Question about Humidifiers
Hi, I need a Operators & Parts Manual for a Komatsu LC755 Crawler Crane
Hi, I am trying to source an operators manual & a Parts manual for a Komatsu LC755 Crawler Crane. Thank you.
Need manual for Crane MD 12840
Try Googling (crane)(MD 12840)(manual) without parens.
May 10, 2017 | Crane Humidifiers
I need the instruction manual..i don't have it and i don't know how to operate the humidifier
http://www.crane-usa.com/manuals/HumidifierManual2008.pdf
This is the manual for all "adorable" crane humidifiers.
Nov 12, 2010 | Crane Frog EE-3191 1 Gallon Humidifier
My humidifier all of a sudden just stopped working. Can you tell me of any common issues and their remedies for this humidifier ?
From the troubleshooting section of the manual (http://www.crane-usa.com/manuals/HumidifierManual2008.pdf):
Problem Humidifier power light is staying red and not turning green Humidifier is working than stops: ? Solution Ensure that water level sensor is assembled properly. ? Clean water float ? Call service center and request replacement water float ? If humidifier does not work at all: ? Ensure it is properly plugged into a power outlet. ? Check that the switch is in the ON position. ? If Power On indicator light does not come on, bring to authorized service station.
Nov 01, 2010 | Crane Frog EE-3191 1 Gallon Humidifier
Need to know how to use it?
Here's the link where you can download the manual, which will have everything you need to know about cleaning it and maintaining it:
May 28, 2010 | Crane Frog EE-3191 1 Gallon Humidifier
I have a WHITE residue all over the room where the humidifier is? what is this?
From the troubleshooting section of the manual(http://www.crane-usa.com/manuals/HumidifierManual2008.pdf): White dust appears and settles outside the humidifier: ? Area tap water may have too many minerals, change to filtered or distilled water.
Jan 14, 2010 | Crane Frog EE-3191 1 Gallon Humidifier
The red ligt on with water inside
FROM TROUBLESHOOTING SECTION OF MANUAL:
Humidifier power light is staying red and not turning green Humidifier is working than stops: ? Ensure that water level sensor is assembled properly. ? Clean water float ? Call service center and request replacement water float
Jan 23, 2009 | Crane Frog EE-3191 1 Gallon Humidifier
Humidifiers Logo
78 people viewed this question
Top Humidifiers Experts
Mack Baxter
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
