Question about Simmons SDMK4 Digital Multi Pad Electronic Drum Set
Simmons SDMK4 Digital Multi Pad Electronic Drum Set manual
2 Suggested Answers
  • 140 Answers
SOURCE: I turned on my Yamaha
Open it up and find the bad connections. If you still have trouble you can send it to Pro Line Music servicedepartmentprolinemusic@comcast.net
Posted on Jun 10, 2011
I need an instruction manual
If you search in Google your exact drum type and add the word "manuel" behind it, it brings u to a pdf file to download of the manuel, i downloaded it but it's too much to post. Its at musicians friend.com website
Jun 17, 2014 | Simmons SD7PK Electronic Drum Set
Simmons SD9K control panel only lights up
Mine and a whole lot of others did the same thing with the SD9K Simmons kit. I called Simmons, they sent me a new power cord...that obviously didn't work. Then they said to wait on a new drum module...that never came. It's been 2 years and now they say they have no records of ever talking to me or sending me the power cord!!! Horrible product, horrible customer service. Whatever you do...don't put any more money into Simmons...only go with Roland!! Trust me on this one!! Me and about 3 others I know waisted $900 on Simmons and we are all paying the price now. So, to answer your question, you need to buy a $300-$400 new module!! Ridiculous!
Apr 01, 2012 | Simmons SD9K Electronic Drum Set...
Need insrtuction manual
go to:www.music123.com/.../DV040_PDF_Copy_5E45EE25-FEDB-48EC.
Feb 02, 2012 | Simmons SD5K 7Piece Electronic Drum Kit
Clarity 7 Pad Electronic Drum Machine Instruction Manual
How do I get a manual for the clarity 7 drum set
Jan 06, 2012 | Clarity Music
The bass (kick) drum pad is not working. When i plug the kick cable into the kick pad, it does not project a sound when I strike it. I know the cable works because i tested it in the other drum pads, and...
If youve already tested the signal path and it works then your likely just dealing with a bad piezo inside the kick drum. The piezo is actually what detects the trigger. You could probolly replace it yourself it not hard typically just 2 solder joints but you'd have to buy the piezo. Call the manufacturer they should provide you with whomever distributs their parts locally to you.
Sep 08, 2011 | Simmons SD7PK Electronic Drum Set
The sub woofer wire inside came off my Simmons DA200S. where do i plug it back in?
If you look on the circuit board that the big black heat sink is attached to, there are two output amp chips (integrated circuits) attached to it. IC7 is the sub output amp. Next to that is a white jack with two pins sticking out, labeled J9. J9 is where you plug your sub into.
Jul 28, 2011 | Simmons DA200S Electronic Drum Set Monitor
I have the Simmons SD9K electronic drum kit. I really love it, but I have two seperate issues. First, I sometimes get a snare pop out of the blue while playing a beat and sometimes just after I stop...
With the sensitivity set very high, you might be getting false triggers from static discharges. It sounds like your snare trigger is either bad or possibly the cable from it may have a problem as you should NOT have to set the sensitivity so high.
It will take an oscilloscope to test the pad unless you can find a system to do a sensitivity comparision. The second problem regarding the recording/overdubs I cannot help you solve.
Mar 27, 2011 | Simmons SD9K Electronic Drum Set
I have the Simmons SD7PK. It sounds as though the speakers to my amp or through our PA system are busted. What could be causing this?
First thing is to verify your sound system is OK by running program material such as a CD at normal levels through it. If it is OK then you need to consider if your drum set is overdriving your sound system. Drums generate high pulses and can easily saturate PA systems. First thing here is to connect headphones to your drum set and listen how the set sounds via headphones. If both these tests pass muster, then your PA system may be too small to handle the drum audio. In that case, get at least a 15 inch powered monitor, preferably bi-amped to run the drums through.
Mar 07, 2011 | Simmons SD7PK Electronic Drum Set
Simmons SDMK4 Digital Multi Pad Electronic Drum Set Logo
41 people viewed this question
Top Simmons Music Experts
Michial Gueffroy
Are you a Simmons Music Expert? Answer questions, earn points and help others
