Question about Frigidaire 14 Cycle Tumble Action Washer
LTF2140ES0 washer just beeps three times, wont start
I have a frigidaire washer LTF2140ES0. It will not start, Its beeps three times and thats it. Door locks dont make or nothing. I have tried to run it through a diagnostic check by pushing the option and cancel buttons at the same time and hold but all that happens is the same three beeps. what up with this thing?
  • jdavidc61 Oct 31, 2008
    washer beeps three times , I have replaced the door lock assy. no water in washer at all so i don't believe its a pump issue.it just won't start, just give me the same annoying three beeps. does any one know what iswrong
  • 1,879 Answers
Frigidaire engineers are so smart they programmed it to beep 3 times for door lock problem, draining problem and other problems in the internal electronics and didn't bother to give the users specific info to read off the machine.
Posted on Oct 31, 2008
    Genius:
  • 2,035 Answers
Please use this link and check the error code on your machine :
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/134374100awd_ts.pdf
Good luck....
  • Frigidaire Master
  • 19,396 Answers
Try first unplugging the power cord for ten minutes,
if it still has the error, it is probably a faulty control panel.
Posted on Oct 30, 2008
  • Ginko
    Ginko Oct 30, 2008
    When it beeps three times is often a drain problem.
    Check if there is water inside , and check if the drain filter is clogged.
    If drain filter and drain hose are free, then it can be a faulty drain pump.
  • Ginko
    Ginko Oct 30, 2008
    If there is no water inside the machine, check also the door lock, if the door lock sensor is faulty or stuck you get the three beeps.
SOURCE:
LTF2140ES0 washer beeps 4 times, will not start
The 4 beeps indicates that the washer is getting a door open signal. If the door is closed, then the door lock switch is probably faulty. Check the lock and then the wiring.
See https://www.searspartsdirect.com/model-number/LTF2140ES0/1428/0153200.html for the parts diagram. The door lock assembly is part 8 on the cabinet/top diagram. The washer lock wiring harness is not shown on the diagram; it is on the parts list below part 60.
I hope this helps.
Jul 12, 2018 | Washing Machines
My washer will run for a short time and them stop and just beep repeatidly
Frigidaire washer beeps for no reason, driving us crazy ...
? 1:03
https://www.youtube.com/watch?v=gP51k2bhbbg
Nov 6, 2011 - Uploaded by NatalieJonathan
Our Frigidaire washer keeps giving us ridiculous beeping issues, and for no reason. ... Mine stack dryer above ...
My washer pauses during wash cycle and will not restart ...
www.shopyourway.com > Manage My Life > Questions
The washer will stop during wash cycle and just beep. Sometimes we can turn it off and it will run again. Getting worse ... My washer is a Whirlpool 3.5 cu. ft.
FIXED Whirlpool Duet Washer Stops and Beeps - ApplianceBlog
www.applianceblog.com/.../48786-Whirlpool-Duet-Washer-Stops-and-B...
Jan 16, 2015 - 6 posts - ‎2 authors
It's a front loading Whirlpool Duet Washer 4.0 cu ft, with Tumblefresh ... wet it stopswashing and starts beeping (three beeps, pause, three beeps, pause, etc). ... The clip that holds them into the CCU (I think that's the right term) has a ... with my fingers so I could get a couple loads of laundry done until I can .
Jan 05, 2016 | Washing Machines
I have a Frigidaire electric dryer it won't start and beeps three times I'm not sure what year and make
Good Afternoon Frankie, thank you for your inquiry!
Based off what you have described your Frigidaire dryer is not starting and will only beep three times. This could be a possible issue with your control panel or sensor. I would recommend performing a reset on your washer and you can do that by unplugging the power cord for at least ten minutes. You may also want to check your household circuit and assure that the breaker did not flip or that the circuit has not shorted. If that all appears to be in proper working order then I would suggest consulting with a professional technician for proper diagnosis and repair. This will help you avoid any unnecessary part purchases. -Matt
May 02, 2015 | Frigidaire Dryers
Frigidaire LTF2140ES0 washer lights come on but doesn't start
Hello friend, thanks for your post!
If your Frigidaire washer, LTF2140ES0, is not starting it could be a possible issue with your control panel or door latch. Is your washer showing you any error codes? Double-check to ensure that the door is closed. If it is secure, reset the power to your washer for roughly ten minutes. You can do this by either unplugging it or flipping your circuit breaker into the off position. If the issue continues, it could either be the door lock assembly or a communication problem with the control board. I would recommend reaching out to an experienced appliance tech just to ensure no troubleshooting step has been missed. I hope these troubleshooting tips help you in some small way. -Matt
Sep 25, 2014 | Washing Machines
Fridgidaire front-loading washing machine model # LTF2140ES0 will not spin
Good Afternoon Friend,
I understand that your Frigidaire washer, model# LTF2140ES0, will not spin. To try and resolve your washer not spinning, please try the following:
    1)Check your washer door and make sure it is completely closed.
    2)Check your dispenser drawer and make sure it is completely closed.
    3)Your load might be too small. Add 1 or 2 similar items to help balance the load.
    If the above does not work, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Turn the power back on and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
    -Best Regards-
    WP
Jun 20, 2014 | Frigidaire Washing Machines
When i start my front loader it beeps 3 times when i press 3 times
Good Afternoon Penny, thank you for allowing me to assist you!
I understand your washer machine is beeping three times, however it is inoperable or preventing your washer to function properly? With this information I can better address the issue at hand. Thank you!
Oct 22, 2013 | Frigidaire ATF6000ES Front Load Washer
How do you replace the door switch on Frigidaire ltf2140es0 front load washer?
You will need to remove the wire ring on the door seal and carefully peal back the seal to reach your hand in to hold the door switch as you remove the 2 screws. Then pull it out and unplug wires one at a time and plug into the new one. This is a easy DIY and only takes about 15 minutes.Here is a link that should help Door switch replacement
Feb 05, 2011 | Frigidaire ATF6000ES Front Load Washer
Frigidaire 14 Cycle Tumble Action Washer Logo
3,320 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
