I have connectecd my barcode scanner (metrologic ms951) to my laptop via usb port the scanner isnt reading the barcodes do i need to download a software to get this working?
SOURCE: Metrologic Keyboard Wedge Barcode Scanner (MS5145)
I found a solution. The scanners needed to be reset to default. (via the manual) Thx anyway. Didn't know they could be configured for use without a kboard... That definately bit me once.
Posted on Aug 23, 2007
  • 8 Answers
SOURCE: Datalogic Dragon D101
You could use a ps2 splitter cable to connect both the barcode scanner and the keyboard to the pc. You would also have to use the correct scanner codes to ensure that the scanner is configured properly. Alternatively, you could try connecting the scanner with only the ps2 to usb and miss out the extension cable to determine if that is the problem. If the scanner is a ps2 wedge scanner, it will need reprogrammed with the correct scanner codes for usb.
Posted on Sep 23, 2007
bluegreenash
  • 661 Answers
SOURCE: My RS-232 scanner beeps at the bar code but nothing appears on-screen.
The "Beep" just means that the scanner has been presented with a valid barcode. (nothing more) The scanner has probably not been set up correctly as this is a common issue. the settings need to be set correctly for your environment. you should have a code book with some bar codes in (part of the manual) which can set all the options within the scanner, There is an option to recall defaults here is the electronic manual ftp://ftp.metrologic.com/pub/download/productmanuals/00-02544.pdf
Posted on Oct 04, 2007
penmobile
SOURCE: Metrologic barcode scanner - laser is a dot not a line
This would be a fault with the scan engine. The dot is created when the mirror inside of the scan engine is not oscillating. The best solution is to have the device repaired, hopefully your scanner is still under warranty, or to purchase a replacement. /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:612.0pt 792.0pt; margin:72.0pt 90.0pt 72.0pt 90.0pt; mso-header-margin:35.4pt; mso-footer-margin:35.4pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Posted on Mar 20, 2009
thesuperdude
  • 97 Answers
SOURCE: LS 1902 AND USB CONNECTION
Scan the Set all defaults barcode from the product reference guide and set the scanner to use USB again if required. This should sort out your problem.
Posted on Mar 26, 2009
Drivers for ms5145
A standard PS2 to USB cable will not work with these scanners. You'll need to purchase cable # M009-3MA7C. They are expensive, so shop around for price.
Jun 06, 2012 | Metrologic Instruments Eclipse MS 5145...
What can a metrologic scanner model MS951 plug into?
no mac, Pcs only. Depending on the interface of your scanner it would plug into either a keyboard port with a y cable or a serial port
Apr 13, 2012 | Metrologic Instruments Metrologic MS 951...
Hi.....im using Eclipse Metrologic Instruments, model no.is MS5145 LS USB barcode scanner. now it is not working. whenever i tried to scan a barcode, it red light goes on continously. i also initialized it...
If the kit number : MK5145-71a48 that you referenced above is correct, your scanner is single ended keyboard wedge, not usb. You would need to order the correct cable : MX009-3ma7c from Honeywell to connect via usb.
Sep 14, 2011 | Metrologic Instruments Eclipse MS 5145...
Hello Is there any driver for use this scanner with usb port?. Thanks.
Please go the Honeywell site listed below (as they are the parent company of Metrologic).
The link should take you directly to the software downloads pages for the Metrologic MS3580. The software you are looking for is Honeywell Scanning and Mobility USB Serial Driver...it is 4mb in size.
Please follow directions carefully during installation as these scanners are a little finicky on driver installation.
Please click HERE for the link to the website and then click "software" to be taken to the drivers page.
Hope this helps.
Thanks,
May 09, 2011 | Metrologic Instruments Metrologic MS3580...
Need metrologic MS 951 driver
This scanner does not need any driver. If you connect via keyboard, the connection is transparent. If connecting via RS232, you need a program to receive data in the com port and send the keyboard buffer.
Roberto Martinez
Sep 24, 2009 | Metrologic Instruments Metrologic MS 951...
Scanner makes the right nosie and the ligth come on when scanning but does read the barcode
What type of cable are you using to connect to a host?
You will need to configure the scanner for that type of connection, for example, usb, keyboard wedge, serial etc.
If you have purchased it new, you should have the configuration barcodes on the instruction manual, otherwise you wil be able to download the full manual from metrologic website.
Mar 26, 2009 | Microsoft Metrologic MS3780 Fusion Barcode...
Fail to configure metrologic usb barcode scanner to use virtual RS232 port interface
First check the com port speed of computer port which you connected scanner .Com port speed should be 9600.
To change com port speed in computer go to computer/properties/device manager.
Select the ports eg com1 .Right click communication port go to properties and select port settings Bits per second should be 9600.
Serial scanner can not be test in word or note pad.you can download the RS232 software from below link and test the scanner
http://www.lookrs232.com/
Oct 30, 2008 | Metrologic Instruments MK9540...
Voyager scans into hyer terminal but not Notepad
Did you read the installation and configuration manuals? I download them from this website:
http://tinyurl.com/359pwh
Your scanner might note be configured correctly.
here are the guides I downloaded:
http://tinyurl.com/2sakgf
http://tinyurl.com/33gh4g
And the MFG website where you can download the material:
http://www.metrologic.com/corporate/products/pos/ms9520/
The scanner and host system must use the same communication protocol. I have a feeling the scanner is not configured correctly. The USB and serial connectors are 2 different types of configuration, but there are more.
You can also download the drivers and POS software from there website.
Feb 14, 2008 | Metrologic Instruments 9520 Voyager
Metrologic USB Voyager scanner
refer the manual and scan the default barcode and scan the usb interface barcode properly.
Feb 01, 2008 | Metrologic Instruments 9520 Voyager
Oct 03, 2007 | Metrologic Instruments 9520 Voyager
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
