How do i replace the hard drive - Computers & Internet
    Top Expert:
  • 1,575 Answers
Hi
Open up the desktop to view inside.The hard disks connected with almost the same cords as the DVD/CD ROM.You only have to disconnect them and slide the disk outwards to remove.
Hope it helps.Thanks!
Posted on Feb 19, 2012
HD REPLACEMENT
Check if you can use SATA else you'll have to look for IDE
Actually to insert a SATA drive is easier then replace a light-bulc.
Just remove cables, unscrew from "drawer" insrtn new drive, scress, replace cables.
If it's a system disk, the difficulty is resintall your system. After you've replaced Hard disk, formulate your question with more doubts
See some fine videos here
How to install SATA hard drive into computer
How To Install Internal Sata Hard Drive and Activate In Windows OS
How to install and remove SATA Hard Drive
How to Replace Desktop Hard Drive
How to Install Second SATA Hard Drive
Jun 27, 2015 | Computers & Internet
How to replace hard drive in Canon image runner 2230 copier
Replacement Hard Drive (LMXWM25216000) for Canon imageRUNNER 2230
Dec 16, 2013 | Computers & Internet
Replace hard drive motherboard
Before you start replacing drive you need to ask yourself if you are trying to replace a bad hard drive and just want to start with a clean install of the O.S. OR are you replacing your hard drive with a bigger one and wish to keep your installed programs, data and documents. If you want to keep your data and documents you need to know how to save the Files and folders on your computer to a CD, DVD or a USB hard drive. Just replacing the hardware involves unplugging all cables from computer after shutting it down. Then opening the case and unplugging the cables from the hard drive and then remove the screw(s) retaining the hard drive. Remove the old hard drive from the case and replace it with the new one, replace screws and plug cables back up watching that that the connectors are correctly aligned with the key(s) on the hard drive's sockets. Replacing the Hard drive also involves installing the O.S. and all your programs and applications on the new hard drive. You can find a lot of information in the internet about this.
Oct 21, 2013 | Gateway SX2855 Case
Erase hard drive hp1055
In service test menu scroll to "3.Hard disc drive", & press enter, if test drive passed don't replace the hard disc or modification or changes. If test failed then check as shown below:
1 Switch the printer OFF. Remove the EIO Card (if installed) and re-install the Hard Disk Drive making sure it installed correctly by pushing it firmly inwards and checking that the two installation screws are completely tightened. Switch the printer ON again and repeat the Hard Disk Drive Test. If the Hard Disk Drive Test fails again then replace the Hard Disk Drive.
2 If the Hard Disk Drive Test passed after removing the EIO Card,then switch the Printer OFF and reinstall the EIO Card, making sure that the two installation screws are completely tightened.
Switch the Printer ON again and repeat the Hard Disk Drive Test. If the Hard Disk Drive Test fails, then the EIO Card could be faulty.Replace the EIO Card.
3 If the Hard Disk Drive Test continues to fail after replacing the EIO card or the Hard Disk Drive, then replace the Electronics Module..
I am having little knowledge, if I am wrong Pl don't comment, pl forgive me.
May 20, 2013 | HP DesignJet 1055cm InkJet Printer
Pri master hard disk s.m.a.r.t. status bad, backup and replace press del to resume
Hard drive is bad or is going to fail soon.
Solution
Backup your information and contact the maunufacturer of the computer or the hard drive for replacement or additional help.
In some very rare cases the S.M.A.R.T. implementation on your computer may have issues of its own and may need to be patched before replacing the hard drive.
If I am receiving the S.M.A.R.T. error, is it ok if I continue to use my hard drive and do not replace it?
As stated above, S.M.A.R.T. is designed to detect upcoming failures in the hard drive.
While it is possible that the hard drive may not fail for several months, it is still inevitable that the hard drive will fail.
