Question about Apple Computers & Internet
My left shift key on my MacBook Air stopped working (it was gradual). I took the key off to see if anything was stuck underneath but there was nothing there. Is that anything else I can try rather than having to bring it in for repairs? It's no longer under warranty.
  • 536 Answers
Try taking it in to an Apple Store and see what they say. If its apparent that the computer has been well cared-for, then they may take pity on you.
Posted on Feb 26, 2012
Keyboard acts like the shift key is always pressed down
Hi, I also had this problem on macbook air 2011, I tried everything but all failed. However, once I used up all its battery and left it like that for 2 days. After that, everything turned back to normal, the shift key worked normally again. Hope this will help you.
Aug 14, 2012 | Apple aluminum 13-inch MacBook laptop-...
Macbook air Shift key will not disengage. I took it to the Apple store and they want to replace the keyboard. I took it home and took the keys off and checked for anything being stuck under the keys....
Once a key starts getting stuck on a keyboard, it won't be long and more of them will have the same problem. The easiest fix for is to replace the keyboard. Cheapest place to get one most likely will be ebay.
Mar 21, 2012 | Apple MacBook Air
Lap top won't come on
Follow the steps below and it should solve your mac problem..
  1. Disconnect any devices connected to the computer including printers, hubs, and third-party keyboards or mice, and test the computer again by trying to turn it on.
  2. If you're using a MacBook or MacBook Pro, check the battery level. Press the small button on the battery or on the side of the computer. You should see lights indicating the battery's level of charge. If you see just one light blinking, the battery needs to be recharged. Use the fluorescent pen computer with the adapter connected to recharge the battery.
  3. Unplug the power adapter from the electrical outlet and from the MacBook, MacBook Air, or MacBook Pro. Wait one minute. Plug it back into the wall first, then to the computer. Make sure the electrical outlet is working by plugging in another device (such as a lamp). When you plug the adapter back into the computer, the PowerBook G4 Battery 15" power adapter LEDs should light up green or amber.
  4. Inspect the MagSafe port on the computer for debris, such as metal stuck to the magnet in the port, which might prevent the connector from seating properly. On the adapter side, look at the DC connector for dust or other debris and check whether pins are missing, bent, or stuck down. If you find any of these to be true, see Apple Portables: Troubleshooting MagSafe adapters for instructions on cleaning the adapter.
  5. Make sure you are using the adapter that was designed for your computer. If you aren't sure or if you need a new adapter,learn which adapter is appropriate for your computer.
  6. Press the control key, the command key, and the sony vgp-bps13a/b battery power button simultaneously and hold for three seconds to try to restart the computer.
  7. Reset the PRAM. After pressing the power button, hold down these keys simultaneously: Command-Option-P-R, until you hear the startup chime at least one additional time after the initial startup chime.
  8. Reset the SMC for the MacBook And MacBook Pro by removing the AC power, removing the sony vgp-bps13 battery and then holding down the power button for five seconds. On the MacBook Air, press (left) Shift-Control-Option along with the power button once. Note: You must use the keys on the left side of the MacBook Air keyboard.
  9. If you recently installed additional memory, make sure it is correctly installed and is compatible with your computer. Remove the new memory to see if the computer starts up properly without it.
  10. If you are still unable to start up your computer after trying each of these steps, schedule a service appointment with either an Apple Retail Store or an Apple Authorized Service Provider.
Regards,
Ron
Jun 02, 2011 | Apple 13" MacBook Notebook Computer ...
Will not load up or take charge
Try removing the AC power, removing the battery and then holding down the power button for five seconds. On the MacBook Air, press (left) Shift-Control-Option along with the power button once. Note: You must use the keys on the left side of the MacBook Air keyboard.
If that doesnt work try this:
  1. Shut down the computer.
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
  6. Release the keys.
Mar 01, 2011 | Apple MacBook Air
MacBook Air 11" won't power
1. Verify AC power presence with MagSafe LED indicating on or charge state.
2. Verify battery as being partly charged, with orange/amber LED on MagSafe power connector.
3. Reset SMC
Resetting the System Management Controller (SMC) The System Management Controller (SMC) is a chip on the logic board that controls all power functions. If the computer is experiencing any power issue, such as not starting up, not displaying video, sleep issues, or fan noise issues, resetting SMC may resolve it. To reset SMC: 1. If computer is on, turn it off by choosing Shut Down from the Apple menu. 2. Connect power adapter to computer and to a working power source. 3. On built-in keyboard, press (left-side) Shift-Control-Option along with power button just once. Important: Use Shift-Control-Option keys on left side of keyboard. Note: When the LED on the MagSafe connector is orange/amber, resetting the SMC will change it to green for a few seconds, indicating that SMC was correctly reset. 4. Wait 5 seconds and press power button to start computer. Note: If bottom case is removed, you can alternately reset SMC by disconnecting both power adapter and main battery, and holding down power button for 5 seconds.
Power Adapter Issues 1. Connect AC adapter's MagSafe connector to the computer. The LED on the connector should be green or orange/amber. 2. Verify power cord or duckhead is firmly attached to AC adapter. Check that duckhead is not damaged. 3. Verify AC power source is supplying AC power. 4. Check for dirty or stuck pins on the MagSafe connectors, both on the adapter and the computer. 5. Reset SMC by pressing the (left) Shift-ControlOption(Alt) keys along with the power button once.
Jan 29, 2011 | Apple MacBook Air
Shift key doesn't work!
I think that you need a new keyboard a new computer will be two expensive for just one key on the keyboard
you can also try an external keyboard just one that you can plug into the USB port it will work out just fine
Jul 14, 2010 | Apple MacBook Pro Notebook
Certain keys are creating double letter combinations e.g. typing "y" yields "hy", "i" creates "ki", "r" "fr", and "o" brings "o9". the shift key has stopped working. replaced batteries. took off key caps...
i think maybe some of your keys are stuck together. have you spilt something on it or is there a load of debris underneath keys if so just give it a wipe to clean it or blow on the keys to remove debris
Sep 26, 2009 | Dell 0Y3740 Keyboard
Selectric II Typewriter
This may sound stupid but lift it up a few inches and let it fall to desk. one of the character keys could be stuck underneath and this will jog it free. also see if you can shift. see if it makes a noise when you shift. It might be a shift clutch spring problem. I have been fixing these for 30 years. Lawrence
Apr 07, 2008 | Office Equipment & Supplies
Computers & Internet Logo
371 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
