Question about Sony DVDirect (VRDVC20) DVD±RW Dual Layer Burner
Tray stuck Tray won't open after pressing the 'eject' button
  • Susan Feb 22, 2012
    Thank you. Last week we found the small pin hole and it worked.
  • 21 Answers
SOURCE: ps2 cd tray does not open and the eject button light flashes
This is the tray getting stuck on the PS2 shell/casing. I can fix mine as it does the same thing but I tap it one quick time after I hit the eject button and it will usually open. Don't try to pry the tray open or this will make the problem worse.
Posted on Jan 10, 2009
  • 157 Answers
SOURCE: disc tray wont open when eject button pressed on ps2
The disc tray motor needs to be replaced. You can find one on ebay. A relatively easy fix. Good luck!
Posted on Nov 03, 2009
Warf135
  • 137 Answers
SOURCE: disc tray will not open. I've turned on &off
This problem is caused by a loose drive belt in the eject mechanism, you need to open the ps2 and replace the drive belt...
Take off the top cover, then take off the cover from the top of the dvd drive mech... then carefully remove the disc tray and you should see the belt near the front. Replace that belt and it should work fine again
On a couple of rare occasions the drive motor has been found to be faulty, but usually replacing the belt will fix it
Posted on Jan 27, 2011
  • 8457 Answers
SOURCE: Sony RDR-GX360 won't respond to
Try unplug,replug the unit back like about an hour later for the unit for resetting itself back to factory setting.If getting the same result the unit might have a shorted motor drive for the disc tray.Or shorted control panel on the unit itself.Well,this thing a basic DVD player only wright?If u can tries take it aparts and check out tries to repair it ur self that great.If u tries the shops,not worth it.Trash it.These basic DVD player only are very cheap now.U can get one brand new like $40 dollars.
Posted on Aug 11, 2011
  • 11800 Answers
SOURCE: Sony bravia DVD disk won't
Mechanical failure of the tray's mechanism - the clicking you hear is made by the wheel on the motor of the tray skipping over its eject lever.
The mechanism will have to be extracted from the tv as a whole then dismantled to see if the wheel can be reattached to the lever. If that is impossible (both plastic parts have been damaged) then the entire mechanism is dead and it will have to be replaced.
Since this is a brand new model and you bought it a few months ago it means that it's still in the warranty period. Because of that the entire repair/ replacement of the BR unit will be done for free by the dealer. Under no circumstance you should attempt to fix it yourself - opening the tv or forcing the unit will void the warranty.
Posted on Sep 15, 2011
Dvd stuck in computer
push eject button, slap the top of computer sould eject. the rubber type band that turns the wheel to open tray is worn out needs replaced
Apr 10, 2013 | Apple Televison & Video
I have a GPX D200B DVD Player and cant get the Disk Tray to open.
unplugged the dvd player and then re plugged, power on then press the eject button. if still the loading tray won't open, at this time you will need to remove the cover of the player to access the loading tray mechanical assembly. then check for an stuck up or broken rail plastic loading assembly it was installed drive by the loading motor.if ok, check the limit switch might not get contact which the processor not turn on the supply for the motor.
Nov 15, 2012 | Televison & Video
The tray On my original xbox won't eject. It will turn on and works perfectly, i just can't get "inside"
I've had this problem before. I used a slightly unconventional approach.
I took a screwdriver and gently attempted to pry the tray open (after pressing the eject button). More than likely, the tray is just slightly stuck. Be careful not to damage the tray.
There is a chance that a belt may have slipped, or some other internal component is keeping the tray from opening. If all else fails, take the console to your local game shop (BestBuy, GameStop), etc.) and they should be able to assist you.
Hope this helped,
-Dan
Oct 10, 2011 | Microsoft Xbox 360 Console
My cd is stuck and the eject button won't eject it. Is there any way I can get it out?
There are two ways to open the CD drive door ifthe button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drivetray next to the Eject button. Push the paper clip gently until the drive traypops out, then pull the tray until it is fully out, then you can remove the CDdisc.
If you continue having problem opening with the Eject button, then the CD drivemay be faulty and needs replacing.
Aug 10, 2011 | Dell Inspiron One 2305 Desktop Computer...
Dvd door won't open for Sanyo DVW 6000
If you are trying to eject a disc, look closely at the front bezel of the drive, there is a small hole near the eject button, push a paper clip into the hole (straightened paperclip) and the tray will be ejected.
If the DVD door is stuck and will not open through ejecting via the icon in My computer, or the eject button on the bezel will not work, you likely have a faulty drive that will need to be replaced
Jul 22, 2011 | Computers & Internet
My Technika DVDr 2005 drawer will not open and has a DVD in place - how can I retrieve the DVD?
turn it off then unplug the dvdr then after a while plug it again and turn on, now press the play button after a while press the stop button then next is the eject button. if still the tray won't eject unplug the dvdr use a philip screw driver unscrew to open the cover. look for the plastic motor gear then manually turn it with your finger to eject the tray now you can get your dvd. place back the cover and plug the unit and then turn on to check if its working again and eject the tray. thanks i hope it will help you good luck.
Jun 13, 2011 | Televison & Video
I have a burned CD in the CD drawer and I can't retreive it, I can't find the button to open the door. Somewhere there is a button" OPEN DOOR" but I can't locate it.
There are two ways to open the CD drive door if the button just below the drive tray does not work.
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc.
If you continue having problem openning with the Eject button, then the CD drive may be faulty and needs replacing.
May 19, 2011 | Gateway Computers & Internet
Well we have a acer computer and the cd drive is stuck
If pressing the eject button does not eject the tray, look for the small pin hole on the cd drive and insert a paper clip to press that hole. It would manually eject your CD tray. Hope this helps.
Nov 03, 2009 | Acer Aspire 5500 5570-2609 Laptop
Sony DVDirect (VRDVC20) DVD±RW Dual Layer Burner Logo
64 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