It is ok to continue to use the hard drive, however, we highly recommend that if you are still under warranty that you consider getting the drive replaced before your warranty runs out.
hope this helps
Sep 20, 2012 | Western Digital WD AV WD2500AVJS hard...
How do I replace the hard drive on my sony Vaio VGN-NR120E?
To replace a hard drive, you'll need to backup any data you want to keep, uninstall the old hard drive, install the new hard drive, and then restore the backed up data.
The specific steps necessary to replace a hard drive differ depending on the type of hard drive you're replacing.
Jun 20, 2011 | Sony VAIO VGN-NR120E/S Notebook
What hardrive for my armada M700?
Hard Drive Installation Instructions 40 gig IDE DRIVE
  1. Shut down the computer and remove Battery Pack and AC adapter.
  2. Locate Hard Drive compartment on the front panel, just left of the head phone jack.
  3. Turn Notebook upside down.
  4. Remove the one torx screw that is securing the hard drive. (A security screwdriver was provided with the computer.)
  5. Push down on the hard drive bezel on the front of the hard drive.
  6. Lift the bezel up 90 degrees to create a handle. Pull the hard drive out of the hard drive bay.
  7. Remove the 4 black screws at each corner and lift off the black tray.
  8. Gently remove the silver bracket and connector.
  9. Place connector on new hard drive.
  10. Place the black tray on the HDD. When looking at the hard drive with the label up, the black bezel goes along the left side of the hard drive.
  11. Replace the 4 black screws from step 7.
  12. With the hard drive bezel pulled down, slide the hard drive into the hard drive bay.
  13. Push up on the hard drive bezel to secure the hard drive in the bay.
  14. Secure the hard drive bay by replacing the screw from step 4.
  15. Replace the battery pack and all cables
Aug 08, 2009 | Compaq Armada M700 Notebook
Can i replace the default hard drive with any brand hard drive?
Well the replacement drive should be the same interface. i.e. if its an IDE drive then you'll need an IDE drive if its a SATA drive you'll need a SATA drive! regards, babb
May 07, 2007 | LaCie (300773) 1638.4 GB Hard Drive
Open Questions:
$@$$@...1********** Canon printer tech support USA ______ Canon Printer Tech Support phone Number Canada 1********** @%%@&&@ Canon Printer tech support @manufacture1? Canon customer service hours Canon computer support contact Canon phone Canon online customer support Canon customer care Canon deskjet printer support Canon customer care phone number Canon contact support phone number Canon customer service number for laptop Canon Contact Number Canon printer service center number Canon Printer Customer Service Number customer care Canon printer Canon help desk phone number hewlett packard customer service Canon printer customer service phone contact number for Canon hewlitt packard customer service www support Canon Canon 1844 Canon Printer Customer Support Number Canon customer care number for laptop Canon deskjet helpline Canon support printer Canon support 844 number Canon phone support phone number Canon support helpline Canon support number printer Canon support helpline number Canon printer install Canon number for customer service contact Canon printer support by phone Canon support technical support number telephone number for Canon printer support Canon printer support telephone number Canon printer tech support phone Canon customer care phone number services Canon notebook customer care number Canon consumer support printer technical support phone number Canon printer customer care online Canon support com customer service for Canon printers Canon Customer Service Number Canon technical Canon pavilion customer support number Canon phone Canon customer service center Canon support number in usa Canon warranty number Canon pavilion support Canon printer customer service number Canon contact number usa Canon help and support Canon printer help number Canon Phone Number Canon laptop support number printer tech support Canon Canon photosmart support phone number phone for Canon tech support Canon print support number Canon Tech Support Number Canon printer phone number Canon printer support chat call Canon technical support Canon customer helpline Canon printer phone support number Canon com contact number Canon com tech support Canon support computer contact Canon technical support by phone Canon printer contact phone number Canon tech support hours Canon customer service for printers printer support number Canon customer care contact Canon support tech support phone number Canon printer from phone Canon desktop support Canon customer care number contact Canon support number Canon laptop support contact number Canon technical support hotline Canon support laptop phone number Canon support phone number for printers Canon help center customer care no of Canon Canon Customer Support Number Canon online support for printers call Canon laptop support Canon service customer care number Canon printer 844 number Canon wireless printer tech support phone