Question about Canon PowerShot SD500 / IXUS 700 Digital Camera
Cannon powershot sx130 IS lens error
Lens error
t00nz
  • 4738 Answers
SOURCE: Cannon powershot SD1100 IS it displays the
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, or if repair costs close to the value of the camera, they're worth a try.
Posted on Nov 24, 2009
t00nz
  • 4738 Answers
SOURCE: Lens Error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Posted on May 28, 2010
CanonAssist
  • 5 Answers
SOURCE: lens error, restart camera canon powershot
The best thing to do is to first try restarting the camera. Do not push or pull on the lens as this will often cause other issues. Do not blow air in the lens as this generally moves any dirt or dust to the back and it sits on your imaging sensor, you'll end up with poor photos after that. The best thing to do is to have it serviced so it is fixed correctly and working the way it should be. The site that is great for the Powershot Models is: www.CamerasAndParts.com They only specialize in these Powershots and they have your exact lens error problem right on the site. Try them for help. They tend to be the best deal plus they're service is wonderful. You'll pay $89 for the repair, all of the service for that model and the return shipping back to you included with them. They'd be the place for help with this one, best of luck.
Posted on Jun 27, 2010
  • 420 Answers
SOURCE: powershot A1100 IS error lens restart camera
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
Posted on Sep 11, 2010
  • 3 Answers
SOURCE: Lens error on Cannon Powershot SD600
i Had that problem a few months ago I accidentally dropped my cam and it said lens error , so I was trying to find a reset on it .., and I found it !! , heres how to do reset your cam : next to the lens there is a tiny hole, now find a pin and press it for 10 secs , but be careful no to get anything sharp because you can damage the reset button, I can't remember if it is 10 secs but that's the reset button mess around with it a little and you will reset your cam . good luck.
Posted on Oct 17, 2010
How to remove lens powershot sx 130 ?
This is a fixed lens camera, you cannot change lenses. If there is some problem with the camera's lens the best advice I can give you is to take it to a camera shop for repair.
Jul 12, 2014 | Canon PowerShot SX130 IS Digital Camera
Memory card stuck in powershot sx130 iscamera
To get the card out. push it down and you'll hear a click and then it will pop up. Check the slide switch on the card to see if it's locked which "might" be causing the error.
Dec 16, 2011 | Canon PowerShot SX130 IS Digital Camera
I bought a Cannon powershot SX130IS and didnt get a users manual. I shouldnt have to buy one. can you help......
Google it. Type in Canon PowerShot SX130 IS Digital Camera manual.
You will get a list of sites but the Canon site will most likely have your manual although you may need to follow a few prompts to get to that level.
Jul 10, 2011 | Canon PowerShot SX130 IS Digital Camera
I have a Canon Powershot SX130 IS and there is dirt behind the first piece of glass in the lens , anyway to clean it?
You shouldn't try to clean this yourself, find a camera shop that does repair or contact Canon, they will direct you to one in your area.
But before anything you better make sure the dust has any impact on the pictures.
May 07, 2011 | Canon PowerShot SX130 IS Digital Camera
Lens error, restart camera
Checkout this tip about digital camera error messages
Lens Error fix for Digital Camera
heatman101
May 04, 2011 | Canon PowerShot SX130 IS Digital Camera
'"The lens of my cannon
This is basically the infamous Canon "E18" error, which has been around for quite a while.
I would type out my own suggestions but since it's such a common error I'll just direct you to a nice long list of solutions already compiled elsewhere: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Mar 01, 2011 | Canon PowerShot SD1000 Digital Camera
My Cannon SX130 Lens is not closing properly or opens properly it got stuck in half way
this happens due to some sand particles getting stuck in lens assembly. give a small **** to the camera so that it gets released.
if not take it to service center in your area and get it repaired.
Jan 15, 2011 | Canon PowerShot SX130 IS Digital Camera
Nov 24, 2009 | Canon PowerShot S410 / IXUS 430 Digital...
Canon PowerShot SD500 / IXUS 700 Digital Camera Logo
234 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
