Question about Minolta EP1083 CS/PRO Copier
Minolta ep 1083
Hej jqsaba. Thank you so much for your try to help me. But I don`t understand your latest suggestions. (I am a fool, I kow) I can`t see any faulhts on the drum and what is the mag roller. I mean it is not possible to adjust anything on that part. And what is t/s charge unit??? Sorry...
  • 145 Answers
You do need to ajust anything...just look for some sort of dirt ,in the developer unit..transfer separation unit is the unit.sets under the drum..its has 2 very thin wires.
the wires should be cleaned very gently.with pencil eraser.is good
hope that help
Posted on Oct 28, 2008
Date 18th May 2010 Dear Sir What is the
THEY ARE BASICALLY THE SAME MACHINE THE 1085 HAS MORE FEATURES.THOSE MACHINE ARE ABOUT 10 YEARS OLD AND PARTS ARE BECOMING HARD TO GET. I WOULDNOT BUY EITHER.GET A NEW DIGITAL COPIER AND YOU WILL BE ABLE TO PRINT FAX SCAN AND COPY AND PARTS WONT BE AN ISSUE FOR MANY YEARS
May 18, 2010 | Minolta EP1083 CS/PRO Copier
I have a Minolta EP 1083 the copies that it gives smudge
If fuser rollers are getting hot - you either lack pressure between upper and lower rollers Restart; remove/dump old developer - instal correct compatible starter reinstal imaging unit remove toner ctg. key in stop 0 stop 1 tec rep run F-8 mode runs apx. 2 min. exit svc mode If whats not fusing is gritty(starter) - other issues
Jan 19, 2010 | Minolta EP1083 CS/PRO Copier
LOOKING FOR A MANUAL ....MINOLTA EP 1083
get it here:
http://safemanuals.com/user-guide-instructions-owner-manual/KONICA%20MINOLTA/EP1083-_E
*please rate me :)
Mar 24, 2009 | Minolta Office Equipment & Supplies
Minolta ep 1083
i still think its your developer unit is causing this problem,do this take out the drum unit remove the developer unit and rotate the develper unit gears clock wise and look for void areas on the magnet roller where develpoer adhear .
hope that help
and check your fuser rollers ?
Nov 02, 2008 | Minolta EP1083 CS/PRO Copier
Minolta ep 1083
why is this still posted?
this was solved
Oct 30, 2008 | Minolta EP1083 CS/PRO Copier
PAPER FEED
you can disconnect the sorter.if that's all you need
Oct 16, 2008 | Minolta EP1083 CS/PRO Copier
MINOLTA COPIER EP 1083 IMAGES TO DARK, NEW TONER, CHANGE PAPER
what is your exposure lamp brigthness condition? checkyour upper high voltage adjustment , check your exposure lamp & bright it & clean your copier lens.thanks.
Oct 05, 2008 | Minolta Office Equipment & Supplies
Help please - my Minolta EP 1083 won´t work properly.
did you try to cleane the optic section ,make sure to remove the lens cover and clean mirror on the right side too underthe len cover,2 remove drum check and c if toner on drum?
Sep 24, 2008 | Minolta EP1083 CS/PRO Copier
EP 1083 service /reset codes
Press on keyboard, stop o stop 1. Press 4 to enter counter mode., the first counter should be the pm, displaying a counter with a negative sign. Press cancel key to reset to 0. Exit service mode by pressing panel reset 2 or 3 times and you should be back in business.
Jul 06, 2008 | Office Equipment & Supplies
51 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
