Question about Dryers
FSP G4AP0401 TF 091C THERMAL FUSE - Dryers
Dryer runs, no heat, element OK 10.5ohm, Hi limit thermostat .8 ohm, next one is thermal cutoff or operating thermostat, open no meter readings. Part # FSP 3399848 could this be my problem? Thank You
Both the Thermal cutoff and the operating t-stat should have ZERO ohms resistiance 0.8 is fine but open on either they are bad
That part number you have listed is what ya would need..even if only the thermal cutoff is open replace both the thermal cutoff and high limit t-stat at the same time
also if the cycling t-stat is open replace it too...if its fairly modenr and hasa digital display the cycling thermostat is a thermister and at room temp that will be about 5.8 thousand ohms
if has timer the cycling t-stat will look like the high limit t-stat and should be closed
GENE
Aug 29, 2011 | Dryers
I have ikon webcam model no ik-091c but i have lost cd installer so how can download
Right click on My Computer>Manage>Device Manager> then select your camera device
Right click on camera driver (yellow) open properties>select Details
On that window select Hardware ID as on the picture
Copy Hardware ID and paste in google then search, you can easily find out your exact driver..
Thank you
Aug 27, 2011 | Computers & Internet
Looking for a thermistor. Only part number on it is d242 zavr and it labled 240 degrees C. Finally tore it down and this is where the votage stops.
Hello Pfeuti,
The only way to fix the unit you have is to purchase the whole assembly. Here is a link to all available parts that can be purchase in a blown up form http://www.ereplacementparts.com/waring-wmk300-waffle-maker-parts-c-120019_120354_120541.html
Thank you for choosing FixYa.com
Justin
Mar 10, 2011 | Waring WMK300 Professional Belgian Waffle...
What is the thermal fuse temp in a Nutone 665rp heater?
Our thermal fuse blew as well, and my son was able to read the small print. Mine is a MicroTemp SRCAXK G4A01 TF 100, which according to the ThermoDisc website appears to have an open temperature of 100C (212F).
Dec 11, 2010 | Broan-NuTone 665RP Electric Compact Heater
I have a protron PLTV 3250 I was watching Tv and the TV went out.
no it is your power supply it may have primary power but if you look closely you will see several puffed up capacitors these blow because of the fet near by let go and is not avail you can get a new supply for about 60 bucks from ramplus.com get the fsp number off the supply ex fsp-194
Sep 18, 2009 | Protron PLTV3250 32 in. LCD Television
TRYING TO FIND THERMAL FUSE. MICROTEMP G4A00 TF216C
Unfortunately, YoTeach's initial solution is in error, I believe. YoTeach mentions that typical temps for brewing water are less than 200F, and THAT seems OK, from a couple of quick searches.
However, the component that is being replaced is not necessarily working at the same temperature as the water needs to be.
The Microtemp G4A00 series has lots of temperatures, and the TF216C means, AFAIK, that Tf is 216C(elsius). See, for example, the datasheet here:
http://www.farnell.com/datasheets/625786.pdf
Tf is the temperature at which fuse opens. So, the person ACTUALLY needs a thermal fuse that opens (breaks the connection) at 216C.
Therefore, either of the two fuse temperatures mentioned: 128 & 140C, would open too soon: i.e. at too LOW a temperature.
While 216C may seem like a high temperature (420F), for the fuse to open, the thermal fuse is often very near the heating element. For comparison, I have a Gevalia CM500 coffee pot, and the thermal fuses in my particular unit are Microtemp G4A00 184C- which is about 363F.
If anyone thinks I am in error on this, please feel free to contact me: jim underscore peak at Hotmail dot com - and I'll be happy to correct this post.
Aug 29, 2009 | Krups Small Appliances Espresso Machine
My gr31sb grill wont heat up, i found the microtemp g4 thermal fuse is bad by by passing it and the grill works. how do i get a new fuse?
Don't know if this helps but Radio Shack has Microtemp 10 amp G4A00 Tf 144c (144 deg Celcius) Thermal Fuses. These are the ones with the little red conical end on them. Under $2 each. I needed one to put in my toaster oven. Couldn't find the small metal clips to attach it to the wiring though. Since it is very diffucult to solder these without damaging the fuse, I'll have to recycle the old clips.
Jul 24, 2009 | George Foreman GR31SB Indoor Grill
THERMAL FUSE BLOWN ON KITCHEN AID KCO100508 TOASTER OVEN. WHERE CAN I BUY A REPLACEMENT ? This Thermal fuse [ 206 degrees C ] is a ceramic housing mounted to a bracket near the oven wall. It contains a...
Thermal fuse is a one time safety device, order by specification. My Kitchen Aid toaster oven has one on the side with the controls marked 206c for 206 degrees Celcius when it blows, and marked with a part number that when Googled was found to be 2 amp. The fuse blows in this sequence: temperature first, then if that fails the regular fuse action will kill the circuit at 2 amps. I called electronic supply places around Los Angeles. $1. 25 later I have my part. Mouser electronics carries them for .44 cents. Placed the new one on the ceramic base of the old one, and am back to using my favorite toaster oven. Will not be using it for broiling again - that is when it got hot and quit on me.
May 28, 2009 | KitchenAid KCO1005OB 1400 Watts Toaster...
Thermal cutoff resistor blown
You can get the part from DigiKey in the US - Phone 1-800-344-4539.  Cost 98 cents each. Details and specification shown below.  This part has a UL safety rating for 10A.
Digi-Key Part Number 317-1139-ND Price Break
50
100
250
500
1,000 Unit Price
0.98000
0.85800
0.57080
0.49000
0.39200
0.34300
0.30625 Extended Price
0.98
8.58
28.54
49.00
98.00
171.50
306.25 Manufacturer Part Number SDJ1 DF192S Description THERMAL CUTOUT 192C 10A AXIAL Quantity Available 4,960 All prices are in US dollars.
Quantity Item Number Customer Reference 317-1139-ND SDJ1 DF192S
When requested quantity exceeds displayed pricing table quantities, a lesser unit price may appear on your order.
You may submit a request for quotation on quantities which are greater than those displayed in the pricing table.
Technical/Catalog Information 317-1139-ND Standard Package 100 Category Over Voltage, Current, Temperature Devices Family Thermal Cutoffs, Cutouts (TCO) Vendor Cantherm Features EN60691 Approved Standard
Temperature 192°C
Voltage 250V
Series SDJ1
Package / Case Through Hole
Lead Free Status Lead free RoHS Status RoHS compliant Other Names 317-1139
317-1139-ND
SDJ1 DF192S
Oct 11, 2007 | Rival RC160 16-Cup Rice Cooker
Dryers Logo
726 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
