Question about One For All URC-8910 LCD Remote Control
Sony S300 blu ray Direct TVRC 64 remote codes
Wondering if you can give info on programming the sony to work with the direct TV remote listed above? The codes from direct TV don't seem to work
Thank you,
Tammy Pettis
robotek
  • 1512 Answers
SOURCE: blu ray S300
the standard code for Sony DVD for this remote is 0533
try that and see, they had not invented blu ray when this remote was engineered :) you can download the manual and codes for it from
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/one_for_all/urc8910-manual.zip&area=other
a "fixya" rating would be great for my time spent researching this for you. Thanx
Posted on Jan 14, 2008
Mediacom 1056B03 remote control code to program a sony blu ray player
Thanks! Code 1516 worked to program my sony bdp :)
Feb 11, 2013 | Televison & Video
Direct TV remote "tv input" button won't work with my Sony TV
I came across this looking for a similar solution for my Samsung TV, and I found the solution on ehow.com. Apparently after you program the remote for your TV you have to hold mute and select again until it flashes twice then put in 960 to make the remote control TV input too. Note you're remote should be in TV mode while you do this. It seems silly that the DirectTV guy wouldn't do this when programming the remote.
Aug 17, 2009 | Directv RC-64 Remote Control
Need programming instructions for RCA RCR4383
Quick answer:
(TV) Citizen............1004, 1013, 1035, 1046, 1061, 1078, 1103, 1123, 1126, 1127, 1133
Note: The actual manual doesn't provide the codes, but can help you assist in programming the code into your remote.
Resource used:
http://www.rcaaccessories.com/rcaaccessories/RcaaccessoriesInfo.do?findManual=RCR4383
Manual(direct pdf link):
http://audiovox2.info/docs/rca_acc/man/RCR4383_DOC_OM.PDF
Code List(direct pdf link):
http://audiovox2.info/docs/rca_acc/man/RCR4383_DOC_OTHER.PDF
Aug 08, 2009 | RCA Universal Remote Control
I need the code for a Philips SRU3006WM/17
Codes listed for Sony DVD players are 0300,0400,0500,0541,0200,0540. Hope this helps due to no listing for Blu-Ray players.
Mar 29, 2009 | Universal Remote Control 6-Device...
Have sony RM-AV3000 need code for direct tv Hr20-100s
how to program the remote control sony model RM-AV3000
Nov 19, 2008 | Sony RM-AAP001 Remote Control
RCA DIRECT TV UNIVERSAL REMOTE CODE FOR SONY TV
If you have the RCR450 remote, the manual is here =>
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr450-manual.zip&area=other
The codes for Sony TV are 1002, 1218 listed in the back of the manual.
Nov 08, 2008 | RCA RCR450 Remote Control
Cant program directtv remote to sony tv
See if this web sight helps in your problem
Good Luck and have a great day.
RCA Universal Remote Control-Programming Codes
Ed
NC Electronic
Mills, Wyoming
Jan 25, 2008 | RCA RCR311B Remote Control
Blu ray S300
Jan 14, 2008 | One For All URC-8910 LCD Remote Control
Olevia 232t remote code
Go to Best Buy and buy the DirectTV Universal Remote Control Model RC64 ($20). It will control both the Satellite Receiver and the Olevia TV (Everything on the Olevia except the A-B-C-D Guide buttons). The Remote Control User Guide lists the control codes, four for the Olevia. The codes are:
Satellite Receiver: 00392
Olevia 235-T12: 11610 (last of the four codes listed for Olevia)
Enjoy!
Nick from Ft Myers
Dec 21, 2007 | Directed 434MHZ Remote Control
One For All URC-8910 LCD Remote Control Logo
157 people viewed this question
Top One For All Televison & Video Experts
Electro Med Services...
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
