Question about Sony PlayStation 2 (PS2) Console
PS2 won't play disc
When I insert a disc into the console it goes to system config. screen, usually stops there or goes on to reading disc screen then stays there indefinitely.
  • gabteach Oct 26, 2008
    Is there something I can do to fix?
Sounds like 1 of your lasers is damaged. its a common problem as there are 2 lasers on this model.
Posted on Oct 26, 2008
  • petsave Oct 27, 2008
    probably cheaper to buy a new or 2nd hand ps2 you can get them from £30 nowadays. Sorry if this isn,t the answer you wanted but it is the cheapest solution.
Ps2 Disc won't respond to a Ps3 when inserted.
Only the first version of the PS3 had PS2 backwards compatibility, They did make a special edition Metal Gear Solid version with it included but other than that no other PS3 will play PS2 discs... No matter what Add-On you install.
Oct 07, 2012 | Sony PlayStation 2 (PS2) Console
My PS2 is not loading Grand Turirsmo 4!
If your PS2 works fine with most of the games and won’t play a few..Then you should try this trick to play them too on your PS2:
  1. Turn on your PS2 without inserting any disc.
  2. Menu screen will appear like:6e4cb56.jpg
  3. Press the (triangle) Button to enter Version Information Menu that looks like9d90dc8.jpg
  4. Highlight the Play Station Driver as above and again press (triangle).
  6. Highlight the Disc Speed as above and press X button,to enter Disc Speed Menu
  7. And set it from Standard to "Fast".
  8. After you set Disc Speed to Fast, Press and Hold Reset Button to turn off your console.
  9. Then again Press and Hold Reset Button till the Blue Light turns on.
  10. Remove the Reset Button and Press it again.
Be patient and wait till the game loads itself. If your lens is in good condition then it will play game in first go else try again till it PLAY your game. If still your Grand Turismo 4 DVD wont work then you must clean your PS2 lens.Watch following video to learn about cleaning lens:
Thank you and Good Luck!
Dec 16, 2009 | Sony PlayStation 2 (PS2) Console
How to fix my playstation 2 that won t read grand theft auto san adreas
Your console is an old one,and your lens too is probably weak.Try cleaning your PS2 lens Watch Video at end of solution to clean your PS2 at home....
You can also follow these steps to make your PS2 to play GTA San Andreas:
  2. On menu screen go to [options] by pressing 'triangle' button.
  3. A new screen will appear select by pressing 'X' [DISC SPEED]and set it to [FAST]
  4. Then insert the game disc.
  5. Turn off your PS2.
  6. Press and Hold the [Reset Button] till the blue light turns on.Release the Reset button and press it again.
It will take a bit more time to play game,but first i recommend you to clean your PS2 lens,watch this video.
I've got something else to add.......you can follow above steps to play DVD movies if your PS2 dont play any.....!!!
Nov 19, 2009 | Sony PlayStation 2 (PS2) Console
Playstation 2 won't play DVDs
if it's a fat PS2 and
model SCPH 30001, SCPH 35001
(not including the models with an 'R' after the model #.
these models need the following to play DVDs:
- PS2 DVD remote with IR unit
- PS2 DVD disc player (sold with DVD remote w/ IR unit)
- PS2 memory card
you copied the DVD disc to the memory card. you used the memory card to play DVDs.
later models didn't need the memory card to play DVDs.
hope this helps :D
Jul 16, 2009 | Sony PlayStation 2 (PS2) Console
Please insert ps2 format disc?
Try inserting the disc in your computer. If it reads its fine. Then look if the Slus...... is compatible.maybe thats why it doesn't play. your ps2 must have an old bios system even if slim.
Mar 05, 2009 | Sony PlayStation 2 (PS2) Console
Ps2 not reading disc.
Theres a high chance that your laser simply broke. You should let someone with solder experience let replace the PS2 laser.
You can buy the laser on websites like this one: http://www.consoleparts4u.co.uk
Oct 05, 2008 | Sony PlayStation Portable (PSP) Console
First you need to define what it IS and IS NOT reading. You'll need to run some tests.
Test 1: use a regular music CD (NON BURNED) (RETAIL) disk and put that into your ps2 and see if it starts playing it.
Test 2: insert a regular DVD (NON BURNED) (RETAIL) disk and try to play that.
If neither will play then it is one of two things. Your laser lens is out of alignment, or your laser lens is damaged.
If one plays but not the other, it is the potentiometer pots on the back of the PS2 lens that need adjusting. You can read more about that on one of my other posts ::.HERE.::
Sep 28, 2008 | Sony PlayStation 2 (PS2) Console
Disc read error
Your PS2 lens is faulty or it is physically jammed in it's metal rod which stops the lens to move smoothy. you better open the PS2 console and observe it offline for jam. or replace the lens with a new one.
Nov 15, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
67 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
