Shower door replacement parts
I have a corner style shower with doors that part in the middle, they slide to the side. The manufacturer is Manhattan and the owners manual says Illusion shower door. I need the retaining clips for the bottom of one door these are the part numbers from the owner manual, 48039,48039 and 47033. I searched every where on the internet and can't find them. Can anyone tell me how to find these parts?
  • 9 Answers
SOURCE: Assembly instructions for Niagara corner shower encloser
Go to this link and print the pages. original instructions. Good luck.
Posted on Feb 21, 2009
  • 548 Answers
SOURCE: Spartan brand curved glass shower door installation info needed.
curved cut glass will not always be the exact dimensions though they may look identical there should be several set screws on both the door glass frame and the shower glass frame that can be loosened and reset to make the door fit and close and open more properly without seeing the showwer itself i can not tell you exactly where they are but they should be either visible or behind a facade piece of metal frame
Posted on Aug 27, 2009
Testimonial: "Thanks. I will try tinkering with it a bit more and see if that works better. :-)"
  • 548 Answers
SOURCE: I have frameless shower doors, the bottom sill
if the glass actually contacts the tile you can go to the homedepot or similar place and buy some glass silicone sealer and just run a nice bead of caulk along the line, make sure you get clear silicone and let it thooroughly dry before you get it wet
Posted on Sep 14, 2009
mrhotandcold
  • 248 Answers
SOURCE: i have a flair shower door and the runner is
yes you can order new runner from PlumbCentra You sould always put Vaseline on runners will last for ever
Posted on Sep 18, 2009
Testimonial: "delighted with feed back. problem solved"
  • 4 Answers
SOURCE: I have a frameless pivot shower (doors are 182 x
Finaly a found a supplier, www.novellini.nl
The parts are:
De benodigde artikelnummers zijn:
1 x R02YOB2G-40 (set scharnieren t.b.v. één deur) à € 23,80 incl. btw.
De prijs van de bovenstaande set onderdelen is € 23,80 incl. btw.
Verzendkosten zijn € 7,50 incl. btw.
Posted on Mar 25, 2010
How do I adjust the position of the sliding doors on my quadrant corner unit shower or how do I remove the doors to clean behind? thanks
Look at the top and bottom mounting points for indications that it may be adjustable. It may be necessary to remove the door to expose the adjustment provision.
Aug 22, 2015 | Home
I have a old mercury villager ...i want to replace the middle row seat with last row seat ...is it posible...?
The middle row seat slides forward to the middle position (and several other positions as well.)
Owners manual explains how to slide rear seat foreard.
Remove middle row seats. Lift handle under 3rd row seat cushion on passenger side. Raise seat cushion up until it locks up. Then lift the lever on the passenger side of seat and pull seat forward until it locks in place.
if you don't have owner manual, go to motorcraft.com, pro center, tech info, owner manual.
join our group for free help.
please rate too. Thanks.
http://groups.yahoo.com/group/villagerquest/
Jan 24, 2011 | Mercury Villager Cars & Trucks
The inside shower door is uneven, making it come of the hinge after moving it more than 4-6 inches.The metal attachment holding the glass is lower than the other ones.How do I get it even so it slides...
The top rollers should have adjustments on them to bring the door to horizontal as it swings accross the track.
Start with door in the middle and adsust by seinging it to both sides.
Dec 02, 2010 | Basco Deluxe Sliding Glass Shower Door /...
I installed a new bathtub bypass shower door and the outside glass doesn't slide smoothly. It seems to bind in the middle of the bottom support track; it moves, but not as freely and quietly as it should.
Please clarify - you said it's a pivoting door but also said it doesn't slide smoothly - can't really do both at the same time. If it's a typical bypass sliding door then you should be able to make an adjustment to the hanging brackets on the offending door to raise it up off the track. If all else fails the header track can be raised thereby making the doors hang higher and off the track attached to the tub surround.
Oct 28, 2010 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Aug 27, 2009 | Sterling Plumbing Sterling& By-Pass Shower...
ECM Giotto group gasket and shower plate falling out
I am assuming that you have basket style shower which sits in the gasket and then inserts in the group.
Find the small bevel edge on the gasket, make sure that side is facing up, place gasket on table then insert shower in gasket, then lift gasket, until it sits at the top of the shower(use a small flat screwdriver or a small hard brush to clean the group where the gaskets seats), then insert gasket and shower in group. Push in as far as you can then use the portafilter to seat the gasket in all the way.
If your shower is the flat style then there should be a hole in the middle for a screw.
May 29, 2009 | ECM Giotto Espresso Machine
Installing shower doors
you going to need a 2' square aluminum tubing for the corner.
the tubing need to be bolted to the floor. and bolted from the 2 upper rails. then you can attach the doors.
make sure the tube is well secured. the door weights about 12lbs-15lbs each ( depended on the glass).
Mar 22, 2009 | American Standard 5 ft Sliding Shower Door
NEED INSTRUCTIONS MANUAL!!!
http://www.hillbillyhousewife.com/breadmachinemanual.htm
This was helpful to me. Good luck!
Mar 16, 2008 | Kitchen Appliances - Others
Computers & Internet Logo
450 people viewed this question
David Payne
David Payne
