Question about RCA F32649 32" TV
RCA 36" making loud pop then screen goes black
My TV is about 4 years old. Recently, I noticed it was making a loud, static-like popping noise, loud enough to distract you from the program. Now, when the pop happens, the screen goes blank. The picture comes back quickly. I've checked the cords and connections, switched outlets but the condition persists. Any suggestions?
    Genius:
  • 1,694 Answers
HV transformer bad = please provide service number from back of set if you want the RCA part #.......T
Posted on Oct 25, 2007
I have the same issue with my RCA 32". I opened it and found that there is a component that has a piece of the rubber coating missing. I am now attempting to recoat the piece with some more rubber. I will let you know the results, but it is not carbon on mine. Mine is clean of carbon. I think this is your issue.
Posted on Oct 21, 2007
  • Leo730 May 23, 2014
    I wound up replacing the transformer. Its not a rubber coating, its actually ceramic. It was arcing bad when I had the unit open and this happened. I desoldered the old one, and soldered in the new and didnt have an issue again before I replaced it/gave it away.
    Novelist:
    Champion:
  • 275 Answers
It seems that there is EHT Leakage from the EHT Transformer Anode Cap! Generally happens during rainy seasons, or if your TV is placed near a window or near an AC, due to excess of moisture in the air. Unplug the TV and wait for an hour to discharge all residual charge in Capacitors. Open the back, and look for a thick red cable leading from the FBT. (It is a Black Block with a thick red cable running from it to the rear of the Picture Tube). Take a sturdy Electrical cable with the conductor visible at both ends. (Multimeter Leads will do.) Now, ground one end of this lead to any Metal part of the Chassis, and gently ease the other end under the Cap of the EHT Cable. BE VERY CAREFUL, as there are very High Voltages involved! Do it Gently, and you will hear a POP! This indicates that the Electrical Charge inside tha Picture has been discharged. Now Take dry cloth and wipe clean the area around the Anode Cap. Close the back of the TV, and switch it ON. In all likelihood your problem should be resolved. BUT, I REPEAT, DO NOT DO THIS UNLESS YOU KNOW WHAT YOU ARE DOING, AND ARE VERY VERY CAREFUL. Otherwise, seek professional help!
Posted on Aug 22, 2006
4 Suggested Answers
snakehead
  • 1074 Answers
SOURCE: popping noise
The anode cap on the back of the tv tube is leaking the high voltage be careful as going into the back of a tv it store very high voltage and could be fatal.the solution to problem get a tube of clear or red silicone discharge the high from the tube,you do this by getting a alligator clip with wire attach clip to a ground wire on the back of the tube attached the other end of the wire to screw driver gently push it under the Anode cap you will hear a popping sound with i little sparks. remove the cap from off the tube get some alcohol wipe the dirt away apply the silicone around the anode and the anode cap place in on back and leave it to dry and cure for about 7 hrs close up back and turn on your tv and all the popping sound is gone.good luck.but if it is the wire for the anode cap that comes from the flyback is the one leaking change the flyback.again good luck.contact me on fixya.com or email me at nicodhem@yahoo.com
Posted on Apr 24, 2007
  • 30 Answers
SOURCE: 32 RCA makes popping sounds
It needs a new FLY BACK transformer. That is what you are looking at. The origionals are not made for the set any longer but insist on having a generic on installed by a local TV shop. I just put one into a RCA 31" and it works nice. Don't throw away the TV. Get it fixed. MAKE SURE YOU INSIST THEY USE THE GENERIC ONE! THEY DO WORK!
Posted on Aug 03, 2008
SOURCE: my 36' RCA TV JUST QUIT WORKING. TURNED ON POWER
my 36" rca green light blinks 3 times, no picture or sound
Posted on Jun 02, 2009
We have a Protron TV that is about four years old. In the last month, we noticed that when we power it on that it starts crackling and making static popping sounds for about a minute and then the noises...
Look for popped capacitors that would make the values lower than need be for the tv to power on properly.
Once you repair the power supply then you may need to replace other components if needed (EX: backlight inverter)! The backlight inverter is what lites the screen for viewing!
I would recommend to repair immedately and stop trying to turn it on over and over...this will futher damage your tv and cost more to repair in the long-term.
This is dangerous as it can spark and may start a fire!
Please rate if this helps! :D
Mar 10, 2011 | Protron Televison & Video
TV has been getting static fuzzy lines, like snow in the picture increasingly bad. Now makes a pop noise, goes black for 2 seconds and comes back on. Thank you
Time ofr a new tv. The guns or gun control system is goign bad. Before it results in something worse ust replace the unit. Cost of repair is not worth the price.
Mar 02, 2011 | Sony FD Trinitron WEGA KV-36FS120 36" TV
No Picture, Power light Blinking 3 times then repeats
3 times blink shows lamp cover is removed or not installed properly on TV.
Please take out lamp inside TV and check, seems its broken as you heard loud pop.
Thanks.
Aug 28, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
My Model # F36669, about a 5 year old 36 inch (non flat screen) RCA T.V. is popping loudly in back and turning off. I looked in back and noticed the popping noise is a short or something that is causing an...
That my friend is the high voltage transformer with a tiny pin hole allowing the high voltage to arc to ground. The red wire going to the picture tube is carrying 30 thousand volts to the anode connection on the CRT. This is not a consumer replaceable part as the CRT can retain healty voltages even when off. Refer to a local TV technician.
Aug 14, 2009 | Televison & Video
RCA HDTV DLP 50'' TV Goes Blank!!!
The bulb went out, The clicking is the ballast trying to start the bulb
Jul 12, 2009 | Televison & Video
My 36' RCA TV JUST QUIT WORKING. TURNED ON POWER
A shorted horizontal output transistor or shorted flyback. If the flyback is shorted replace also its HOT.
Apr 05, 2009 | RCA F36650 36" TV
Rear screen tv
replaced flyback transformer
Sep 17, 2008 | RCA F36650 36" TV
F36650
Bad flyback transformer = 257805 or Asti 2078..........T.
Please rate this solution.................
Nov 05, 2007 | RCA F36650 36" TV
RCA 27" TV F25432
You apparently have a high voltage arc. Possibly the anode lead to your picture tube. Also the flyback transformer could be arcing. If you're not experience with tv repair, you need to have a tech check it for you. The circuits operate at very high voltage and if you get into it you can get a possibly fatal electrical shock. Be careful !!! Stargazer
Jan 11, 2007 | RCA F27645 27" TV
RCA F32649 32" TV Logo
422 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
