Question about Staples EPS611X (CrossCut) Shredder
Eps-611x manual Is there a fuse or circuit breaker?
Cleaning a shredder that has sticky paper stuck to the cutters. A EPS-611x.
FIRST MAKE SURE THAT YOU HAVE REMOVED POWER
UNPLUG IT
Using pick remove the paper that is stuck to the cutters,
also you could try shredder oil to assist after you have removed
a majority of the sticky paper...Take a piece of paper fold it
in half, apply a bead of shredder oil the length of the folded paper
Run it through the shredder like you would a plain piece of paper keeping it folded
Sep 05, 2017 | The Office Equipment & Supplies
Can not locate fuse for power windows in fuse box
Interior fuse box. It is a circuit breaker, not a fuse, #28, according to your owners manual. Not only check the circuit breaker, use a test lite and check for voltage on circuit breaker circuits. Sometimes, if faulty window motor, it may cause the circuit breaker to trip. I've seen some circuit breakers that were hot to the touch. After it cools off, it may reset?
Jul 18, 2017 | Cars & Trucks
WHERE IS THE FUSE FOR MY POWER STEERING IN MY 2006 CHEVY HHR LOCATED?
You vehicle has two fuse's ! one in the underhood fuse box EPS/STR WHLCNTRL an it is a 60 amp . An there is one in the BCM fuse center - EPS 2amp fuse ! do you know what an where the BCM is ? The BCM - body control module !
Body Control Module (BCM) location
Under the I/P below the radio on the right side of the center console .19
EPS/STR WHL CNTRL
2A
Electronic Power Steering (EPS) Column Assembly and Inflatable Restraint Steering Wheel Module Coil
Aug 05, 2015 | 2006 Chevrolet HHR
Cable replacement on six-sheet crosscut shredder Executive Machine EPS-611X?
Fairly simple fix then; figure out what length of cable you need (or would like to have if you need something a little longer (like 1 or 2 feet more)) and run down you your local hardware outlet; a place like Lowes, Home Depot or Ace Hardware and pick up a 2 or 3 wire replacement. Make sure it is th same guage wire inside. This will involve opening the unit to install the new one. Take the head unit off, open it and see where the wires from the cable attach to. Make a drawing or take a picture of it before you take things apart and along the way so that reassembly with be easier. Disconnect the old broken cable, and connect the new one. If it is solder to a circuit board, or soldered to the switch, cut the wire back (the old one) so that you can splice the new cable to it. If it uses little connectors, you can disconnect it, and take them along when you go to get the new cable and see if they have similar connectors you can use on your new cable. Reassemble it, and test it. Should be a pretty simple fix. Let me know how it comes out. If you need any additional help, just post it here. -Coss-
Dec 10, 2013 | Executive Machines SESS640HD 6-sheet strip...
Which fuse on the fuse panel is the one for the power windows i lost the manual
I know thta, for a 2002 Ford Explorer, the 30 amp circuit breaker in location #62 of the power distribution box in the engine compartment is the power window circuit breaker. (unfortunately in the 2002 owner's manuals it is labelled accessory delay ) later years are labelled as the power window circuit breaker.
Hope helped with this. Remember rated this help, good luck.
Nov 24, 2009 | 2003 Ford Explorer
Circuit Breakers Comparison
A circuit breaker is an automatically-operated electrical switch designed to protect an electrical circuit from damage caused by overload or short circuit. Unlike a fuse, which operates once and then has to be replaced, a circuit breaker can be reset (either manually or automatically) to resume normal operation.
Aug 27, 2008 | HOOVER ROCKER SWITCH W/ CIRCUIT BREAKER
Staples EPS611X (CrossCut) Shredder Logo
242 people viewed this question
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Tom Chichester
Steve P
Steve P
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