number tech support Canon number Canon support assistant number Canon Technical Support Number Canon wireless printer support phone number Canon wireless support Canon support one Canon phone support number Canon tech support phone number usa Canon envy customer support Canon computer helpline number Canon printer error codes Canon troubleshooting printer Canon help phone Canon call center number Canon wireless printer support Canon customer care toll free number help with Canon printer Canon deskjet help customer support Canon customer service number for Canon Canon Printer Contact Number Canon printer phone support Canon phone number for printer support Canon laptop tech support Canon phone support printer Canon online help Canon tech phone number Canon support customer care number Canon printer contact support Canon support for printers phone number Canon customer support center Canon printer support uk Canon laptops number customer service Canon contact help Canon phone number Canon printer support line Canon 24 hour support Canon laptop online support Canon Printer Contact Number Canon printer call center number Canon customer relations Canon support site Canon computer phone number customer service Canon pavilion tech support phone number Canon laptop customer care phone number Canon contact support Canon officejet contact number Canon Printer Customer Service Phone Number Canon customer support no Canon officejet customer service telephone number for hewlett packard technical support Canon notebook help Canon printer support customer service Canon printer technical support telephone number Canon printer support online Canon print support help with Canon laptop Canon pavilion customer care number technical support for Canon printers Canon technical service phone number Canon all in one printer support phone number Canon printer customer number Canon laptop service center contact number Canon laptop contact number Canon support desk Canon Printer Printer Service Number Canon customer care helpline number Canon notebook support phone number Canon service support Canon helpline for printers telephone number for hewlett packard Canon customer number Canon Customer Service Phone Number customer service number for Canon printers customer care no of Canon printer Canon printer toll free number Canon desktop helpline number Canon call support printer tech support number Canon product support Canon support assistant phone number Canon computer helpline Canon contact number 24 hours Canon number customer service contact phone number for Canon Canon printer support phone number Canon laptop customer support number Canon com contactCanon Canon 844 number Canon support india Canon customer care number 24 7 Canon notebook customer service Canon printer help Canon customer service contact call Canon printer support Canon customer support printer Canon customer support line telephone number Canon support Canon warranty phone number Canon phone number customer service Canon printer service number Canon pc support phone number Canon tech number Canon notebook customer care contact Canon support Canon pavilion customer service phone number Canon printer customer care number Canon laptop contact Canon customer care support Canon customer support online Canon photosmart help technical support Canon phone number phone number for Canon support for printers Canon support call contact Canon by phone Canon printer help line online Canon support Canon printer customer support telephone number telephone number for Canon support Canon products phone number Canon laptop customer service Canon online printer support Canon laptop customer care Canon contact Canon contact number Canon tech support for printers Canon support online Canon printer support phone number us Canon Printer Tech Support Canon printer call center Canon laptop number phone number for Canon printer support Canon customer service line Canon text support Canon customer help Canon help desk for printers Canon printer support number usa Canon all in one support Canon ink customer service number Canon pavilion support number Canon help center phone number Canon printer customer service contact number Canon customer service contact number Canon laptops tech support Canon support services Canon computer support number Canon officejet help Canon technical support for printers phone number tech support Canon printer Canon customer support telephone number Canon tech support 844 number Canon help and support center Canon laserjet support Canon online tech support customer service Canon laptop phone number Canon customer support contact number Canon Printer Tech Support Number Canontech Canon phone number for help Canon printer customer service phone number Canon officejet printer support contact Canon support phone Canon consumer support phone number Canon desktop support phone number Canon Printer Service Phone Number Canon officejet technical support Canon help and support phone
Nov 21, 2017 | Pavilion Computers & Internet
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
