Question about Fishman Classic 4T Pickup & Santos rosewood back & sides.
Fishman classic 4t does not work when tuner is off
2 Suggested Answers
  • 5603 Answers
SOURCE: My Fishman Prefix plus is not working through an
Check the battery in the preamp. Also adjust the eq to see if you might be clipping the frequency you are generating.
ALSO do not overdrive a tuner... they get confused and won't register.
Posted on Sep 01, 2009
I have a fishman classic 4t that the battery isn't making a connection, what can I do? Do I need to replace it in my guitar?
can you tell if there is a wire broken? if you know how to use a vom meter you can check to see if you have continuity if you don't then you have a wire problem & make sure that your battery is good.
Jul 12, 2017 | Fishman Music
How to operate an acoustic fender electric guitar Fishman tuner
If it's the same as mine, the tuner has a little clothespin clip. You clip that on to your guitar's headstock and turn it around till you can see the screen while picking strings. The tuner picks up vibrations through the headstock and with it's microphone and it tells you what it hears. The little needle tells you the note and if the string you're plucking is below that note, above that note or right on. You have to figure out if you're in the right octave on your own.
Dec 30, 2014 | Fender Music
I have a hum that almost disappears when I touch the output jack. It isn't at all related to leads, external influences. I have tried different amps, leads, new battery etc.
As a test, if you can find a system that you can connect with a short lead to a DI box set to "ground lift" and that then goes to an amp or mixer try it and report results. In the meantime VERIFY that your power system is grounded (three wire plugs on the amp) Verify you are at least 6 feet from the amp or other devices generating magnetic fields. I suspect the cause is bad grounding of the amp due to the receptacles or a broken ground pin someplace in the system.
May 03, 2011 | Fishman Classic 4T Pickup & Santos...
How do I tune guitar using intergrated fishman tuner as I have no instructions.
With good battery in the unit. Press the TUNE button. This will disconnect the audio output while tuning. The indicators on the tuner will show the note, including sharps or flat and there will be a red arrow either >
Jan 15, 2011 | Fishman Music
My guitar is great I love it but the built in fishman isys tuner is not tuning my guitar properly and when it tells me my guitar is in tune it is really not at all. Is there a way to fix this ? Please...
Hey There,
If its adjustable its worth checking if the Pitch of the tuner is set right (normaly changed by a + & - button) Any normal tuner should be set to 440 which is standard Pitch.
Hope this is of any help
Jan 10, 2011 | Washburn NEW PRO WASHBURN ACOUSTIC GUITAR...
My Fishman Prefix plus is not working through an amplifier and the tuner will not stay lit
Sep 01, 2009 | Fishman Music
Fishman Classic 4T Pickup & Santos rosewood back & sides. Logo
Top Fishman Music Experts
Matthew Spark
Matthew Spark
rhodesworks
Are you a Fishman Music Expert? Answer questions, earn points and help others
