Question about Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500
How to Seperate the shaft from the engine - Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500
    Sergeant:
  • 316 Answers
Hello d. to seperate the shaft from the engine::remove the center screw in the throttle handle and loosen the others,remove the screw and loosen the metal ring in front of the engine that holds the shaft,pull shaft out and remove the handle,now you can do what you have to for repairs,,
Posted on Feb 19, 2012
How do you seperate a kohler motor from generator on a miller welder?
if by asking this im assuming the generator is face bolted to motor , if this is so , to save from having another front bearing , the gen stator is directed attached to motor shaft , on the far end under end bell cover is the end of shaft , a long bolt goes thru gen shaft to screw into motor shaft , MARK/photograph all the wires you unhook helps a lot when puting back together
Aug 05, 2014 | Kohler Replacement Engine Part Pa-64711...
How to remove engine
Hi
You dont separate drive shafts!
a drive shaft can be removed from the gearbox either by the removal of the flange bolts or...in Rover..a prybar between the flange and the end of the should pop it out. Dont forget to drain gearoil first.
Jul 20, 2014 | 2005 Rover Streetwise
How do i separate the motor from the rest of the unit onan weldanpower 125
Take off the end cover on the generator. There is a bolt that goes thru the shaft that bolts to the engine Once that's out then the remaining bolts on the housing come out to seperate the generator from the engine.
Jun 07, 2014 | Electrical Supplies
How to remove transmission for mercury cougar 1999
Disconnect battery.
Disconnect drive shafts.
Remove radiator.
Disconnect all water and oil hoses from engine
disconnect all wiring from engine.
Undo engine mounts and lift engine and transmission out as one unit.
seperate transmission from engine.
Dec 20, 2013 | Cars & Trucks
How to seperate the engine from the generator
Generators are getting more complicated due to the addition of solid state regulators and capacitors. In the old days, there was only brush pack and diode pack. If you would like to seperate the generator to repair the engine you must make sure not to damage wiring or brushes. You will need to remove the stator first so remove back cover to expose bolts holding stater to bell. Make note of all connections from stator to panel and remove all the wires. Remove brush pack if brush type. Pull stator out exposing the armature. Armature has center bolt to crankshaft (remove bolt). The armature is sitting on tapered engine shaft that may be rusty. Apply oil to shaft of engine directing oil to the tapered part (wd40 or similar) from the bell side and thru the bolt hole. Notice the two sides of the armature that are lamanated steel. Using small piece of hardwood against lamanated part rap solidly with heavy hammer once on each side being carefull not to damage metal or winding. Should pop loose with first or second hit. If no joy, re-apply oil but follow with a shot of carb cleaner. The carb cleaner will make the oil penetrate deeper /faster. Good luck
May 25, 2013 | Electrical Supplies
Putting a clutch and transmission wont seperate
you need to lift the rear of the engine about 2"then wiggle the transmission while pulling out the idle shaft from the flywheel.in other words keep the trans/engine in a straight line when pulling apart.....
Jul 14, 2010 | 2001 Hyundai Elantra
Seperate engine fromgenerator
depending on your model most have a tapered shaft and you need to loosen the center bolt that goes through the generator rotor and into the crankshaft...then you will require either a puller (some models have a ridge that fits a power steering pulley puller perfectly)..or you may be able to pop the shafts apart by giving the loosened bolt a sharp rap with a ball peen hammer
Jun 21, 2010 | Coleman Powermate Premium Plus 6250W...
How do i take clutch fork out. trying to
Im assuming its 5speed, just remove the cables/line, no need to remove the clutch fork out to separate the tranny from the motor, clutch fork only work the throw-out bearing, it stay with the transmission; it little stubborn sometime for both to seperate from one another. just make sure the tranny is well balance and not hanging from the motor while trying separate the two. it will be very difficult trying to pull the tranny away from the motor if its not on the correct level and height and must not have no weight on the transmission shaft. You have to slide the tranny straight out and level from the flywheel, tranny shaft has to come out straight and same way when reinstall.
Sep 24, 2009 | 2000 Honda Accord
What gearbox oil for 1992 K reg Mitsubishi colt
IT IS SEPERATE FROM ENGINE THERE IS A FILLER BOLT AT FRONT OF BOX DRAIN PLUG IS AT THE BOTTOM NEAR THE OUT UT SHAFTS DRAIN IT AND REFILL WITH A SYNTHETIC CASTROL AUTO TRANS FLUID THIS WILL IMPROVE YOU GEAR SHIFTS
Sep 10, 2009 | Mitsubishi Colt Cars & Trucks
Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500 Logo
67 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
