Question about Garmin nuvi 1390T Car GPS Receiver
Updating maps on garmin nuvi 1390t. Won't take 4g/sdhc card
Only allows me partial north American maps. I don't think it's reading the 4ghdsc I have put in the side. Help!
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Garmin Master
  • 102,366 Answers
You are correct. The 1390t works with microSD cards. While microSDHC cards will fit into the slot, they are electronically incompatible.
You need to use microSD cards 2GB and smaller.
Posted on Feb 21, 2012
SOURCE: Nuvi 205w won't read upgraded map
You HAVE to go through software support as this is an issue with the map. They told me it is because the map KEY is wrong, it is only for the united states, but the map is ALL of north america. The wait time is incredibly long, I have been waiting for over an hour, such bad service
Posted on Apr 17, 2009
  • 3 Answers
SOURCE: Installed 2010 North America map in garmin Nuvi
I just got off the phone with tech support. They have a very complicated fix that involves remote accessing into your computer and editing files, etc. They said it would take over an hour and a half, I declined. The problem apparently is that the nuvi 200/205 can't support canada, but the maps contain canada = problem. and btw, i downloaded "City Navigator Lower 49 States+PR NT 2010.10, Deluxe, Apr 09" and got the same problem. this filename ends in a "B", apparently that's the "fixed one" but acc tech support it's only fixed in the sense that they can waste over an hr w' u fixing it, whereas the older files are unfixable.
I'm just gonna wait til they really fix it and upload those files.
Hope that helps.
SOURCE: Garmin nuvi 200w can't update all 49 lower states
OK, I just finally am getting through all of this myself.
First, the bad news. You cannot load all of the lower 49 states onto your Garmin 200W as-is. The map file is over 1GB and the 200W only has 991MBs of memory.
So, go out and get yourself a SD card. I got a 2GB card at OfficeDepot for $8. It was at the counter, not back with the other cards they carry (Note: The speed showed as 60x. The slightly more expensive ones, $12-$15, may be faster, like 150x.)
You'll also need to get yourself MapInstall, available from the Garmin site. BUT, don't try to use this right away, a mistake I made. If you do, you basically get a message that MapInstall can't be installed because it's not already installed. Seriously.
BUT, MapInstall GETS installed, or whatever, when you load your 2010 maps (or partial maps), so after you do your partial install, THEN you can install the MapInstall program. (May not be necessary, but remember, I did this out of order. Look for a "Garmin" folder under your Programs, or All Programs, and see if it's already there after you install your 2010 maps.)
Next, run MapInstall. The next mistake I made was that at the window where it finds your device, I clicked on the NEXT button. DON'T. Notice that your device is shown in a drop-down box. Click on that, and you can select your SD card for the destination.
THEN click NEXT. On my system, it appears as if it shows you what IS already on the 200W, and lets you select whatever you want to add. I put everything else available on the SD card.
I just this minute finished loading "the rest" and checked it out. Works flawlessly. I easily found a seafood restaraunt in Anchorage (Alaska was not loaded in the intitial install.)
Just remember that you have to keep the SD card in the Garmin at all times to use those maps. That really shouldn't be a problem though.
Hope this helps eveyone.
JDCrownover
Huntsville, AL
Posted on Jun 17, 2009
  • 156 Answers
SOURCE: Remove a map to make space on my garmin nuvi 205
I would reset the whole unit to factory specs & then load map.
Posted on Jul 06, 2009
  • 11 Answers
SOURCE: I was working in Taiwan
Search on Google
You will find it.
Oh and im sure that you can leave the Taiwan maps
Posted on May 23, 2011
Nuvi2555LMT
The micro SD card has to be between 4-8gb. Garmin Express is used to load the South American maps. Garmin Express can be downloaded from Garmin. Once installed on your PC, plug your GPS into your PC. The program should give you the option to install the South American maps to the SD card.
Dec 31, 2016 | Garmin nuvi2555lmt nuvi 2555lmt
Garmin nuvi 1390t won't read or recognize microsd
The 1390t works with microSD cards. Your 8GB card is actually a microSDHC card. While it fits into the slot, it will not work in older devices.
You need to go with microSD cards, 2GB and smaller.
Feb 09, 2012 | Garmin nuvi 1390T Car GPS Receiver
Microsd card won't read
You need to use a microSD card, not a microSDHC card. microSD cards max out at 2GB, anything larger is a microSDHC.
Garmin nuvi 3760. I have downloaded North american maps to the SD card but the Nuvii doesn't recognise the SD chip map when I go to tool, maps etc. Help
Update your unit using Garmin Webupdater. The latest updated firmware allows the units to read all sd/microsd cards You can download garmin webupdater from here: http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Download install and run the program and follow the on screen prompts to update your unit.
Sep 27, 2011 | Garmin Nuvi 3790T 3790 3760T 3760 3750...
I bought a lifetime update from Garmin a few years ago but now my nuvi 270 tells me that I don't have enough memory to install the latest maps and that I must choose only certain regions. I have an 8Gb...
The internal memory of the nuvi is full. Some maps will need to be delete before any new maps can be added. Typically, the map in the nuvi is named GMAPPROM.IMG and a map installed to an SD (or SDHC) memory card is named GMAPSUPP.IMG.
1) Remove the SD card from the memory slot
2) Connect the nuvi to the computer via USB cable.
3) Open the nuvi drive.
4) Locate and delete the GMAPPROM.IMG (or GSUPPROM.IMG) file(s). Optionally copy (instead of deleting) them to your hard drive in case there is a problem wit the new map file(s).
5) Empty the Recycle Bin.
6) Retry the map update of the nuvi.
This method will take some time to perform depending on how many map segments you are sending to the nuvi. Transferring the entire map can take over an hour. A quicker way is to send the maps to the SDHC card directly by inserting the card into a card reader. This eleminates the slow Garmin card reader from the equation and transfers are done in a fraction of the time. No maps will be on the nuvi - they will all be on the memory card instead. To update the SD or SDHC card, do this:
1) Repeat steps 1 thru 5 above. This removes the maps files from the nuvi.
2) Disconnect the nuvi from the computer.
3) Connect a card reader to the computer.
4) Insert the SD or SDHC card into the reader.
5) Locate and delete the GMAPPROM.IMG (or GSUPPROM.IMG) file(s). Optionally copy (instead of deleting) them to your hard drive in case there is a problem wit the new map file(s).
6) Update the map to the SD or SDHC card.
When either method is employed, only one map file set will result. GMAPPROM.IMG or GMAPSUPP.IMG is the name of this file set. You should ensure / change the name to GMAPPROM.IMG. Any subsequent file set added should be named GMAPSUPP.IMG.
I hope this helps & good luck! Please rate my reply - thanks.
Jun 27, 2011 | Garmin nuvi 200W GPS Receiver
Jul 06, 2009 | Garmin nuvi 205W GPS Receiver
Not enough space for maps?
The garmin does not have any space on it for maps,any additional maps are stored on a memory
card. I don't see where garmin says the size limit of the card but in most cases unless it says
SDHC memory card,then the max is a 2g sd card, I think the models 500 and over can use over a 2g card.,
Mar 27, 2009 | Garmin nuvi 200W GPS Receiver
Downloading North American Maps
Did you purchase a preprogrammed sd card or did you get software to download into your PC?
If you are downloading and need to enter unlock codes, avoid using Garmin's unlock wizard.  I generally have better luck unlocking from their website.
Oct 25, 2007 | GPS
Garmin nuvi 1390T Car GPS Receiver Logo
733 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
