PC HANGS ON BOOT
While pc is booting up it hangs just as windows starts to load(every other time).asusp5k-e wifi solo-ap(mb) intel q6700 quad cpu / 4x2g sticks ocz ddr2 pc8500 1066 mem(total of 8g) / nvidia 275 ftw gpu/ pc power & cooling 900w power supply. 2 os on 2 seperate hdd's xp pro & w7 pro.just installed 1.5tb(cavier black 7200 rpm) hdd western digital and installed w7 pro on it/. originally and still have xp pro and wd 1tb cavier green hdd.the problem has been going on since ive owned it was built for me.this problem happens about every other boot or start up.then i push the power reset and it uaslly loads okasus bios 1305.(ami v02.58). ihave tried all kinds of things can anyone help me solve this issue,thanks for all your help in advance.
  • DAVID PRESCOTT May 22, 2012
    my problem is solved.the issue was with my marvell youkon setting in bios turns out i needed to disable it.
    this problem has been resolved.disabled marvell youkon adapter in bios and cured problem.
    Top Expert:
  • 5,032 Answers
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Posted on May 23, 2012
Hi, The situation is My system INTEL PENTIUM
Do you have any extra things plugged into the usb ports? (external hard drive,Ipod,Flash drive) anything like that can sometimes cause pc's to hang at boot they will try to boot to that device instead of your hard drive
Mar 07, 2011 | Dell Inspiron Desktop / Intel Pentium...
Pc hanging
Scan your PC with a good antivirus like avast which support boot scan;it will solve your problem if it is caused virus,worm or malware.
Sometimes system hangs when a porgram start to load during bootup too.
for troubleshooting this,boot your system in sfae mode during startup by pressing F8.Click "start" then "Run" type "msconfig" select "startup" tab untick all the program and restart your system.
PC hangs or reboots due to overheating of the CPU.It is caused by dust and dirt contamination inside.open the system and blow it with a small air blower.
Dec 18, 2009 | Acer Aspire One PC Notebook
Won't boot to bios
I suppose you have reseted the BIOS and it didn't have any effect.
Check in this order (either using similar components or the ones you have in another pc): power source, memory sticks, processor. If all work then the motherboard is malfunctioning - check the capacitors for leaks and bulging and replace them if necessary; or just buy a new one.
Dec 08, 2009 | Intel DP43TF Motherboard CPU Bundle - ...
How do I get into safe mode on a Dell Inspiron 531. PF 8 doesn't do it?I can only get into Setup with PF2. Otherwise the boot up only goes to the DELL screen and hangs there.
You cant get in safe mode because the PC hangs before windows ever try to start.
Try to press F8 multiple times but right after the Dell screen.
Some computer don't like that you press F8 while the bios is loading and just hangs there, maybe its your case.
Oct 27, 2009 | Dell Inspiron 531S (DDCWGA1_5) PC Desktop
Got a Ms-6368 ver 2.1 hangs or freezes on boot up
JUST DO THAT FIRSTLY CHECKOUT YOUR RAM IN YOUR CPU AND PUT OUT THE RAM AND THEN REINSERT RAM IN RAM SLOT
Oct 06, 2009 | Computers & Internet
Intel Dual Core 2.0 GHz Sytem hangs after boot
During your boot screen press the F8 key to boot into safe mode. If that gets you to the desktop run virus/spyware scans. Reply with any results.
Jan 12, 2009 | Bravo Intel Dual Core E2180-2.0GHz 2GB RAM...
Intel cpu ucode loading error
You need to update the BIOS.
Go here to get the update, enter...
Product: motherboard
Series: Socket 775
Model: P5VD2-VM SE
Operating System
ASUS Download Link
Oct 16, 2008 | EliteGroup L7VMM2 Motherboard
Computer hangs after 5 minutes from boot
Check the CPU fan (working) and heat sink as these over time clog up with fluff and dirt overheating CPU also check the rear of power supply for blocked ventilation holes
Jul 20, 2008 | Intel Pentium 4 1.7G, 1.7 GHz...
New Motherboard Problem Pleasee help
Great info furnished, were you doing a VISTA UPGRADE or a separate full install to have a dual boot system.
For now-to get up and running reinstall XP via the CD
Jun 21, 2008 | Computers & Internet
XP-SP2 hangs on boot after installation
I think maybe better uninstalling driver, but leave card in and boot system and let windows find the card(hardware) first instead of wot sounds like windows looking for driver and freezing in the boot up process as it will look for a connection to internet for an update or driver. Normally any usb periferals should be connected after driver installation, but any pci or agp cards inserted first, then driver.
Nov 05, 2006 | X-Micro Technology XWL-11gCAG 802.11g/b...
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
