Question about Frigidaire Affinity ATF7000ES Front Load Washer
Fridgidaire Affinity ATF6700FS1 with door lock error, door lock light is on, and loud buzzing noise.
When started, door lock light comes on and hear door lock engage but instead of starting washing cycle the washer begins buzzing like it can't start. Ran the diagnostic test and receive the E41 error for the door lock. Is there any way to know if it's for sure the switch assembly or the control panel...or do I have to replace the switch assembly to find out it's actually the control panel?
4 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: My fridgidaire affinity front load
The most common thing that causes this problem is a door switch failure...
Check out to see if the door switch is working properly...
heatman101
Posted on Nov 27, 2010
KevinWhite
  • 1902 Answers
SOURCE: I have an Frigidaire Affinity
Hello & Welcome to FixYa
E41 error indicates that the problem is with door lock assembly, it is displayed when the control board thinks that the door switch is open. To solve this problem you have to remove the door lock assembly and measure the resistance of the PTC. If it reads open then the door lock assembly needs replacement however, if the reading is around 1500 ohms then replacing the control board is recommended repair. Please get back to me if you have any other questions.
Kevin
Posted on Aug 01, 2011
Jahn27
  • 1554 Answers
SOURCE: Frigidaire Affinity washer (LAFW3511KW0) with
Install the door lock/switch assembly with the door switch harness disconnected but "jumped". Jump a wire between the wire harness terminals and if the error code (E41) stops appearing when the machine is started, the door lock/switch assembly is indeed faulty and needs to be replaced.
Check the continuity of the door switch harness connecting the switch and terminal J2 of of the control board if the error code (E41) still appears every time the machine is started after putting a jumper wire between the door switch harness terminals.
Make sure the connectors are clean and snugly connected to both. Replace the wire harness if you are skeptical about its condition. Disconnecting the door switch wire harness (J2) from the control board and putting a jumper wire between the leads of terminal J2 on the control board will directly confirm the condition of the wire harness and the board itself. The wire harness is the problem and must be replaced if the error code E41 stops appearing. On the other hand, consider replacing the control board if the error code still flashes even when the leads of terminal J2 on the board is shorted ("jumped").
Posted on Aug 21, 2011
My washer makes a loud buzzing noise model Fridgidaire GLTF2940FE
Good Afternoon Friend,
I understand that your Frigidaire washer, model# GLTF2940FE, will lock the door, start buzzing, and not start the cycle. I suggest resetting your appliance, be either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 26, 2014 | Frigidaire Washing Machines
I have an Frigidaire Affinity Washer Model ATF6700FS1 got error code E41. Thinks the door is open. I tried unplugging the connectors to the door switch but nothing worked. What to do now?
Kevin
Aug 01, 2011 | Frigidaire ATF6000ES Front Load Washer
Makes a loud buzzing noise when attempting to start cycle
The lock solenoid on the door latch assembly may be hanging up or just noisey. If washer starts and runs then all is ok. If washer wont start, just buzzes, then door latch assembly may have to be changed.
Feb 01, 2010 | Frigidaire Affinity ATF7000E Front Load...
How do I reset my Frigidaire Affinity Front Load Washing Machine? When I press a button the ERR code comes on and then it turns off.
My Fridgidaire Affinity front load washer has a ERR pause and I can't reset it. How do I clear this
Jan 17, 2010 | Washing Machines
I have a Figidaire Affinity front load washer. The problem that I am having is I close the door select wash and then push start and dr is on the screen. Can you tell me what is happening?
dr means the door switch is not closed. Thus meaning the door lock assembly is bad and needs to be replaced.part number is 131763245 and price is $48.99
Nov 01, 2009 | Frigidaire ATF6000ES Front Load Washer
Master door switch? or something else? buzzes when i press lock
ok ur door lock switch isnt going out,,however ur drivers front door lock actuator is going or is already bad...have that replaced..also as far as the end noise buzz u hear , that may be ur a.b.s modulator and accumulator cycleing on and off..it may be empty and or leaking..have the a.b.s modulator and accumulator checked at the dealer..its an expensive fix... ur modulator unit in in the front left or right of the vehicle depending if u have a v6 or 4 cyl. its a square unit with a rectangular brake fluid resevroir and a long tubular cylinder (acummulator)... also identify it by the orange connectors...and the brakelines going to it...common symptom with those accords....they leak alot especially if with high mileage..
Apr 09, 2009 | 1996 Honda Accord
Frigidaire Affinity Door Lock
under 1st yr warr, sure if thats he issue they would cover, it, a clogged drain pump may cause the same problem though , not being able to drain water , the pump would just hum.
Dec 03, 2008 | Frigidaire Affinity ATF7000E Front Load...
Loud buzzing sound when trying to start washer, something to do with the door, like it won't lock
the buzzing noise is from a one of the coils trying to come in water coil valve cultch coil something is trying to come in but can not go in all the way so it will buzz . there could be a coil that is failing also . put a screw driver on the noisey coil or part to hear what part is trying to engage . change that part or inspect to se way it is not working proper with out buzzing . hope this helps you
Nov 26, 2008 | Washing Machines
Washing Machines Logo
378 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
