Question about Nintendo Video Game Consoles & Games
How do you do a Wii system update - Nintendo Video Game Consoles & Games
Can not perform wii system update
The last system update for the wii was the 4.3 system update and that was in September 7 2010. There should no be any other update If it is giving you an error code look it up in this website Error Code Lookup Wii and Wii mini Nintendo Support this might also help Unable to Perform System Update Nintendo Support
Mar 30, 2016 | Nintendo Wii Console
The Wii console light will turn green
Hi sharonkayh,
Try the following:
1) Completely power down your system by pressing the power button for 10 seconds. If that doesn't work, unplug the AC Adapter from the Wii for a moment, then plug it back in.
2) Make sure your Wii console has the most current Wii system menu. Download the latest update, and then test your Wii console to determine if the problem has been resolved.
This is done by:
  1. Make sure your Wii console is successfully connected online.
  2. Access the Wii System Settings.
  3. Click on the blue arrow twice to reach the Wii System Settings 3 menu options.
  4. Select "Wii System Update" and press the A Button.
  5. Select "Yes," and read any messaging regarding obtaining the update. If you agree to the messaging, select "I Accept."
  6. The Wii console will now search for the latest Wii System Update.
  7. If an update is available, it will be downloaded and installed automatically.
I hope this can help you - Source: Nintendo Website.
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 05, 2011 | Nintendo Wii Console
My wii won't play the new wii games.Need to know how to upgrade?It will play the older wii games.
hi there,
the best and easiest way to upgrade the firmware on your wii is to connect the wii to your internet and look for system update in the system settings and update that way. Altthough most games that need newer firmware come with the update installed on the disc, normally once you insert the disc it will tell you it need to update the system firmware in order for the game to work, so i'm not sure why this is not happening for you if your new games not playing. The only thing i can think of if it's not updating automatically is that the wii has been chipped/modded in some way, has it? If it has'nt just connect the wii to the internet you should be able to update it that way.
Hope that helps
Feb 15, 2011 | Nintendo Wii Console
Wot is wii system update
wii system update is when your wii gets the updates for channels such as the nintendo channel
Mar 18, 2010 | Nintendo Wii Console
Error code 32017 keeps coming up on my wii console. i can still connect to the internet on my wii and play games but whenever i put in super smash bros it requires a system update. it will begin but never...
Error Code: 32017 There appears to be an issue with updating your Wii console.
  1. Try and perform another Wii System Update on your Wii console (how to).
  2. If you attempt another Wii System Update and still receive this error code, please call 1-800-255-3700 so that we may assist you further.
Mar 03, 2010 | Nintendo Wii Console
Error code 51420
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
oishuk13
Dec 26, 2009 | Nintendo Wii Console
Error code 32017
Nov 12, 2009 | Nintendo Wii Console
My wii unit does't work. There is nothing but a black screen.
Hi.If the power light is green or orange and your screen remains blank, follow these steps.
1. Completely power down your system by pressing the power button for 10 seconds. If that doesn't work, unplug the AC Adapter from the Wii for a moment, then plug it back in.
2. Make sure your Wii console has the most current Wii system menu. Download the latest update, and then test your Wii console to determine if the problem has been resolved. If you continue to experience this issue, there is a problem with the Wii console and it will need to be repaired by a certified Nintendo service tech.
SYSTEM UPDATE
If your Wii console is currently connected on-line, you can download the latest Wii System Update by selecting the "Wii System Update" button from Wii System Settings menu. Downloading the latest Wii System Update will add the most current features to your Wii console. If you already have the latest update, on-screen messaging will indicate so after the Wii console searches the available Wii System Updates.
Oct 23, 2009 | Nintendo Wii Console
I put in a game and the home screen says "system update".
hope this helps.
Aug 28, 2009 | Nintendo Wii Console
How do i get connection 24 on my wii?
When you are not able to connect with Internet from Your Wii, means there is something wrong with the settings. You may go to Wii Fix Guide and check out the guide available there, This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge.....
Mar 09, 2009 | Nintendo Wii Console
Video Game Consoles & Games Logo
18 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
