Question about HTC Cell Phones
Brake light won't work
My brake light in my 99 Voyager won't come on. I have changed the bulb. I can't find a fuse for the light.
  • 1 more comment
  • ch768 Oct 26, 2008
    My question is is there a fuse for a brake light and where is it.
    only my left brake light won't work. Is there a fuse and where is it.
    It gives me a start to fixing my problem. Thanks
  • 1,879 Answers
While you're at it, check the bulb socket wires.
Posted on Oct 26, 2008
    Scholar:
  • 64 Answers
Your vehicle has two different fuse boxes. One is located under the hood, next to the battery. The other is under the driver's side of the dash, next to the parking brake lever. Here’s a link that shows the boxes: http://dodge.justanswer.com/view_image.aspx?rel='nofollow' href=%2fuploads%2fttiger79%2f2008-10-13_153813_1.gif I couldn’t paste the picture in here so you will have to use the link....good luck and let me know if this helps...
cbinny1
  • Craig Binford
    Craig Binford Nov 10, 2008
    Please rate my solution
    Thanks,
    cbinny1
    Master:
  • 538 Answers
Yes..that fuse will be either under the dash, or inside the engine compartment..included with the light accessories panel..not called a brake light fuse, by the way..
  • A Womans Computer Man
    A Womans Computer Man Oct 26, 2008
    well..when you get there, you may find that the fuse is fine..then you will need to check the contacts inside the bulb housing, to see if there is any corrosion..which can happen with an older vehicle..
  • 345 Answers
Check the power at your brakelight switch on the foot pedal if you have power at the pedal you can put a link wire across the wires and your brakelights should come on,if they do you need a switch....
  • colin white Oct 27, 2008
    if its only on one side check the power at the plug on the back of the cluster this way you will know if its a power problem or a cluster problem.....
  • HTC Master
  • 13,433 Answers
The connection is cut somewhere, possibly its not getting signal that the brakes are pressed. Fuses in the fuse box, check them all. if they are fine, and the bulb is fine, then you need to check and follow the wireing to find the fault.
1999 Plymouth voyager. right signal light. have changed bulbs, fuse and thing behind brake pedal
Connectors in the socket might be at fault. Hold the bulb to one side and the other to verify.
Oct 21, 2015 | 1999 Plymouth Voyager
My inside dashboard lights and back break light suddenly stopped working so cant drive it at night. Its a 99 honda prelude. I've tried changing the light bulbs and the fuse but still not working.
If the dash lights are on the same circuit as the park lights. Chances are if no dash lights... no park lights. Unless the dash light dimmer switch is on the low position. Check park light fuse. If no brake lights... which are on a different circuit and you are sure the bulbs are ok check brake light fuse. If fuse ok, unplug brake light switch at brake pedal and cross the terminals with a jumper. If brake lights work, the brake switch is faulty. If still no brake light operation suspect a wiring issue
Jun 18, 2015 | 1999 Honda Prelude
Brake lights won't work
Check the voltage or the connection.
__________
Multi-Cardiag M8 CDP for car and truck
Jun 05, 2013 | Cars & Trucks
I have 99 chevy suburban my brake lights dont work i changed the switch, checked the fuse its good cleaned the connections and checked the bulbs they still dont work
See if there is a relay for the tail lights/brake lights. I would go ahead and install new bulbs. Make sure that you get the correct bulbs. Not many vehicles still use the old 1157's.
Dec 22, 2010 | 1996 Chevrolet K1500
1193 plymouth voyager. Brake lighs don't work
Maybe a relay or fuse is bad or the wiring to it.
But you said that the third brake light works.
So the brake switch must be ok.
CIRCUIT PROTECTION Fuse Block Fig. 1: The fuse box is located under a cover at the lower left instrument panel — 1987 Voyager shown 85616099.jpg
The fuse block and relay bank is located on the driver's side under the lower instrument panel. The fuse block contains fuses for various circuits as well as circuit breakers, horn relay, ignition lamp thermal time delay, and the turn signal flasher. The hazard warning flasher is mounted into a bracket below the fuse block. The individual fuse and relay locations can be found in the wiring diagrams at the end of this section.
is bad.
Aug 01, 2010 | 1993 Plymouth Voyager
Brakes lights are not working.
The first thing to check is the brake switch(es) that are on the brake pedal lever, and the circuit for the third brake light is seperate from the normal brake lights.
If the brake light switch(es) and wiring do check out alright then the problem will most likely be in the turn-signal switch, and the brake lights are ran through the turn-signal switch.
Jun 07, 2010 | 1999 Plymouth Voyager
How do I change the brake bulbs on 99 Nissan Quest
The whole assembly will pop out with a screwdriver (carefully). Then the bulbs can be reached. Just push the whole thing back into the slots when you are done.
Feb 17, 2010 | 1999 Nissan Quest
99 mercury mystide had rear running light broken
If the driver's side tail light is working, it's not a fuse. Use a test light to check for power at the bulb holder. One terminal will be for tail light, the other for brake/turn light. If the is constant power for tail light, replace bulb. If no power, trace wiring from bulb holder to driver's side junction. Probable broken wire between the two tail lights.
Jan 16, 2009 | 1999 Mercury Mystique
My 1998 plymouth Voyager lost both brake lights but not center lt
CHECK ALL THE GROUND LEADS TO THE LIGHTS AND CHECK FOR CORROSION
Jan 15, 2009 | 1998 Plymouth Voyager
99 svt brake lights
Check the fuses in the fuse box. Use the diagram on the back of the cover. also check to see if there is power to them by using a light bulb tester. That should determine if you have a short or a cut wire somewhere.
Jun 12, 2008 | 1999 Ford Mustang Cobra
Cell Phones Logo
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
