Electrolux EOG9330 Gas Double Oven
Problem for Electrolux EOG9330 Gas Double Oven
How do I clean the inside of the door window of my self-cleaning oven?
By Janstim on Oct 26, 2008
The oven in question isn't a year old yet. The self-cleaning process (3-hour cycle for the first use late last spring, if I remember correctly--whatever the directions said to do for the first time, a 4-hour cycle after Thanksgiving last fall and a 3-hour cycle for the second cleaning a couple of days ago since it wasn't very dirty) only melts the grease that is on the inside of the oven door window but doesn't "make it go away". Otherwise it does a lovely job of cleaning. What solution, method or combination thereof can I use to remove this now brown goo from the interior window without causing any damage or problems? --thanks!
Grease and spattering of any kinds that hits the over door bakes on to a thin sandpapery film.  The self clean cycle does not clean it, soaking it in soap, or using windex also does not clean the interior window.  The oven is one month old.
Solution #1
posted on Oct 26, 2008
Not Helpful)
aborcass
Rank: Guru
Rating: 89%, 2406 votes
umm. there will always be some assemblence of grease on the door glass, if its on the inner most panel and you can scrub it off, then i would reccomned using a razor blade lying flat to scrape it off, however if it has developed within the panel(s) of glass then the only remedy is to dissassmeble the door and glean them that way.. there was some conflict as to the age of your machine in your description, you say "3-hour cycle for the first use late last spring, if I remember correctly--whatever the directions said to do for the first time, a 4-hour cycle after Thanksgiving last fall and a 3-hour cycle for the second cleaning a couple of days ago since it wasn't very dirty"" so i cant be a mont old??? reason i say is that is the unit you purchased probably come with a pretty kickin warr and the manufacture will want ot make good on your issue if you cant resolve it, betterchance though if only 1 month not 11
Was this helpful?
Yes
No
Popular Solutions for Electrolux EOG9330 Gas Double
Questions and Unsolved Problems for Electrolux EOG9330 Gas Double
Do you recommend Electrolux EOG9330 Gas Double Oven?
Answer
Answer
fan does not work when i use oven or grill, the oven just heats up and then overhaets, do i need to... (More)
Answer
when i use the oven or the grill; i put on the switch gas .the lightern begin to sparks and never... (More)
Answer
lightern doesnt turn off it stays on when i use the oven or the grill help me pleaze to solve it
Answer
my electrolux double gas oven drips from the bottom on to housing door. I had repair men around who... (More)
Answer
eog9330xn Gas oven with grill decided not to come on .. ie no electricity > Any suggestions as I... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Ovens Experts
Top Range & Oven Repair
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
(972) 859-0929
Honest, Dependable, Available &...
Accurate Appliance Repair & Parts Supply
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
