Question about Air Tools & Compressors
Can you source nails for a Hitachi VH 650 Coil Nailer
  • 425 Answers
I am not positive but I believe the Duo-Fast CI series, plastic collated nails may work in your Hitachi. At least worth a try.
Posted on Mar 06, 2012
Testimonial: "Thanks Brad for the info about the coil nails,I'm trying to track these buggers down,I"m not optimistic simply because if they are difficult to get in america they are going to damn difficult to get in Brisbane,I will be trying Tokyo next. Sean"
  • 3 Answers
SOURCE: Hitachi Framing Gun Not Firing - Bad Battery?
Does the fan run and the light blink ont he nailer? I have one that I just bought. I put in the wrong type of nails and got one stuck. I had to take the front apart to clear it and now the damm thing wont fire. The green light blinks and the gas cartridge is basically full, even the fan does run after I release the push lever, but no fire???
I wonder if yours is the same as mine did fire for a couple nails first just fine then got jammed...
I will try to charge the battery more.... MAybe like yours it needs a strong charge for the spark...
Russ
Posted on Oct 05, 2008
  • 3 Answers
SOURCE: Stanley bostitch coil nailer gun
check the safty shaft and see if something could be under trigger safty causeing it to fire.
Posted on Feb 20, 2009
  • 67 Answers
SOURCE: Max 890s coil nailer does not advance nails when operated.
Make sure you have at least 100 psi available and I would pretty much drown the sliders and other moving parts in something like Marvel Mystery Oil.
Posted on Feb 26, 2009
odiebugs
  • 949 Answers
SOURCE: have ism coil nail gun what nails do i use where
Somewhere there should be a model #, I have never seen a ISM.
Most all bostitch roofing coil nails will fit there guns.
Below I posted there website where you can check the info on your gun.
http://www.bostitch.com/default.asp?TYPE=CATEGORY&CATEGORY=BOS_ROOFING_NAILER_STAPLER
Posted on Apr 07, 2009
  • 1244 Answers
SOURCE: Hitachi NV45AB coil nail gun is leaking air from
the top!! o-ring inside of thr top plate is bad you need to remove the plate /dissasemble and replace the o-ring
Posted on Jan 21, 2010
Hitachi roofing nailer shoots every other nail & doesn't sink the nails it shoots
i think you have two different problems , replace the feeder spring, and replace the oring on the driver piston. also make sure that the coil of nails is perfectly round if they are dropped or squeezed tool will not work right
Sep 11, 2012 | Hitachi NV45AB2S Coil Roofing Nailer
How do i set the depth on a nv45ab2 hitachi coil nailer
Your owner's manual is available at: http://www.hitachipowertools.com/PDF/All/NV45AB2_NV45AB2S_OM_NEW.pdf
The adjuster knob to set the depth the nail is driven to is on the same side of the gun you load the nail on, just at the bottom of the head and near where the head of the next nail to fire rests. Pull down on and turn the knob counter-clockwise to leave the nail higher in your work or clockwise to drive them in deeper. When you let go of the knob it will spring back up. With it up turn it until it locks into place, usually another 1/4 turn or less.
Dec 16, 2011 | Hitachi NV45AB2 Roofing Coil Nailer
I have a craftsman roof nailer with plastic cover for nails broken where can i get one to fit
Best place for replacement parts is the address below.
Ez to order from and usually only takes 10 to 14 days to get the parts. Click on Hitachi logo then select coil nailers, then your model number. For local parts, look in the yellow page directory for fasteners. Fastener companies that sell nails and other supplies to contractors also have parts for Hitachi nailers. Check with several. Some will even repair the nailer for you if you buy nails from them.
Good luck.
WWW. toolpartsdirect.com
Sep 01, 2011 | Hitachi NV45AB2 78Inch to 134Inch Roofing...
My hitachi nv45ab2 roofing coil nailer misfires and only shoots every third nail
Hitachi coil roofing nailer will skip nails if the piston oring is worn, the feed spring is weak or lower bumper is cracked. Easy to check. Remove nails and air supply. With side door open point nose of gun up then down again. If the piston moves up and down in the cylinder, replace the piston oring. If piston does not move and is in the up position, check the feed spring for tension. With air supply removed and door open, slide feeder back and press on feeder from door side to check tension. It should spring back to position against rails.If is feels loose, replace spring and retainer pin if the pin is worn. If piston oring is good, and the feeder has good spring tension, suspect lower bumper and the plastic part below the bumper called the "sheet". Remove head and pull the cylinder to examine lower bumper. Parts are available at www.toolpartsdirect.com. Good luck with your repair
Aug 09, 2011 | Hitachi NV45AB2 Roofing Coil Nailer
No nail or double nails
Usually due to bent driver, worn driver oring or lower bumper cracked, weak or broken feeder spring. Remove head being careful not to tear gasket. Pull the driver and check for bend in shaft or chipped end. If the end of the driver is chipped or rounded, grind tip flat (remove as little as possible ). Piston should hold position in the cylinder and drop down under its own weight. Examine lower bumper. If missing pieces, replace with new. Lube orings with silicone paste (sold at Lowes in plumbing department). Also check for correct nails. Should be 15 degree metal wire. There is an older hitachi nailer with a metal canister (nv50aa) that uses plastic strip nails. These nails are too close together to work properly in the #nv65 gun and will usually shoot two nails. Good luck
May 13, 2011 | Hitachi 2 - 1/2" Coil Siding Nailer
Hi, when I nail also it leak. when I make a shot, the gun nailer blow for the middle. but when I don't nail it does'nt feel any leak.
Your description makes it clear that it needs a head rebuild kit. You can order this from Hitachi, or send it in to local Hitachi center. Good machine, straightforward repair. If you are a little handy, you can do this repair yourself. remember to oil the gun frequently to make your repair last longest. Farmerbear at FixYa
Oct 14, 2010 | Hitachi NV45AB2 Roofing Coil Nailer
Pieces of the coil are breaking off when firing my Hitachi NV65AH - what causes this?
If you are using wire coiled nails, this is a common issue and there really is noway to stop this, and is advisable to wear safety glasses when ever using a nail gun. I have had 1 of the wires come off a coil and literally pierce my cheek. If it would have hit me in the eye it would have done some serious damage.
Aug 16, 2010 | Hitachi NV65AH Siding Nailer, Coil,...
Can i use any brand coil nailes in my nv 45ab2 coil nailer
Yes. Roofing nailers all use about the same size and spacing on coil nails. You will find that Harbor Freight is about 1/2 the price of Home Depot or Lowes for those nails.
-Jim
Oct 17, 2009 | Hitachi NV45AB2 Roofing Coil Nailer
It will double fire sinking second nail only half way. This happens every third or fourth shot. The nailer is a Hitachi NR 83A 3.25in. X .131
the pin pushing your nails is loose and the guides are warned .
try to change the guides and you will see that this problem will will be gone .
one last thing , make sure the coils are in good shape as it may create some feeding problems and push 2 nails at once
Sep 26, 2009 | Hitachi VH650 2 1/2" Full Head Fencing...
Air Tools & Compressors Logo
60 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
