Question about Amana Dryers
I have an amana ndg8805aww gas dryer, the dryer turns on heats up for two minutes and then stops heating. took the cover off and it ignites but doesn't stay lit. what could be the problem?
SOURCE: Amana gas dryer only heats first 20 minutes
need to know where the heat sensor is located
Posted on Apr 14, 2008
  • 848 Answers
SOURCE: amana gas dryer
check the thermal fuse ........
Posted on Aug 28, 2008
  • 91 Answers
SOURCE: amana alg643rb gas won't stay on
repl/ coils when bad does the same thing that it going on w/ your dryer
Posted on Jan 04, 2009
dragonsthatk
  • 547 Answers
SOURCE: gas dryer burner won't stay lit on maytag dryer
thermo cupple need's to be replaced
Posted on Feb 17, 2009
  • 234 Answers
SOURCE: gas dryer not heating properly
This sounds like the flame sensor is bad to me.
If it does not work properly, the unit will shut off for safety. The machine assumes that the burner did not light and rather than run gas into your house, it shuts off. It may try to start a certain number of times and then shut off.
You may be able to remove and clean it (flame sensor) lightly with a scotch brite pad and it may work properly again.
Otherwise it will need replacement.
This is a very common problem and the part is probably in stock.
Post a comment on your progress as this solution is likely to be useful to many people.
Thanks,
Tim
The problem is not the gas valve.
Posted on May 06, 2009
Hello Fixya, I just moved and my new place has an amana 120-V Gas Dryer, that turns but won't heat. Ignition would bes suspect #1. Any great ideas? Thanks much, Rob
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 31, 2011 | Amana ALG866SB Gas Dryer
Whirlpool gas dryer blows cold air. took back panel off cleaned lint out. Took front cover off, turned dryer on gas igniter does not heat up, or glow model # lgr4634jq0
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 09, 2010 | Dryers
I have an Amana dryer Mod. ALG649RAW. Turn dryer on ignites than flames, but after a few minutes goes out, it will again ignite, but won't flame. Is it overheating? The dryer is vented underground about...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Aug 28, 2010 | Amana Dryers
Have had a repair man out 3 times. Replaced igniter and gas regulator. Dryer will heat for a few minutes then stop heating. When I try to turn it back on, it will not turn on at all for about 10 minutes.
Are you saying the dryer will not start again after a few minutes? That is a motor [problem. Replace motor.
Are you saying dryer starts after a few minutes but will not heat? That is an air flow problem or a gas valve coil problem. Thoroughly clean EVERY single air passage in the dryer and vent tube. If that does not cure it, then replace gas valve coils if the igniter comes on and off.
Jul 02, 2010 | GE DCVH515GF Gas Dryer
Hi, Two problems. The first I believe is rollers - drum clunks when turning. The second problem is it blows cold - no heat. What part is needed to repair this. Thanks.
Well, check the rollers for flat spots, could also be the belt drive pulleys especially if you've overloaded the dryer and caused it to stop tumbling.
Secondly while the front cover is off look at the heating element used to trigger the gas valve ( igniter ) next check out the light or flame sensor, if the pilot flame ignites but the major flame doesn't then the sensor may be malfunctioning.
Jun 14, 2010 | Amana NDG2335AW Gas Dryer
I Have an Amana gas dryer Mod-NDG8805AWW that only intermittently works. I took it apart to clean it and to observe the operation. The ignitor will light up, but the gas valve doesn't send gas through but...
The problem is the dryer coils have failed. They are inexpensive and easy to replace. This video will walk you thru troubleshooting and replacing this. There are also videos of different styles to help with disassembling.
http://appliancehelponline.com/gdryertroublevideo.html
http://appliancehelponline.com/gdryertroubleshootge.html
Jun 02, 2010 | Amana Dryers
Gas dryer Amana Model LGA30AW, rattling noise, no heat.
I was experiencing a similar problem. I just repaired mine yesterday, with the help of this web site. Remove the front bottom panel. The are two screws located on the bottom of the panel. They are there, just slightly hidden. Turn on dryer to heat. Look inside where the panel was. Wait a minute or two and you will see the igniter glow. After a minute or so you might hear a click and the gas valve will open to start flame. After a while flame will go out until it cycles again. If your igniter glows and you hear the rattling noise and then the igniter glow goes out and you have no flame, it might be your solenoid coils are bad. These are the two black round things located on top of the gas valve. Make sure your gas dryer is unplugged. There is a wire clip attached to each solenoid. Unplug them. I needed to pry them off carefully with a flat screwdriver. There is a metal bracket holding those two solenoids in. There are two screws that you will need to remove the bracket. Use a flashlight to see them. Slide them up and off the gas valve. One is a 2 prong and one is a 3 prong. I bought a new set for 26.75. Put the new ones back the same way as you took them off. The is little nips on the top of the solenoid that line back up with the holes of the top bracket when reassembling them. Plug your machine back in and turn on and watch to see if the ignitor glows again and watch for the flame. Put panel back on and enjoy dry hot clothes again. GOOD LUCK
Aug 09, 2009 | Amana ALG331RAW Gas Dryer
Maytag Neptune MDG 5500 AWQ heats sporatically
your dryer has a safety feature that it will not run or heat when the door is opened. It is so no gas fumes are exhauseted into your home. Once the safety is engaged, It will not allow the dryer to restart for a short while. It should clear itself after only a few minutes. Hope this helps, good luck.
Apr 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Gas dryer wont heat
Looks like the gas valve coils are failing. This usually begins to happen later in the cycle as the dryer has run for awhile. You will have to have the coils replaced.
http://tclaundryrepair.com/
Feb 25, 2009 | Amana ALG866SB Gas Dryer
Dryers Logo
116 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
