Question about Plumbing
Repair cartridge moen 4600 bathroom sink - Plumbing
  • 6 Answers
SOURCE: can't remove moen bathroom faucet assembly to
If you are dealing with the type of Moen faucet I think you are, what you need to do is remove the pop-up rod. do this by loosening the locking bolt on the linkage under the sink and pulling the rod out from the top. Once the rod is out you will need to find the correct size allen wrench which goes into the center hole. there is a mounting bolt in there that needs to be unscrewed. Easy when you know how.
Posted on Jun 17, 2009
snap101
  • 117 Answers
SOURCE: I just installed a new cartridge in a moen single
try and pull the cartridge out and look in there with a flash light and make sure there isn't any think lodged in the hot water side of the faucet, you might even want to leave the cartridge out and turn the water back on to try and flush it out. alot of times rubber from the old cartridge gets stuck in there as you are pulling the old one out especially if it's stuck in there good
Posted on Jul 29, 2009
  • 82 Answers
SOURCE: I have a slow leak coming from the spout
ooops, didn't mean for that to be a request, sorry...It was a solution. Although, if you dont want to deal with Moen, you can get one at your local plumbing suplly store. I recommend taking the old one with you (make sure you shut the water off first!). Again, good luck
Posted on Sep 03, 2009
  • 3 Answers
SOURCE: I have a Moen Monticello bathroom faucet. I am
Moving left to right: I am not an expert, but I have installed a fair number of faucets. Seems like a basic issue of just getting under the sink and tightening up. Make sure someone is topside to assure the faucet stays straight and does not move as you tighten up below. It is never easy to get a wrench and your hands in the proper position to tighten up the nut, but don't give up try a smaller Channel lock wrench if necessary.
Sink Stopper: http://www.lowes.com/lowes/lkn?action=howTo&p=Improve/PopUpStop.html
Posted on Jan 03, 2010
  • 94 Answers
SOURCE: leaky moen 2 handle faucet
if memory serve's me,you will need to remove a stem extension,screw in center,and you may need a tool #103462 to remove cartridge.1'st stem ex't is red,(hot) blue (cold), remove, look down,white piece w/ 2 notch'es, this hold's cartridge down, ya might try needle nose plier's to remove,a little lube help's upon re assembly, carefull w/plastic thread's
Posted on Apr 26, 2010
What is the proper repair cartridge number for my Moen model 4700 bathroom sink faucet? On Q&A I find #1200 or #1225 but don't know which fits what. I'm unable to find it on Moen's website.
Fixya is unable to provide replacement parts information. Try contacting Moen directly; you may be seeking discontinued parts information.
Jul 14, 2017 | Moen Plumbing
I need replacement part for bath sink cartridge 4570
The Moen 1225 or 1200 cartridges are the same except the 1200 is brass in stead of plastic. They will fit most Moen single handle faucets. If it is a two-handle faucet, the 1224 cartridge will fit most two-handle models unless it is a fancy widespread faucet more than about 15 years old. I don't know the model numbers for those cartridges. All of these cartridges require a removal tool if you can't get them out with a pair of pliers.
Dec 09, 2011 | Moen Soap & Lotion Dispenser 3910S
Moen 2 handle bathroom faucet is leaking out of base of the left handle
There is a plastic retainer not with two tabs used for removal. You will need a removal tool to get this retainer off. Any plumbing supply that carries Moen should have this tool.
After removing the retainer nut, the cartridge pulls right out. Good luck!
May 23, 2017 | Moen Kingsley Two Handle Bathroom Sink...
My classmate
Moen Monticello 4-inch centerset bath faucets can be repair easily with only a screwdriver and adjustable wrench. Turn the water off to the both sides of the faucets under the sink. Open both the hot and cold-water valves to alleviate any remaining pressure. Remove the handles by grasping the base of the handle and turning it counterclockwise.( This works for both lever and cross handles). Loosen the Moen faucet cartridge bonnet nut with an adjustable wrench by turning it counterclockwise to the left. Pull the stem from the faucet by hand and replace. Reinstall the bonnet nuts and handles. Turn the water back on and test the faucet for leaks. The Moen Monticello faucet comes with a limited lifetime warranty. Try calling Moen to get your replacement parts free.
Dec 09, 2010 | Moen Bathroom Sink Faucet - 4-inch...
We bought a home and our spare bathroom shower does not work. we replaced the moen valve and still cannot get water to come out of the shower. the toliet and sink in that bathroom work as they should. and...
did you install the valve sideways or upside down? or is there a blockage in the hot line? the valve may be pressure balanced so if there is no water then there may be a blockage on one side. did you solder the valve? if so did you remove the cartridge? when you replaced the cartridge did you grease it with non-petroleum grease?
Dec 03, 2010 | Moen & One Handle Tub & Shower Faucet
Trying to put new cartridge in my moen bathroom faucet and i don't know how to do it. It is a teardrop one handle faucet. Please help a single woman not have to call a plumber!!!
shut water off under faucet,open it to prove wtr is off. pry off cap , slide edge of putty knife,butter knife.etc should see a phillip's screw.remove,pull handle off, pull chrome sleeve off, now. toward's top you should see a little tab sticking out, it is part of a horse shoe shaped clip,pull with needle nose plier's,or similar.pay attention how it come's apart ,your new cartridge come's w/detailed instruction's,calmly refer to 'em, you may need or may not need a moen cartridge puller,(use a good grip,steady pull,)
Apr 25, 2010 | Moen Bathroom Sink Faucet - 4-inch...
How do I get to the valve cartridge to replace it?
how to replace moen cartridge for two handle kitchen faucet ... cartridge for two handle kitchen faucet exporters,how to replace moen cartridge for two handle kitchen faucet suppliers,how to replace moen cartridge ...cn-faucet.com/ kp-how-to-replace-moen-cartridge-for-two-handle...
Mar 17, 2010 | Moen Bathroom Sink Faucet - 4-inch...
Leaky shower knob
Absolutely the same as the shower excluding the obvious difference in supply cut offs.Thanks for using Fix Ya.
Mar 02, 2009 | Moen & One Handle Tub & Shower Faucet
Plumbing Logo
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
