Question about Price Pfister Plumbing
Price-pfister model 17196-0100G luke warm water
Single handle tub/shower handle. Plenty of hot with tub. Shower starts hot but turns lukewarm.
  • 68 Answers
SOURCE: Single handle Pioneer shower faucet
its the mixing slide in there its stuck u can take it apart at the handle it pulls out shake it if it doesnt move its bad. what happens is over time sediment gets in there and seazes it up. if you take it apart and its not stuck then its ur mixing valve on your boiler is bad good luck
Posted on Dec 21, 2008
blueextc3221
  • 15935 Answers
SOURCE: my price pfister tub valve leaks
there is an o-ring inside the valve that seals. It has failed. They should sell a rebuild kit where you bought it, or dis-assemble, and take the failed oring in to have it matched to a new one.
Posted on Dec 26, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Price Pfister ashfield collection shower single lever.
This sounds like a proper with your water heater. If you just installed this new shower head. First take it off and make sure that the hot water valve is opening fully if that checks out then go to the water heater and make sure the pipes check out ok and also that the heater is ok. Try putting a water heater blanket on it. Also try getting some pipe cover and cover the hot water line so on really cold days or not you will have warmer water
Posted on Feb 13, 2009
SOURCE: PRICE PFISTER TREVISO SINGLE HANDLE SHOWER - WATER NOT HOT ENOUGH
Check the manual that came with the unit and it should tell you how to adjust the max temp inside the fixture. Hope this helps!
Posted on Apr 02, 2009
  • 30 Answers
SOURCE: I have a Price Pfister Model no. 808 DK00 single
It's likely that you have some sediment that has accumulated in the cold water valve and has clogged it. The model number you have cited above is only for the trim (rather than for the valves behind it). Assuming that you have a Price Pfister valve, they don't have built in filters, so you're probably going to have to either clean or replace the valve.
Posted on Sep 18, 2009
I need a replacement cartridge # 17196-0100k for a single handle price pfiser shower valve. where can i order one?
I have a single handle price pfister shower valve Model 17196-0100k .No cold water.It's coming hot on both sides.
Mar 28, 2011 | Price Pfister R89-7PC0 Chrome Portland...
My shower faucet doesn't get hot, only lukewarm. Not very good for a shower in the winter! Can it be adjusted to give more hot water?
I have the same problem but I did notice that I coulnt turn the handle all the way to hot. Can I adjust it and how?
Dec 25, 2010 | Price Pfister R89-7PC0 Chrome Portland...
When turning on the hot water on dedicated hot water faucets, the water is almost scalding. However, when turning on the shower and tub that has only one faucet handle (mixes cold and hot) and put the...
Pull apart the front of the valve and there is a limiter that is set to limit hte hot water, you need to adjust that limiter. I find many valves are shipped with teh setting too cold.
Oct 09, 2010 | Delta & Single Handle Shower Faucet
The cold water stop working in my shower. I have a
Two posebel coses i can think of.
1. the taps plunger is stuck in the off posision or 2. there is dirt loged in cold side of tap.
take off head part of cold tap and c if mabe the rubber is stuck or if u maby see some dirt in the tap ietself
hope it helps
Jul 11, 2010 | Price Pfister R897EBK Brushed Nickel...
How do you adjust temp. water luke warm? This is a single handle. Hot water set at 145.
These type faucets have anti scald dial setting that if you remove the handle you can gain access to it.
Just remove handle and mark or remember where it is and pull it out and reinsert it about 1/4 turn counter clockwise.
It has got marks on it and looks like a little gear.
May 19, 2010 | Danze & Single Handle Tub And Shower...
Only warm water from the tub/shower
You can cap the lines at the tub faucet to rule out tub faucet. It maybe mixing there.
Faucet may be bad also the safety stop will alow you to change water temp it can be tricky to adjust water temp.
May 02, 2010 | Moen 1 Handle Lever Shower Faucet With...
I have a Price Pfister Model no. 808 DK00 single handle bath tub/shower faucet. I am only getting hot water coming out when the handle is turned on. This problem just started. It was working fine for about...
Sep 17, 2009 | Price Pfister R89-7PC0 Chrome Portland...
Swaping Pfister Shower leaver handle
it must be the same model number,most models come in different colors and styles.
Feb 27, 2009 | Price Pfister 01-111 Shower Head, Tub...
Plumbing Logo
160 people viewed this question
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
TED
Level 1 Expert
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
