512
If it only gets as far as starting, the unit’s firmware is corrupt.
Firmware updates are not usually recommended.
I’d contact Delstar for the correct firmware.
Apr 23, 2008 | Delstar DS 31024 MP3 Player
Creative zen v plus frosen
Did you hold down the power button while resetting it?
Nov 08, 2007 | Creative Labs ZEN V Plus MP3 Player
Element Electronics GC823 MP3 Player Logo
149 people viewed this question
Top Element Electronics Audio Players & Recorders Experts
Gyula Lacz
ray gallant
Are you an Element Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
