Question about Jwin JD-VD745
Jwin JD-VD745 v1.1-always powers on with low battery-then powers off.
Hi
when i switch on.even with mains adapter.low battery symbol appears on the screen.and player then switches off.
Thanks..............
2 Suggested Answers
petraman7
  • 1175 Answers
SOURCE: jWIN JD-VD745 won't read DVD. It will start but
When the DVD drawer is open you'll see a small plastic lens and a little runner assembly. Clean the lens with a cotton swab dipped in 90% alcohol and swab it dry with the other end. Clean the metal runner with a swab too.
Try a DVD again
Posted on Apr 17, 2010
Stating no disc
Need to replace a new dvd driver is bad. laser is bad.
May 09, 2010 | Jwin JD-VD745
JWIN JD-VD745 won't read DVD. It will start but after "loading", it stops or "no dvd".
Try a DVD again
Apr 17, 2010 | Jwin JD-VD745
I have jwin jd-vd503 it does not work it shows
Jwin JD-VD200 / JD-VD203 / JD-VD500 / JD-VD503
  1. (Open the disc tray)
  2. Press SETUP
  3. Press 1, 3, 6, 9
  4. Press LEFT 3 x
  5. Press RIGHT
  6. A new menu entry appears (Version)
  7. Select it and select RC (0=codefree)
Sep 15, 2009 | Jwin JD-VD502 DVD Player
Blinking power light
I got the same problem too.
Jul 11, 2008 | Jwin JD-VD140 DVD Player
No Power
Hi Rusty,
Open the cover , there must be a blown fuse, replace with another fuse of same value. If still not working take to service centre. This is a case of SMPS power supply failure.
Please vote for me if this is helpful.
Jun 08, 2008 | Jwin JD-VD135 DVD Player
Nesesito un codigo para un dvd marca jwin grasias
Some unlock codes for Jwin DVD players are:
Jwin JD-VD100 / JD-VD703 / JD-VD753
1. Press SETUP
2. Press PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER
3. "VerX" is displayed (X=RC)
4. Select the RC with RIGHT and LEFT (255=Codefree)
5. Press RETURN
Jwin JD-VD120
1. Press SETUP
2. Press 1, 3, 6, 9
3. Current RC should be displayed
4. Select RC with UP, "DOWN" (0=codefree)
5. Press ENTER
Jwin JD-VD130
1. Method 1:Press SETUP
2. Press 1, 3, 6, 9
5. Press ENTER
1. Method 2:Open the disc tray
2. Press PROG
3. Press ENTER 3 x
4. A menu should appear.
5. Select RC with UP, "DOWN" (0=codefree)
6. Press STOP
7. Close the disc tray
Jwin JD-VD135 / JD-VD147
1. Open the disc tray
2. Press SETUP
3. Press 1, 3, 8, 9
4. Use Up/Down keys to change the region
5. Press SETUP
Jwin JD-VD140 / JD-VD501
2. Press 2, 8, 1, 2
3. Use the arrow keys to change the region (9 = multiregion)
4. Press SETUP
5. Close the disc tray
Jwin JD-VD145
2. Press 9, 7, 3, 5
3. Change the region
2. Press SETUP
3. Press 1, 3, 6, 9
4. Press LEFT 3 x
5. Press RIGHT
Jwin JD-VD138 / JD-VD504 / JD-VD602 / JD-VD603 / JD-VD745 / JD-VD903
no known hacks
or you can try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 18, 2008 | Televison & Video
Locked keys
Hi. I have a different Jwin model radio to yours, but they might have this in common: is there a 'hold' button on yours? If so, this is used to 'lock' all the buttons so that you don't switch it on/ change stations etc accidentally. Look for a 'key' symbol on your display, and press AND HOLD the 'hold' key until the symbol disappears. Pressing the 'hold' button briefly will make the symbol re-appear, and lock the keys again.
May 18, 2007 | Jwin JX-M20 AM/FM Radio
Jwin JD-VD745 Logo
59 people viewed this question
Top Jwin Televison & Video Experts
Henry  Thomas
Henry Thomas
Jaime Hernandez
romy sibug
romy sibug
Are you a Jwin Televison and Video Expert? Answer questions, earn points and help others
