Question about Winbook Corporation Computers & Internet
Winbook a700 caddy
Hard drive caddy and connector
2 Suggested Answers
  • 62 Answers
SOURCE: need a part
You can buy it from ebay. Please click here.
CompQ
Posted on May 11, 2010
Where can I find the part number for SONY ALPHA DSLR-A700 CF PIN CONNECTOR
Try your Sony retailer. Any reputable retailer should be able to help you with parts and accessories.
Dec 06, 2012 | Sony Alpha Dslr-a700 Cf Pin Connector...
I have the aspire 3680 but it hasa mk8034gsx-si hard disk that has gone bad what do i do?
Hello
You may need to re-place the hard disk if it gone bad, the picture shows it procedure of replacement.
The hard drive can be easily accessed from the bottom of the laptop. Simply remove the hard drive door, remove four screws securing the hard drive caddy, disconnect the hard drive from the connector on the motherboard and remove it from the laptop.
After that remove all screws securing the hard drive to the caddy and transfer the caddy to the new hard drive.
Hope this helps, if so rate the solution
Jan 20, 2011 | Acer Aspire 3680 Laptop
Need a part
CompQ
May 11, 2010 | NEC Versa LXi Notebook
What do i need to install a WD Scorpio Blue 500Gb hard drive in my HP dv90052us laptop - i've got the drive but it does not fit in it's slot like the original drive does - i'm putting it in the second...
You may need a "caddy" -- a metal shell that wraps around the disk-drive, in order to line-up its "data" and "power" connectors with the matching "sockets" inside the second drive-bay.
Order the caddy from http://support.hp.com
Apr 18, 2010 | HP Pavilion dv9005us Notebook
I have an E1505 with no hard drive, no dvd drive. 2 questions: Is there a special "sled" or tray needed for a new drive, and do the connectors for any new hard drive line up and plug into the bay...
Answer for question 2 is yes, get into the BIOS and change the boot menu to include a ISB device if one is not enabled. I am unsure of the factory default, but once you are in the BIOS you can check that usb booting is enabled.
The hard drive of the E1505 use a "caddy" which consists of a smooth plate and a caddy head that screws to the hard drive and allows easy access to the drive by allowing you to pull it free of the side of the computer. Some people do not use the flat plate and just screw the caddy head atraight to the drive itself. I would recommend the whole caddy setup. Ebay sells them by the hundreds. Dell does not use an adapter on the hard drive to get it to connect with the motherboard. Your drive should be a SATA interface and that is what is on the motherboard as a connection. All you need is a "caddy" to be able to easily remove and secure the hard drive.
Oct 28, 2009 | Dell Inspiron E1505 Notebook
Hard Disk upgrade
Figured this out...
1)  Flip laptop over, keep front of laptop closest to you and hinges away from you 2)  Remove cover with cylinder/harddrive icon (2 screws) 3)  Remove small single silver screw near the front (close to you) of the laptop in the center of the metal harddrive caddy (the caddy may hold one or two hard drives) 4)  Pull the plastic tab on the left toward the outside of the laptop... the whole caddy with harddrive(s) inside will shift to the left, disconnecting it from the motherboard and lining up the caddy for removal. 5)  Lift the entire bracket straight up
To remove the primary harddrive (the only one present in my model) you must remove the blue L-shaped circuit board from the caddy. 1)  Flip the caddy over 2)  Remove the three screws with slightly larger head diameters around the perimiter of the caddy 3)  Push/slide/jiggle the circuit board so the sata connectors release from the hard drive(s). 4)  Unscrew the hard drive from the caddy
Aug 25, 2008 | Acer Aspire 7720 Notebook
How do i fix a hard drive on a lap-top
You need to remove the old hard drive first. Depending on your model, there should be a screw or two on the bottom of the computer that gives you access to the hard drive. You remove the old drive, take it out of it's caddy, take the special connector off of it and install it on the new drive, put the new drive in its caddy, and replace the hard drive.
Thanks and please take a moment to rate this as fixya.
Jul 06, 2008 | Gateway Computers & Internet
Hard drive connector
It is called Hard Drive Caddy connector or Hard drive bracket , part number 465170802.
Ensure that you do not need the whole caddy.
Here is a reseller find more by putting part number in google.
regards
Mar 23, 2008 | Sony VAIO F540 Notebook
Computers & Internet Logo
Top Winbook Corporation Computers & Internet Experts
David Payne
David Payne
Are you a Winbook Corporation Computer and Internet Expert? Answer questions, earn points and help others
