Question about RoadPro RPPI-2500W Inverter
How to install inverter on a 4 battery bank - RoadPro RPPI-2500W Inverter
2 Suggested Answers
SOURCE: Inverter fan kicks on after turning on a light bulb
yes the ic chip tells fan to start up.
Posted on Jul 27, 2009
Dometic brisk 2 AC can it be operated on a 24 volt inverter.
If your inverter puts out enough power, sure. It may drain your batteries pretty fast, though. Check the power rating of your AC and compare it to the power output of the inverter. Add a safe margin for everything else you want to run at the same time.
Oct 29, 2015 | Dometic Rooftop RV Air Conditioner
De inverter switches off indicating low Batteries while according to my monitor ( xantrex charge ) battery bank is 100%. How can I help help it?
use a voltmeter and measure the voltage AT THE INVERTER'S Battery terminals and see if its over 11 volts. You could have a loose connection or a bad cable creating a voltage loss.
Jul 26, 2015 | Victron ENERGY Quattro 24/5000/120-100/100...
Why is induction motor saw blowing fuse shortly after starting?
If it is still trying to run as a DC system, it might be that the positive and negative are reversed.
May 03, 2014 | Saws
I have a #20 charger inverter on my sailboat. It has worked fine for several years. This winter, I replaced the battery bank with 4 Trojan T-105. Batteries are fully charged, new battery wiring and...
Without more information, it could be a number of things. For starters, you might try disconnecting the ground wire to see if that makes any difference. The Xantrex Owner's/Installation Manual says specifically not to connect the inverter's negative *battery cable* to the vessel ground, but if the unit's housing and the negative cable share a common ground somewhere inside the unit, that would be the same thing. The T-105s are great batteries, but since they are 6V, make sure you rewired them correctly, i.e. a pair in series (12V) wired in parallel with the other pair for 450 AH total. Recheck all your battery connections and make sure you didn't blow the inline battery fuse in case you inadvertently made a momentary wrong connection during the new battery installation.
Apr 27, 2010 | Xantrex Technology Heart Freedom 30...
I need to install my inverter 18 feet from my battery
a very thick one,,,like a baby battery lead on your car,,,its a very bad idear to have it so far away from the battery point, you would be far better off finding a closer place to put it as the volts drop off would have a big drop in out put on the inverter,,,also thats one big mother of a fridge to use 3000 watts????
you need a small power station to run it,,and if it do use 3000 watts your inverter is far to small to do the job, read the out put plate on the inverter,,it says 3000 watts max? not all the time,,,,thats about 2000 watts realy running contently and the whire to feed the inverter will need to carry about 30 amps so your car battery is say 90 amp hours plus the volts drop off, you would be lucky to have the inverter running for 3-4 hours before your battery go's is very flat on you!
Mar 28, 2010 | Inverter Aims Pure Sine Wave Power...
When i hook up my 750 watt inverter to my truck do i need to install a isolator or inline fuse? or just connect the 4 gauge battery cables directly to the battery and the inverter?
Yes, inline fuse as close to the battery as possible. If 4 gauge wire were to ground out without fuse, would most likely start a fire or at least damage other existing harnesses (depending on routing) before a person could disconnect battery.
Oct 13, 2009 | Whistler PI-1200W 1200-Watt Power Inverter...
the inverter fan just kicks on to keep the system from overheating. Its perfectly normal.
Jul 24, 2009 | RoadPro RPPI-2500W Inverter
Power inverter
There are 8 40A fuses inside this unit. In the following pics you will see a bank of 4 and another bank with 3 of the 4 removed. I'm currently working on mine as it will cost me more to ship and have Cobra repair than I paid for the unit ($133 to repair). Good luck with your problem
Jun 18, 2009 | Cobra 2500w Power Inverter
I have no instalation instructions for my 2500 rppipower inverter
You should use 2 red and 2 black cables, Install the inverter as close to the batteries as possible and use minimum #4ga cables #2 are better. Keep the cables as short as possible. You will need also connectors, like the ones on the truck's battery cables, attach these to both ends of each cable and crimp VERY well, connect all 4 cables to the inverter first, then the red cables at the positive battery terminals (if 4 batteries use one on each end) then the black cables to the negative posts the same way.
Jan 07, 2009 | RoadPro AC/DC Power Inverter 2000/5000w
Power Supply How To
Because inverters operate from a DC (Direct Current) power source, usually a battery bank (one or more batteries), the battery source will have to be recharged at some point. (Remember that a battery discharged more than 50% is probably close to being dead.) Most cars and trucks recharge their batteries from an onboard alternator. Depending on the inverter load and runtime required, most power use applications will be covered by the charged battery, augmented by the operating alternator supplying a continuous charge to the battery. If the load is large (air conditioner, large draw power tools, large microwave, food freezer, ice cream machine, etc.), the user should verify that the installed vehicle alternator is of large enough capacity to operate the vehicle's power requirement as well as to fulfill the capacity of the inverter load. If it’s not, a motor throttle installation may be required to carry a small load, a larger alternator may be required, or a larger alternator, battery isolator and additional onboard battery bank may be required in order to meet the power requirement of the large load. Remember: it takes 12 DC Amps (at 12 VDC) to run 1 AC Amp (at 120 VAC single-phase) of power because there are voltage and efficiency factors to take into consideration.
Aug 27, 2008 | Xantrex Technology Xantrex Freedom Xmic...
RoadPro RPPI-2500W Inverter Logo
127 people viewed this question
Top RoadPro Electronics - Others Experts
jdthefixer
deton8 von Splosion
Are you a RoadPro Electronics - Other Expert? Answer questions, earn points and help others
