Question about HP PSC 1610 All-In-One InkJet Printer
Ink is too light on printout, can barely read it
    Top Expert:
  • HP Master
  • 1,575 Answers
Hi
Check the installations of the cartridges and probably re-install them again.
Also try adjusting the colour density on your printing software.
Posted on Feb 19, 2012
PRINTING ON PAGE IS VERY FADED AND SOME PARTS NOT PRINTING AT ALL
First, checkthat the USB cable is secure in both the printer and the computer and that theprinter is sitting on a flat surface. The printer may not work if it is tilted.
Next, run a printer check to make sure the printer is operational. To run aprinter check, turn off the printer and the computer and unplug the USB cable.Turn on the printer and press the Maintenance button. Use the down arrow buttonon the printer to highlight More Options on the display screen and press OK.Highlight Nozzle Check and press OK twice. If a page prints out, reinstall theR300 software on your computer.
Lines inPrintout
R300 mayproduce printouts with light horizontal lines that are not a part of theprintout. This is called banding and can have several causes. First, trycleaning the printer head to clear any clogged nozzles. To clean the printerhead on the R300, press the down arrow button to highlight More Options andpress OK. Use the arrow buttons to highlight Head Cleaning and press OK twice.The printer will take about 30 seconds to clean the print head, after which youshould run a printer check as described above. If the printout has gaps, pressthe STOP button to run the print head cleaning feature again. Once there are nogaps in the printout, press OK.
If the printout still has banding, open the Print window on your computer andclick on Properties. In the Properties window you can choose the print quality,speed and printer type. Select a higher print quality and a lower speed andmake sure the paper type matches the type you are using for the printout.
Finally, check that the ink cartridges are not empty or close to empty andreplace them as needed.
Faint Printout
If your printout looksfaint or faded when using the R300, try cleaning the print head. Next, replaceany ink cartridges that are old, low on ink or out of ink. Check that the papersetting on the computer matches the type of paper you are using for theprintout.
Another potential cause of faded printouts is incorrectly loaded paper. Sometypes of paper have a printable side that is whiter or shinier on one sidecompared to the other. The printable side of the paper needs to be loaded intothe printer face up.
Nov 20, 2010 | Epson Stylus Photo R300 InkJet Printer
Poor print quality, but only on certain lines
Pull out the cartridges. Wet a q-tip with alcohol and clean the foil contacts that are in the spaces that the cartridges just occupied. Use a flashlight to better see what you are doing. See if that helps.
And what kind of lines are you getting on the printout? Vertical?Horizontal? Those could be ink that is on the feed rollers.
Jul 17, 2010 | HP Officejet 6310 All-In-One InkJet...
LC 61 printout problems
As the manufacturer always suggest don't replace your ink with just a refill.
Please replace your ink cartridge with original ink cartridge.
Sep 19, 2009 | Office Equipment & Supplies
My Epson Stylus Color 760 printer tells me there's still ink
If your ink was installed Feb. 2007, then most probably it got expired as you said you have done test prints but with faint samples.
It is advisable to install new and genuine epson ink cartridge.
Jul 24, 2009 | Office Equipment & Supplies
Could not take print.
replace cartridge and see if problem still occurs.
May 02, 2009 | HP LaserJet 1320 Printer
Low ink light will not go off after refining HP94 ink cartages
the message of low ink cartrige always appears after refilling the cartridge or installing the recycled cartridge.only if u install orignal cartridge it will go.but let it show low ink you will get proper printouts till the end of the cartridge as this message does not effect on copy quality or number of printouts.the printer will work.just cancel that message or ignore.it will not effect your printer.
thanks.
Nov 13, 2008 | Office Equipment & Supplies
Getting started with a used deskjet 880c
you can notice it when the ink indicator is flashing..or by manually looking at the printout..
Sep 04, 2008 | HP DeskJet 880c InkJet Printer
Printer problems
PULL OUT TONER CARTRIDGE SHAKE SIDE TO SIDE AND REINSTALL
Jan 18, 2008 | Brother MFC 9700 All-In-One Laser Printer
Blank printout
If you are able to drag out your users manual, most lazer printers have a self cleaning process for the head, which takes around 3-5 minutes to complete, after that try to run a test page to ensure the colors are working fine.
Failing that, unless the printer is brand new, and or unless it has been sitting ( unused - regardless of age ) the print heads can dry out leaving a blockage ... hence, no ink, hence blank page.
The only other suggestion after running a Print head clean, would be to replace or refill the ink cartridges.
Jan 13, 2008 | Lexmark X5150 All-In-One InkJet Printer
HP PSC 1610 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
