Question about Kenmore 22442 Top Load Washer
I need a manual for kenmore 22442100 - Kenmore 22442 Top Load Washer
Have a Kenmore heavy duty super capacity 22442100 type 111 washer. Washer won't drain. How do I locate the drain pump?
If top load, look in the back by the water lines. The pump would be in the frame behind there just follow the only tube besides the water lines. If a front loader look directly below door or on the sides for a little 4"-4" access panel. You will need a small pan to catch water. Open the access panel with pan nearby and unscrew the stopper. Sometimes there's money, or lent blocking that and once you clean it out it takes care of the problem.
Nov 25, 2012 | Washing Machines
I have a kenmore washer top load model#22442100 it needs a new switch for the spin cycle but i can figure out how to get the top off to change it
Welcome to FixYa.
Here`s a helpful link for changing it out, and it covers most whirlpool built washers including Kenmore and removing the screws...locating them can be tricky on some models...this helps.
http://videos.wittysparks.com/id/3098139337
If this gives you any trouble I will try to help in any manner I can of course, let me know. Good luck.
Regards,
Macmarkus :)
May 22, 2011 | Kenmore 22422 Top Load Washer
My kenmore 22442100 top load washer will not stop filling I have to watch it and manually stop water and advance timer past fill cycle please help advise.
your load select switch, has a hose connected to it, it goes to the bottom of tub. This tells water to shut off when it reaches desired water level for load size you selected. This hose gets clogged with soap, you have to open area where switch is, take hose off of switch and blow it out. This should solve your problem. If it does not, then load selector switch should be replaced. I am going with first solution, more common. Thanks
Sep 27, 2010 | Kenmore 22422 Top Load Washer
KENMORE 22442100 WONT FILL UP WITH UP WATER
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
Aug 23, 2010 | Kenmore 22422 Top Load Washer
Some times the washer machine will spin and then
sounds like your clutch is slipping,,,,you can put a #10 washer in one of the clutch spring caps and that stops the slipping! thats a low on cash fix or just replace the clutch ,cost about 40 bucks!
Mar 30, 2010 | Kenmore 22422 Top Load Washer
I have a kenmore washer and pump needs to be replaced. How much does the pump cost model #22442100
I have tried to locate your washing machine model on several web sites, but I can't find it. Are you sure you typed it correctly? You typed a different model number than you indicated in your category. From what I have seen, pumps usually cost somewhere in the $40 - $50 range.
Feb 20, 2010 | Kenmore 22422 Top Load Washer
No agitator action in kenmore 22442100
if your coupler is bad you'll know right away
Apr 02, 2009 | Kenmore 22422 Top Load Washer
Kenmore 22442 Top Load Washer Logo
90 people viewed this question
Sal De
fordexpert
Robert Rankin
