Sherwood RD8108R no sub-woofer
Hi. Was wondering if anyone could help me out. I can not get my sub to work (cables and speakers test fine so it must be in the set-up on the receiver). I have been through the manual trying to work out where I might have gone wrong but still can't work it out. Gale Sub5 is powered up and connected (via left channel) to the Pre-out Sub output on the RD8108-R and sub-woofer is swtiched on via the speaker set-up menu (fronts are set to small). I can't even get a tone through it on the T-Test, so absolutely flummoxed. The set-up used to work in a previous location but since I moved it, nothing. All the other channels are fine. Any help greatly appreciated. Many thanks
  • 2336 Answers
SOURCE: Connecting DVD player to AV receiver
If you've done that already and still no response from your system, I would suggest to take back to the place where you bought it and ask them to check it for you. Tell them that you follow the user's manual to the "T" but still unable to make it work.
Good Luck.
Posted on Jun 20, 2008
blueextc3221
  • 15935 Answers
SOURCE: CANT GET SUB WOOFER TO WORK WITH MY RECIEVER!!!!!
See step 9 for turning the subwoofer output ON
HERE
Part of the original link i gave you to your online manual.
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Feb 13, 2009
  • 92 Answers
SOURCE: no output to subwoofer per-amp
you may have to go into the onscreen menu and enable it,that shuld work
Posted on May 20, 2009
  • 561 Answers
SOURCE: How to switch on Sub?
surround and subwoofer may not work if there is an additional graphic equaliser operating.
1. check in your receiver speaker setting ensure your speaker setup doesn not have subwoofer set to NONE. this will block any signal to your subwoofer socket.
2 when you select your surround sound setting setup, ensure you select the speaker mode you want, if there is a multicontrol knob, cycle through the choices
select subwoofer mode and set it to yes.
if you have set-up small speakers S in your speaker settings then it could be that subwoofer is set to yes automatically if you have large speakers L, subwoofer has to be set additionally in the subwoofer setting.
3 test subwoofer on alternative device to test it is working ok
consult manual on enjoying surround sound and adjusting the speaker settings.
Posted on Nov 16, 2009
dunnbiker
  • 8546 Answers
SOURCE: Cannot get the sub woofer to work.
Now tell the NAD you have a subwoofer. Page 15, Figure 13, etc. and Page 18 - 19.
Posted on Mar 05, 2010
How it can be connected to a stereo amp
hi,
if ur amplifier have a pre out, then u can connect that to ur L/R input of ur sub woofer.
if not the only way is, connect ur amplifiers speaker output to sub woofers speaker input and then connect ur speaker to sub woofer speaker output terminal. remember don't inter change positive and negative wires.
if ur amplifier have speaker A,B connection then it is very easy. connect the speaker A to ur left and right speaker. then connect speaker B to ur sub woofer's left and right speaker input. be sure to make that speaker A and B switch is in on position. the power on both and check it. ( use good quality speaker cable to connect the sub woofer)
your sub woofer is designed to work , both at low level and high level input.
ok
Dec 17, 2010 | Yamaha YST-SW215 Subwoofer
I get no sound out of my sub woofer. I've triple checked the setup for speakers. I've had this unit for years so I'm familiar with the setup. I've taken the speaker to another stereo and it works fine....
check the cable for you sub woofer. If problem exists. Try another cable to verify. What kind of subwoofers are you using? Are you going through the LFE port or are you running speaker wires through the speaker inputs on the sub?
Dec 08, 2010 | Pioneer VSX-D908S Receiver
The sub-woofer output on the receiver is not working. I have tested the sub-woofer (speaker) and it works. And I have tested the cables and they work. The problem lies within the receiver. How can I fix...
I don't have the manual, but if YOU do, crack it open and find the part where you tell the receiver it HAS a subwoofer and any other settings that direct bass toward it.
Apr 18, 2010 | Sherwood RVD-8090R Receiver
Sherwood home sub sp210 manual for speaker hook-up
pull sub out it may have been replaced and the speakers inside were not connected.
Apr 04, 2010 | Sherwood U8M Car Subwoofer
My sub woofer is driving me crazy
it is the problem of ur cable there must be a shorting between the cable try changing ur cable.
Dec 01, 2009 | Philips MMS 460 Computer Speakers
Nov 16, 2009 | Sherwood R-945 Receiver
Sherwood RD7502
Hi - You can download the manual by clicking the link underlined in blue below:
RD-6108
Your sub woofer needs to have it's own power amp i.e. a "powered" sub woofer:
Assuming your sub woofer is powered & connect as shown then check the following setting:
Let us know how you get on.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 06, 2008 | Sherwood RD-6108 Receiver
JVC DVD players
Use a sling for multiconnection to connect 8 pin input;
Sling Media - Slingbox
Jul 19, 2008 | Audio Players & Recorders
No sound out of woofer
Hello sparkie102
Happy Holidays
you have to check if all the cables are well connected, and in the right inputs. 2) check your software for sound that is enable, fine.
turn up the sub volume , if got it independent.
other that this, is a failure sub. if got warranty, use it! or RMS your sub.
Dec 26, 2007 | Logitech Z-2300 Computer Speakers
35 people viewed this question
 Grubhead
Grubhead
